where to put a sub in a first gen
Discussion in '1st Gen Tundras (2000-2006)' started by griffinbristow, Feb 8, 2021.
  1. Feb 8, 2021 at 4:36 PM
    griffinbristow
    griffinbristow [OP] 2004 tundra SR5
    Griffin
    Alabama
    2004 Toyota Tundra SR5 4x4
    3” leveling kit, 33” nitto ridgegrapplers, full audio restoration
    does anyone have any clue of a good location to put a subwoofer in a first gen tundra. right now i just have mine sitting on top of the rear seat but i’m trying to gain that seating back. i know there’s that stealth box for the center console but i don’t really want to lose that storage. there’s just not enough space under the rear seats. any ideas?
  2. Feb 8, 2021 at 4:42 PM
    Access or double cab? I've seen a box for an access cab.
  3. Feb 8, 2021 at 6:35 PM
    Riverdale21
    Riverdale21 Speed seeker
    OTP ATL
    06 DC SR5 Tundra TRD Off Road
    If you have a double cab there are companies that make either baffles or actual sub boxes that fit in the under rear seat storage areas.
    I have a DC but run a self powered Rockford Punch 8 under the front passenger seat.
    https://www.crutchfield.com/p_575PS8/Rockford-Fosgate-PS-8.html
    Fits alright but had some vibration against the seat rails. I put a piece of 1" thick high density pillow foam on the top and bottom, works great. Puts out a surprising amount of bass for it's size
    G_unit3000 likes this.
  4. Feb 8, 2021 at 6:58 PM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    this is what I did as well. Was the cheaper option vs buying the console or underseat boxes
  5. Feb 8, 2021 at 7:02 PM
    Riverdale21
    OTP ATL
    Yup. Once you price out subs, box, and amp may as well buy the self powered.
    CodyP[QUOTED] likes this.
  6. Feb 8, 2021 at 7:07 PM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    I also went cheap with the sub cause I just need a little low end. I mean I'm not 17 anymore haha. $89 off Amazon with a $30 wiring kit and I was set.
  7. Feb 8, 2021 at 8:08 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    He already has a sub, amp and wiring.
    Access cab or double cab?
    Access cab you can build a baffle into the rear passenger side compartment and put an 8" or a shallow 10" in. Won't sound amazing being free air but you'll have your seat back. Or you can spend $350 on the dual 8" qlogic box and buy 8" subs for it. Expensive option but gets what you want.
    Double cab has a much larger compartment under the driver side rear where you can fit 2 8'' subs in a baffle and have more room to seal up the sides for better sound.
  8. Feb 8, 2021 at 8:23 PM
    1lowlife
    1lowlife New Member
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    I had a custom box built for a 10" Punch ran it off some old school amps in my 06 DC, when I owned it..
    Could remove the sub quickly if needed..
    If I had it to do over again, I'd make an enclosure under the rear seat and buy a swing case or something to put my stuff in.
    WooferBox2_e4e9bd4e477af44a505cf4206a2e5a0b7393b9a2.jpg WooferBox1_f538d9301c8e33d5d9c726c4dc9efa258c83ff08.jpg AmpMount2_e9024a3e8e980b4efdcaba018b96b9672ad35607.jpg AmpMount3_914fe5077e9b8820f8d80776307b75d6ccce4b91.jpg
  9. Feb 8, 2021 at 8:48 PM
    weadjust
    weadjust New Member
    Tupelo, MS
    2006 Tundra Limited DC
    I have a Kenwood powered sub under the rear passenger seat in my double cab. It won't rattle the windows but fits my need. Had to move the jack and lug wrench to my tool box.
    G_unit3000 and abcinv like this.
  10. Feb 8, 2021 at 8:50 PM
    APalmTree
    APalmTree Sometimes helpful
    Brandon
    SW Washington
    A few... Definitely more than 2
  11. Feb 8, 2021 at 9:10 PM
    Ghostly.-
    Ghostly.- Tragic.
    Mitchell
    Montana
    I pulled the smaller section of my rear seat and put a 12" there. I would never use it anyways because my seat would always be all the way back and nobody could fit there. Have had it in there for about 8 months with no issues. I'll grab pics in the morning if you want them.
  12. Feb 9, 2021 at 4:14 AM
    abcinv
    abcinv OEM (+) Junkie
    Tommy
    Lookout Mtn Georgia
    I love those old Punch Amps! The Orion reds were bad ass as well...back in the day.
    1lowlife[QUOTED] likes this.
  13. Feb 9, 2021 at 9:47 PM
    1lowlife
    1lowlife New Member
    DADA
    2014 MGM DC SR5
    I wish I still had them....
  14. Jun 30, 2025 at 5:05 PM
    ps8820
    ps8820 New Member
    joe
    06 SR5 AC 2WD V8 CaptainsSeats
    Freshly Killed Piezo Buzzr!, Re-paint 04-2025
    @weadjust ....
    Old thread revival [late to the party]...
    just wondering, if any of these guys are still alive [@tundras.com ha-ha]...
    But if using the passenger rear-under seat box, obviously you 86 the Toyota amp and therefore skip the 'ByPass harness' and now direct wiring to speaks from replacement HU?
    Or did I miss something, or just answered my owm question?
  15. Aug 14, 2025 at 1:22 AM
    Ron Tundra
    Ron Tundra New Member
    05 Tundra access cab v8 4x4
    I used the Metra 70-8121. It plugs into the harness that comes off the amp and goes back to the deck. (Like 10' of wire)
    And yes the tweeters work, even though there's only 4 pairs of wires
  16. Aug 14, 2025 at 5:21 AM
    Incorrect, though Ron covered that. The only bit I'd add which may be helpful is...
    The OEM amp wiring goes from the head unit to the back cubby. Two connectors, and they're bulky, only one gets plugged into the Metra ampy bypass harness. Some boxes, like the Q-Logic enclosure, not only require removing the amp and the cover plate, but you can't keep the OEM amp harness connectors where they are. I ended up pulling my passenger seat, and re-routing the OEM amp connectors up to the dash area, IIRC.
    Man, you're really digging up the zombies aren't you?
