Anything missing from this part of the engine bay?
Discussion in '1st Gen Tundras (2000-2006)' started by Can Can, Feb 3, 2021.
  1. Feb 3, 2021 at 8:47 PM
    Can Can
    Can Can [OP] New Member
    Hello everyone!
    I'm looking at buying this 05 Toyota tundra limited double cab in the next few days. I was looking at the photos and noticed that in the far lookers upper right there is a fill bottle and some mechanisms (circled in red, also sorry I do not know what it's called and I do not know what it does). But from my experience, it looks like somethings missing and it also looks like it's an aftermarket piece. If you all could let me know if this is okay, or if this looks fishy it would be a great help! Thank you in advance! (Photo below)
  2. Feb 3, 2021 at 8:56 PM
    Can Can
    Oh boy, that's the brake fluid reservoir isn't it. Any help would be greatly appreciated!
  3. Feb 3, 2021 at 8:57 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    it’s the brake fluid reservoir. And it’s also the abs assembly all built into one
    Tundra2 likes this.
  4. Feb 3, 2021 at 9:11 PM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    What am I missing here...hard to tell from the picture but everything looks like it’s there, the usual grease shine on the parts except what you have circled though.
  5. Feb 3, 2021 at 9:15 PM
    empty_lord
    05 rollover special
    Yea looks like the normal crusty engine bay.. nothing to really see there.
    I’d be more focused on if the frames safe
    Rex Kramer likes this.
  6. Feb 3, 2021 at 9:30 PM
    Can Can
    Okay. I've just never seen a brake reservoir quite like that one there. But anyway thanks for the help, you guys! Yeah Ill be doing a thorough frame inspection
    empty_lord likes this.
  7. Feb 3, 2021 at 9:46 PM
    empty_lord
    05 rollover special
    Yea this style abs system is VERY expensive to replace if it fails. (2-3 grand) so be sure to test out the abs if you can. As in try to lock the wheels up
    hammeron and Stuck in the '00s like this.
  8. Feb 3, 2021 at 9:47 PM
    jerryallday
    jerryallday New Member
    Jerry
    Pasadena, Ca
    2006 DC SR5 V8 Grey
    One thing that is missing is the timing belt change sticker that goes on the air box after it has been replaced. Water pump get done at the same time. Should have been changed at 100k miles. Not sure how many miles the truck has but you should ask if it’s been replaced.
  9. Feb 3, 2021 at 9:51 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    In that pic the end of the master cylinder does look odd, as if there is a hole where something would mount at the end.
    speedtre and FirstGenVol like this.
  10. Feb 3, 2021 at 9:55 PM
    empty_lord
    05 rollover special
    Nope. That’s normal.
  11. Feb 4, 2021 at 4:51 AM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    Mine is stuck to the underside of the hood but I've seen them multiple places.
  12. Feb 4, 2021 at 5:41 AM
    Where is the brake booster that's normally mounted on the firewall?
    Jack McCarthy likes this.
  13. Feb 4, 2021 at 5:43 AM
    Also, not every place adds a sticker. I had my timing belt changed at the dealer and they didn't put a sticker anywhere.
    speedtre, Darkness and w666 like this.
  14. Feb 4, 2021 at 7:09 AM
    Pucks18
    Pucks18 Fleabit peanut monkey
    2001 Tundra 4x4 Limited trd
    I mean, I dont think it has to go on on spot and one spot only
  15. Feb 4, 2021 at 7:25 AM
    empty_lord
    05 rollover special
    Accumulator based. Not a regular braking system. All electronic
    FirstGenVol[QUOTED] and speedtre like this.
  16. Feb 4, 2021 at 7:38 AM
    speedtre
    speedtre New Member
    Inland Northwest
    @empty_lord ...is this what the VSC systems look like?
    OP....get the VIN, register it here and you can look at it's Toyota Dealer service history (or at least you may seem some there, it's not always recorded) and you can see all the options it had when new...
    https://www.toyota.com/owners/
  17. Feb 4, 2021 at 8:01 AM
    empty_lord
    05 rollover special
    On double cabs yes I believe
