2006 Tundra Engine "Whine"
Discussion in '1st Gen Tundras (2000-2006)' started by mtb-sam, Feb 9, 2021.
  1. Feb 9, 2021 at 4:54 PM
    mtb-sam
    mtb-sam [OP] New Member
    Hello!
    I have a 06 Tundra ( under 150k miles ) that recently started making a "whining" noise that is heard when the truck is idling, mostly goes away once you start driving or under load. Appears to be coming from the passenger front side of engine. Any ideas of what this could be? It has been intermittent but recently the noise seems to be happening all the time.
    Possibly a pulley bearing? power steering pump? pump fluid?
    Link to youtube video link below for audio.
    https://youtu.be/DmHjic2v2SU
    Thanks!
  2. Feb 9, 2021 at 4:59 PM
    jskeyes2
    jskeyes2 New Member
    Jeff
    Carlsbad, CA
    2005 Limited AC
    ADS Shocks 35” Yokahama M/T
    Is it only when warming up or when warm too?
  3. Feb 9, 2021 at 5:11 PM
    mtb-sam
    It does both.
  4. Feb 9, 2021 at 6:10 PM
    Professional Hand Model
    Fred
    Hand Protectors
  5. Feb 9, 2021 at 6:12 PM
    Try isolating it listening with a stethoscope or through a garden hose. To me it sounds like it’s possibly an accessory. I’ve got a noisy power steering pump but you can hear the ball bearings, it doesn’t sound like yours although that doesn’t necessarily rule it out.
  6. Feb 9, 2021 at 8:22 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    Probably the alternator.
    remove the belt and run it for a minute to see if the noise goes away. Then go from there with a stethoscope
  7. Feb 10, 2021 at 7:36 AM
    mtb-sam
    Thanks for the tips!
    Noise seems to be intermittent at this point - didn't make the noise this morning both cold and warmed up. I've got a stethoscope on order ill dig deeper once the noise comes back.
  8. Feb 11, 2021 at 7:44 AM
    Grumpy74
    Grumpy74 New Member
    2005 White Tundra SR5
    I've got the same noise coming from the same location. I've narrowed it down to the power steering pump. Try turning the wheel back and forth while it's running to see if it gets louder or changes tone at all
  9. Feb 11, 2021 at 7:46 AM
    Probably grew a supercharger. What have you been feeding that thing?
