Headlight question 2018
Discussion in '2.5 Gen Tundras (2014-2021)' started by Forkhunter, Feb 5, 2021.
  1. Feb 5, 2021 at 11:18 AM
    Forkhunter
    Forkhunter [OP] New Member
    2018 DC Limited
    The answer to this is probably buried in some other threads. I searched, but wasn't 100% clear. My dad and I both have 2018's. Mine is limited and his SR5. Do we have different headlights? He was complaining about his and was wondering what he should do to upgrade. I want to offer him advice, but we are a couple states away.... I am happy with mine and assuming it is because I have an upgraded version vs his? Appreciate any confirmation and/or advice to give him. He is not one that will be going to an internet forum to get advice....
  2. Feb 5, 2021 at 11:23 AM
    AZBoatHauler
    So.Arizona
  3. Feb 5, 2021 at 11:25 AM
    War Machine
    War Machine SSEM # 5 3MW
  4. Feb 5, 2021 at 11:25 AM
    AZBoatHauler
    So.Arizona
    That’s my understanding unless equipped with the TRD OR package. Thanks to @AzureNightmare for pointing this out - I thought all SR5s got halogen.
    The iHacker thread seems to confirm this.
    War Machine and GODZILLA like this.
  5. Feb 5, 2021 at 11:29 AM
    18" TRD Off Road Wheels
    Correct. Unless it has one of the TRD packages.
  6. Feb 5, 2021 at 11:32 AM
    War Machine
    I’d thought they switched them all to LED in 2018. Seems silly to keep manufacturing the halogen ones. Adam, did your 2019 come with halogen?
  7. Feb 5, 2021 at 11:34 AM
    I specifically got the TRD OR package just for the LED lights. Look at a 2021 Trail Edition. They are halogen.
    jonclark96 likes this.
  8. Feb 5, 2021 at 11:35 AM
    1000% agree with this.
  9. Feb 5, 2021 at 11:37 AM
    jonclark96
    jonclark96 Not so new member
    Jon
    Maryland
    2021 Army Green SR5
    Yup. I have a 2021 Trail Edition with halogen lights...
    GODZILLA[QUOTED] likes this.
  10. Feb 5, 2021 at 11:37 AM
    War Machine
    I’ll be damned. I wouldn’t think anyone would waste manufacturing resources on halogen any more. Even most of my lighting manufacturers have made nearly everything non-led a special order item at this point.
  11. Feb 5, 2021 at 11:38 AM
    War Machine
    It’s a whole other line in the plant for something nobody wants, and it’s not even cheaper to make them anymore.
  12. Feb 5, 2021 at 11:39 AM
    Yup. My guess is that they kept it up so they had reason to keep up production for replacements in all the ones still on the road.
  13. Feb 5, 2021 at 11:46 AM
    War Machine
    Makes sense that way. I’d be pretty miffed to get them on a new truck though.
  14. Feb 5, 2021 at 11:51 AM
    Yup. I specifically only looked at packages the had LEDs. It's a dealbreaker on a new vehicle for me. Part of why stuff like Fords are off the table. Only the upper trims get them.
    Anyway, OP, @AZBoatHauler pointed you in the right direction. Get in contact with @iHacker and you'll get all the info you need.
    BravoDeltaRomeo likes this.
  15. Feb 5, 2021 at 11:54 AM
    BravoDeltaRomeo
    Bruce
    MB Canada
    2019 Cavalry Blue Tundra CM
    My 2019 SR5 had LED DRL and Halogen Headlights/Fogs.
    My wife's 2020 RAV5 has LED Headlights/DRL and Halogen Fogs. :facepalm:
    It's like they are using up old parts before putting LED in an ALL makes/models, like they should have been since 1994.
  16. Feb 5, 2021 at 12:06 PM
    Forkhunter
    2018 DC Limited
    So maybe the difference is the lack of adjustment? He does have the TRD OR package but doesn't have this .
  17. Feb 5, 2021 at 12:08 PM
    War Machine
    If he doesn’t have that, he’ll have to adjust them manually on the headlight itself. (Yet another thing I thought was standard. My 2011 SR5 has the adjuster knob.)
  18. Feb 5, 2021 at 12:10 PM
    AZBoatHauler
    So.Arizona
    You can adjust them manually with a Phillips screwdriver if you pop the hood. You’ll see a circular cut out for the screwdriver and a gear to adjust the aim up or down. I’ve read the hot spot of the beam should be 2-4” below the center of the headlight at 25’. You can find YouTube videos discussing the aiming process in detail if necessary.
    Shocked to hear someone complain about these lights - they are the best OEM lights on anything that didn’t come out of Germany IMO.
  19. Feb 5, 2021 at 1:20 PM
    Forkhunter
    2018 DC Limited
    Well.....after 2 years of ownership, my dad did discover he does have the light adjustment....geez....maybe if he doesn't have them pointed straight down, he will be more pleased with them. Thanks for all who helped. Unbelievable....
  20. Feb 5, 2021 at 2:15 PM
    Xyleff
    Xyleff New Member
    NorCal
    ‘16040CMSR5
    Bit off topic but does the ‘18+ have foglight switch that can be turned on/off with drl without the HL on?
  21. Feb 5, 2021 at 2:29 PM
    YotaBro
    YotaBro This forum will make me broke
    Calvin
    FL
    2017 Cement Grey Tundra TRD PRO
    Lots of shenanigans.
    Dumb question but what does that dial do? I have it on my truck but have no idea what it actually does.
  22. Feb 5, 2021 at 2:34 PM
    Forkhunter
    2018 DC Limited
    It raises and lowers your headlights. Nice if you are towing, etc so you don't blind oncoming traffic.
    YotaBro[QUOTED] likes this.
  23. Feb 5, 2021 at 2:34 PM
    BravoDeltaRomeo
    Bruce
    MB Canada
    Moves the focus of the headlights, up and down, in small increments.
  24. Feb 5, 2021 at 2:36 PM
    That angles your headlights up and down. Park with your headlights pointed at a wall, then move it one notch and you'll see your headlights move. It's so you can adjust your headlights to account for a loaded bed and such, so you don't blind oncoming traffic.
