RTT Setup
Discussion in 'General Tundra Discussion' started by hunterta1, Feb 4, 2021.
  1. Feb 4, 2021 at 10:10 AM
    hunterta1
    hunterta1 [OP] 2017 Tundra CM Limited
    Travis
    2017 Sand Tundra Limited
    Is anyone running this setup? Victory 4x4 half rack with a Tuff Stuff® TRAILHEAD™ Roof Top Tent, 2 Person. I'm trying to get started on planning what I would need for a RTT setup that also works with a tonneau cover. I'm not set on the tent yet, but it's on sale for cheaper than most and has higher weight capacity. I'll be traveling quite a bit this year to multiple state/national parks and want to get something a little bit better than a cheap 2 person ground tent. I'm extremely new to the idea of RTT so looking for a little guidance on the best route. TIA
    IMG_2433.jpg tuff-stuff-trailhead-roof-top-tent-2-person-roof-top-tent-tuff-stuff-overland-818249_2048x.jpg
    jewsNbrews likes this.
  2. Feb 4, 2021 at 10:22 AM
    jewsNbrews
    Jewiston Idaho
    2019 TRD PRO
    Bolt on
    I believe RCI makes a bedrack that works with a tonneau cover. Also, unless dead set for a rack, I think some cross bars are compatible with tonneau covers as well.
    Good luck. I went with a datin metal fab bedrack for my setup, but I don't have a tonneau cover to plan around.
  3. Feb 4, 2021 at 10:28 AM
    hunterta1
    Travis
    I've looked at cross bars also, but didn't want something that low that might interfere with rolling up the cover, plus the extra height of the rack would allow me to put some taller items in the bed.
  4. Feb 4, 2021 at 11:15 AM
    jewsNbrews
    Jewiston Idaho
    2019 TRD PRO
    Bolt on
    Totally makes sense. If it was me, I'd do a quick Google search for bed racks and then call the companies to see if they are compatible with a tonneau. Hopefully others will chime in soon. Also check out build threads or the over landers thread on here. Maybe you'll find someone with similar setup to your needs.
    hunterta1[QUOTED][OP] likes this.
  5. Feb 6, 2021 at 2:07 AM
    OnespeedTRD
    OnespeedTRD New Member
    Don
    San Diego
    275/70r18 Cooper AT3 XLT on SCS Ray 10s, Eibach Coilovers, DD 12" Exhaust, AJT Blackout Kit, Truxedo Pro X15, paint match/chrome delete.
    RCI and KB Voodoo make adapters to fit their racks with a soft roll-up or retractable tonneau cover.
    They're offset brackets that allow the tonneau cover to fit underneath the rack.
    You might lose some of the watertight integrity of the cover, but better than nothing.
