5.7L Transmission Cooler Kits
Discussion in 'Genuine Cooling Systems' started by Genuine Cooling Systems, Jan 19, 2020.
  1. Jan 24, 2021 at 2:02 PM
    #391
    ssls6
    ssls6 Dr. Awesome
    Richard
    South Park, CO
    2020 TRD Pro CM
    Bakflip, Bedstep, Gulfstate stuff
    What was the issue that caused you to call Hayden's customer service? I find your statements concerning.
    Bradleybb and sask3m like this.
  2. Jan 24, 2021 at 5:02 PM
    #392
    Genuine Cooling Systems [OP] New Member Vendor
    Grounding the horn will no longer require a ground cable. I'm going to be updated the instructions next week to include the new procedures of mounting it.
  3. Jan 24, 2021 at 5:05 PM
    #393
    No need to be concerned, this is just regarding becoming a dealer for their products.
  4. Jan 24, 2021 at 5:09 PM
    #394
    ssls6
    ssls6 Dr. Awesome
    Richard
    South Park, CO
    2020 TRD Pro CM
    Thanks for the clarification.
  5. Jan 24, 2021 at 5:14 PM
    #395
    Vizsla
    Vizsla 2 = 2.5
    Why do you no longer advertise stainless steel mounting brackets? I understand the new coolers are isolated, but what about everyone that bought the kit with the Hayden cooler and stainless steel bracket and fasteners with no isolation?
  6. Jan 24, 2021 at 5:53 PM
    #396
    Hayden doesn't offer vibration isolating brackets on any of their products.
    KC.Tundra likes this.
  7. Jan 24, 2021 at 6:26 PM
    #397
    Vizsla
    Vizsla 2 = 2.5
    Not talking about vibration, the no aluminum with stainless thing so you don’t get corrosion in the cooler.
    Saltyhero13 likes this.
  8. Jan 24, 2021 at 6:40 PM
    #398
    The bracket is powder coated and so is the Hayden cooler.
  9. Jan 24, 2021 at 6:45 PM
    #399
    Vizsla
    Vizsla 2 = 2.5
    Powder coating is not an excuse for selecting the wrong materials. Good luck!
  10. Jan 24, 2021 at 6:48 PM
    #400
    Good luck with what? I don't use stainless in the brackets. The hardware is stainless, yes.
  11. Jan 24, 2021 at 6:51 PM
    #401
    Vizsla
    Vizsla 2 = 2.5
    Everyone on here with your Hayden kit has a stainless steel bracket?
  12. Jan 24, 2021 at 6:51 PM
    #402
    No.
    Vizsla[QUOTED] likes this.
  13. Jan 24, 2021 at 7:24 PM
    #403
    sask3m
    sask3m New Member
    Alberta
    Black 2019 SR5
    Vizsla likes this.
  14. Jan 24, 2021 at 7:27 PM
    #404
    I used aluminum when I was designing the 777. 778 brackets were .93" cold rolled steel. MHX and Setrab use .125" cold rolled steel.
    sask3m[QUOTED] likes this.
  15. Jan 24, 2021 at 7:34 PM
    #405
    Also, I've designed a MHX bracket that will fit on 2014-2018 year Tundra's. It will be a couple weeks until it is test fitted to work in conjunction with the factory cooler on top of the condenser.
    I'm looking for a 2019+ magnuson superchargered Tundra to install the MHX bracket/kit on their truck. PM me for deatails. Discount included.
  16. Jan 24, 2021 at 7:36 PM
    #406
    sask3m
    sask3m New Member
    Alberta
    Black 2019 SR5
    Yeah steel was what I used for the bracket to mount my B&M. I want to now get some of those rubber mounts that TXBrit used, not sure if they're necessary but can't hurt I guess.
  17. Jan 24, 2021 at 7:51 PM
    #407
    Vizsla
    Vizsla 2 = 2.5
    So nobody got the stainless bracket cooler combo?
