2021 Tundra light clunk noise?
Discussion in '2.5 Gen Tundras (2014-2021)' started by Drifter5151, Feb 2, 2021.
  1. Feb 2, 2021 at 9:41 AM
    Drifter5151
    Drifter5151 [OP] New Member
    2021 Tundra SR5 crewmax
    I have a 2021 SR5 crewmax 4x4, about 1 out-of 5 times when accelerating from a stop there is a very light clunk noise. Sounds like it's coming from the bed area behind the cab. It does it on light acceleration but not every time.
    No modifications have been done..the truck has about 3000 miles on it.
    Anyone else ever have this??
    Any ideas what I'm hearing?
  2. Feb 2, 2021 at 1:05 PM
    SLA10
    SLA10 New Member
    2019 Tundra TRD Pro
    Believe it might be abs self testing brakes
  3. Feb 2, 2021 at 1:12 PM
    Drifter5151
    Thank you, I'm looking at some articles on this. Could possibly be it.
  4. Feb 2, 2021 at 1:44 PM
    Safar85
    Safar85 New Member
    Ed
    Corona, Ca
    2021 SR5 CM
    More than a few.....
    I have this too, if its a clunk sound from the front and its the ABS check, it should do it every single time when you turn on the truck and drive past 5 mph. This is completly normal, i hate it, but i am getting used to it. If you only hear it sometimes from the rear and it feels most like a bump in the back, i have this too, and think it may be a TSB related issue relating to the driveshaft at the rear diff, its intermittent. I will be having the dealership check it on my first oil change. My 21 currently has 1400 miles on it.
  5. Feb 2, 2021 at 2:37 PM
    chickunfut
    chickunfut Low-buck Ramp Truck
    Fort Worth, TX
    2007 Tundra Crewmax
    I used to have this and thought it was related to the driveshaft TSB. I inspected the rear end as recommended in the TSB and found nothing wrong.
    When I removed my rear leafs to install the rear lift, the passenger side leaf was binding on the bolts. There's no lube on the bolts and i believe when they release from being bound up, you feel a bump. My truck is a 2007 but it's had the bumping sensation since new.
    I never took the truck in for the driveshaft TSB and have not experienced the bumping sensation since replacing the leaf springs.
  6. Feb 2, 2021 at 2:45 PM
    tttrdpro
    tttrdpro Former Naval Person
    SWGA
    2024 GMC 2500 AT4
    In progress…
    It is the abs system doing a self test. Completely normal.
  7. Feb 2, 2021 at 2:55 PM
    Safar85
    Safar85 New Member
    Ed
    Corona, Ca
    2021 SR5 CM
    Do you think lubing it would help?
  8. Feb 3, 2021 at 5:37 PM
    Robster80
    Robster80 New Member
    Noticed it on my 21. Was like great. Wtf. Just my luck i get a lemon. Did some research and found its normal
    Drifter5151[OP] likes this.
