Wheel offset
Discussion in 'Wheels & Tires' started by roger280@gmail., Jan 31, 2021.
  1. Jan 31, 2021 at 4:49 AM
    roger280@gmail.
    roger280@gmail. [OP] New Member
    Roger
    2016 Tundra Platinum
    Hi all, I’m new to the group. I am looking for some advice on wheel size offset. I am planning to install a 4 inch rough country lift with 35x12.50 on fuel ripper wheels and fender flares on my 2016 crew max platinum.
    I’m curious what offset would look best and sit just under flush with the fender flares. Looking for thoughts on wheel width and offset. I’m thinking 9 inch with +20 offset. Pics would be appreciated.
  2. Feb 2, 2021 at 7:06 AM
    Fastlane47
    Fastlane47 New Member
    Maryland
    2018 Platinum
    2012 tundra.jpg 2018 tundra 4.jpg My 2012 and my 2018 both are -44 offset
  3. Feb 2, 2021 at 7:08 AM
    18" TRD Off Road Wheels
    That's going to depend on what flares you are using. Some stick out more than others.
  4. Feb 2, 2021 at 7:10 AM
    Fastlane47
    Maryland
    2018 Platinum
    Sorry the 2012 is a -20 offset, the 2018 is -44
  5. Feb 2, 2021 at 7:20 AM
    BravoDeltaRomeo
    Bruce
    MB Canada
    2019 Cavalry Blue Tundra CM
    I believe stock is +60.
    roger280@gmail.[OP] likes this.
  6. Feb 4, 2021 at 1:34 AM
    roger280@gmail.
    Roger
    Thanks for the response guys. Hey Fastlane, do the tires stick out past the stock fenders? It looks like the do slightly. Hard to tell in the pics. I’m want something that will be about 1 1/2” past the stock fenders.
  7. Feb 4, 2021 at 2:53 AM
    jeremyd and roger280@gmail.[OP] like this.
  8. Feb 4, 2021 at 4:39 AM
    Fastlane47
    Maryland
    2018 Platinum
    On my 2012 just a bit, you can just see the tire tread. The 2018 has the 6in Honey D fenders and the tires stick out about a 1/4 inch. I would also call tire rack and tell them what you are looking for, they will ley you know how far the wheel and tire will stick out on the factory fenders. I think -20 will be what you what, but check with them.
