2000 TRD Limited for sale
Discussion in '1st Gen Tundras (2000-2006)' started by sjamins1986, Feb 6, 2021.
  1. Feb 6, 2021 at 12:43 PM
    sjamins1986
    sjamins1986 [OP] New Member
    2000 Tundra TRD Limited
    TBD
    I need to get my truck up for sale but I have no idea what a fair price would be.
    2000 Access Cab limited 4x4
    214k miles
    New wheels and tires (stock set from a 2019 Tacoma)
    I’ve had the Timing belt, water pump, thermostat etc done recently.
    Hard shell bed cover
    problems:
    Exhaust manifold leak on the drivers side
    parasitic power drain coming from an “integration control module” (controls dome light, cargo light, etc)
    This part is unique to the truck and is $1700 from Toyota although if you can find one at a junk yard it is programmable according to the local stealership.
  2. Feb 6, 2021 at 7:15 PM
    SouthPaw
    SouthPaw The headlight guy
    2000 Limited 4x4 AC
    Www.kbb.com
    Www.nada.com
    Start there for a baseline and check your local CL/FB to see what others are going for.
  3. Feb 7, 2021 at 7:37 AM
    Insurance quoted me $5800 value for mine about a year ago. Same truck as you, 250k miles at the time. Trucks were going for around $6700-7800 at the time. You could likely get that or more now with the short supply of trucks and the good reputation and desirability of these models. The exhaust leak will have to be remedied. If your not doing it yourself it will be $$$. If you are doing it yourself, it's a pain in the ass. The module may be able to be saved, it's a solid state piece. Someone may be able to clean it up and get it proper for you. Maybe only a couple hundred bucks. Or pull one from a junkyard.