  18. Jan 24, 2021 at 7:55 PM
    #408
    Jmn
    Jmn New Member
    :popcorn::spending:
    will have to get one at some point! thanks for working of the full kit again, that's a stress saver :)
  19. Jan 31, 2021 at 6:06 PM
    #409
    JEHTUNDRA
    JEHTUNDRA New Member
    2021 Crewmax SR5 4x4
    Is there going to be a new install video with the MHX and Setrab kits?
  20. Jan 31, 2021 at 6:11 PM
    #410
    Not at this time. If the current instructions are not clear I can fix them. Also, the current install video covers most of the install since the instructions to install all the parts to the hard lines are going to remain the same.
    KC.Tundra and JEHTUNDRA[QUOTED] like this.
  21. Feb 3, 2021 at 2:16 PM
    #411
    19PlatinumCrew
    19PlatinumCrew New Member
    Dave
    MGM 19 Platinum Crew
    Toytec 3" coilover lift,295/75/18 on Method Nv,Nitto tires,Retrax cover,spray liner.
    Nick...If I wanted to upgrade to the MHX from the Hayden 778 that I purchased from you what would I need and what would it cost ?
  22. Feb 3, 2021 at 2:49 PM
    #412
    Sent a PM.
  23. Feb 3, 2021 at 2:51 PM
    #413
    For those who have purchased a Hayden kit in the past, I will offer you a $100 discount for the MHX and $80 discount for the Setrab partial kits if you would like to upgrade.
    Lake.Life24 likes this.
  24. Feb 3, 2021 at 3:05 PM
    #414
    Lake.Life24
    Lake.Life24 New Member
    Shawn
    Upstate, NY
    2021 GMC Sierra 3500HD Gasser
    That is good to know. I have the Hayden kit and have towed/hauled near max capacities for about 4,000 miles and my temps never got over 208. And one trip I was probably over the max towing. Everything seems to be working fine.
    Do you think I should upgrade to the newer coolers?
  25. Feb 3, 2021 at 3:10 PM
    #415
    19PlatinumCrew
    Dave
    So 929 for a new MHX kit....
  26. Feb 3, 2021 at 3:44 PM
    #416
    $539 for the partial kit with the discount.
  27. Feb 3, 2021 at 5:18 PM
    #417
    Mad Max
    Mad Max New Member
    Max
    2021 Tundra Limited
    I have the Hayden cooler and have ZERO concerns over any mechanical integrity issues. It's every bit as robust as the Toyota radiator used in the Tundra. Too funny the dissimilar metal concerns, a little knowledge is a dangerous thing. I have been extremely satisfied with my install using the Hayden cooler. I have yet to see trans temp over 198F with any of my towing adventures. I never see trans temp below 188F after the transmission reaches steady state. The package works flawlessly.
    Let's say you spring a leak in ANY transmission cooler. It will most likely be a pin hole leak spraying transmission fluid everywhere. The odor will be the first indication there is an issue, smoke will be the next from the fluid hitting hot engine components. If you aren't perceptive enough to pull over at that point then something will take your truck out before the trans cooler, lol.
    I do not see any advantages of the "heavier coolers". Then again some people drive 1 ton trucks that don't tow anything.
  28. Feb 4, 2021 at 3:23 AM
    #418
    Bammer
    Monroe, CT
    Agreed, no concerns or worries with the Hayden. Stay Calm & Tow On !
  29. Feb 4, 2021 at 3:36 PM
    #419
    Drainbung
    Drainbung Some days you are the show...
    Bob
    Oasis of NV
    2019 Cement DCLB 4X4
    TRD Fleshlight
    Sub'd
    I think this will be the first mod as soon as take possession of the truck.
  30. Feb 4, 2021 at 4:28 PM
    #420
    Ruggybuggy
    Ruggybuggy Seasoned Veteran
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Only do it if you require it. If your not towing heavy often you don't need it.
    Drainbung[QUOTED] likes this.
