Door lock switches do nothing
Discussion in '1st Gen Tundras (2000-2006)' started by POC, Feb 3, 2021.
  1. Feb 3, 2021 at 10:06 AM
    POC
    POC [OP] New Member
    Patrick
    Indiana
    2006 SR5 Crew Cab 4x4
    My 2006 crew cab, the door lock buttons don't do anything. If I lock a door by hand then open a door with the key in the ignition it does unlock the doors.
    So I don't think it would be a fuse, but I have looked at the owners manual and checked all the ones I thought might have something to do with them.
    ETA: After a little more messing, the window switches on the driver's door don't work either. This is my wife's truck I don't drive it often.
    So I'm guessing there are some broken wires somewhere.
    Any suggestions?
    Thanks
  2. Feb 3, 2021 at 11:58 AM
    There's contacts in the switches that can wear over time as well. I've read of some replacing the switches. Could be as simple as a loose connector. Needs some diagnostic inquiry performed on it. Pull the switch and inspect.
    POC[OP] likes this.
  3. Feb 3, 2021 at 1:38 PM
    Rotaryphoneuser
    Rotaryphoneuser New Member
    Ontario. Canada
    2018 Cement CrewMax
    Time to take the panel off and poke it with the multimeter.
    POC[OP] likes this.
