Differential
Discussion in '1st Gen Tundras (2000-2006)' started by Cody06tundra, Feb 7, 2021.
  1. Feb 7, 2021 at 8:19 AM
    Cody06tundra
    Cody06tundra [OP] New Member
    Cody
    2006 Tundra Crew Cab SR5 4.7L
    Hey guys.
    I'm going to change the gear oil in my rear diff today and I saw online that I need to have Crush gaskets. My question is is that true and if it is do I need one or two and is this part the correct one?
  2. Feb 7, 2021 at 8:32 AM
    Professional Hand Model
    Fred
    Hand Protectors
    On the 2002, I seem to remember not needing a new gasket. Just reused what was on there.
    Jack McCarthy likes this.
  3. Feb 7, 2021 at 8:32 AM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC 2wd
    I hardly ever replace them. Iirc though it should be an m18 x 1.5mm thread. So 18mm i.d. washer if needed.
  4. Feb 7, 2021 at 8:39 AM
    Don't believe that's the correct part. That's for an oil pan and its generic, not specific to any model it would appear. I believe the Drain plug on the diff is much bigger than the one on the oil pan. Check your breather while you're down there, if you haven't done the relocation mod, give the cap a few twirls to loosen any crud buildup.
  5. Feb 7, 2021 at 8:40 AM
    des2mtn
    Shady Grove
    2004 Black DC Limited 4x4
    Tonto cover
    I got a new drain and fill plug from my dealer's parts counter and both included a crush washer.
    Cody06tundra[OP] likes this.
  6. Feb 7, 2021 at 10:34 AM
    Pucks18
    Pucks18 Fleabit peanut monkey
    2001 Tundra 4x4 Limited trd
    Na u dont need new ones, unless u like the satisfaction of doing the job 100% correct, but even im too lazy for that
  7. Feb 7, 2021 at 11:03 AM
    Cody06tundra
    Cody
    Yeah I do like to do it one hundred percent. I spent two and a half years at a technical college studying Automotive Systems Technology just so I could work on my own stuff and do it the right way.
  8. Feb 7, 2021 at 11:10 AM
    I have a crush washer for one of my drain plugs in my toolbox, maybe the oil or transmission. There it sits. I always forget to use it when I'm doing a fluid swap. Never had a plug leak in spite of my short comings.
  9. Feb 7, 2021 at 11:12 AM
    Cody06tundra
    Cody
    I'm not going to bother using it. The dealership is 30 miles away from me and I don't feel like paying or waiting for it to ship. I'm sure it'll be fine.
  10. Feb 7, 2021 at 11:15 AM
    Fred
    Hand Protectors
    Same here. I bought a pack of 10 Oil Plug Washers from Toyota. Lined them up and taped them to my Tool Box like @abcinv does with his coins in his coin holder.
    9 of the 10 sit there unused but I do enjoy their Mojo.
    abcinv likes this.
  11. Feb 7, 2021 at 11:17 AM
    Cody06tundra
    Cody
    Of course that was 10 years ago and I forgotten most everything that I've learned. However I kept all of the text books except for the electrical one which disappeared which sucks because that was a really good one to have. Plus I'm also going to be buying a one year membership to all data for my Toyota Tundra so if anybody has any technical questions or needs drawings or anything like that just let me know and I will send you a copy of whatever you need.
    Pucks18 likes this.
  12. Feb 7, 2021 at 11:18 AM
    Fred
    Hand Protectors
    Just download the free one from @Tundra2
    Pucks18 likes this.
  13. Feb 7, 2021 at 11:21 AM
    Cody06tundra
    Cody
    How do I find that?
  14. Feb 7, 2021 at 11:47 AM
    Fred
    Hand Protectors
    Someone will post it for you. Give it a little wait time.
  15. Feb 7, 2021 at 1:51 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
  16. Feb 7, 2021 at 1:52 PM
    Is it in the sticky?
  17. Feb 7, 2021 at 1:52 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    I don't reckon
  18. Feb 7, 2021 at 1:54 PM
    There's a 5,000 page FSM in there from @Pinay
    Tundra2 likes this.
