2021 SR5 Driver Seat Recline
Discussion in '2.5 Gen Tundras (2014-2021)' started by RilerOfDogs, Jan 31, 2021.
  1. Jan 31, 2021 at 3:24 PM
    RilerOfDogs
    RilerOfDogs [OP] New Member
    Ohio
    2021 SR5
    Hi. The roadside of the driver seat in my truck has three switches listed from front to back:
    #1. Slides the seat fore and aft.
    #2. Reclines the seat.
    #3. Blows up an air bladder (I assume) for lumbar support.
    The truck is new (+/-500 miles) and I haven't been able to get #2 to recline the seat. Nothing happens when the switch is moved. Is there some function somewhere that I've disabled the switch maybe? I've checked the manual and don't find anything helpful. I looked underneath and all the connectors seem to be seated properly. Nothing seems out of place.
    I don't want to look like a moron taking this thing back to the dealer to find out
    it's a setting or a check box in the menu that I inadvertently clicked or something easy like that.
    Thanks in advance for the help- Bill
  2. Feb 2, 2021 at 6:16 AM
    KingsAustin
    KingsAustin Grey Goose II
    Morgan County, AL
    2021 Limited Night Shade
    BakFlip MX4, Gator All Weather mats, Console Safe, Ceramic Tint, Roadmaster Active Suspension, Interior/exterior LED conversion, Wireless console charger, AJT designs.
    I would reach out to your sales agent and explain the situation. You will probably have to take it in for an eval. I had an issue as well and the sale agent helped me out. BTW, have you check the fuses??
  3. Feb 2, 2021 at 6:34 AM
    Gene5253
    Gene5253 New Member
    Gene
    Boise ID
    2020 Tundra CM Limited
    Assuming if it was a fuse none of the functions would work??
  4. Feb 2, 2021 at 6:43 AM
    KingsAustin
    Morgan County, AL
    Not sure. I hope it can easily be resolved.
  5. Feb 2, 2021 at 6:59 AM
    BravoDeltaRomeo
    Bruce
    MB Canada
    2019 Cavalry Blue Tundra CM
    **edit**
    Just pop by a dealer, don't mess with any wires or fuses. It's brand new.
  6. Feb 2, 2021 at 7:01 AM
    18" TRD Off Road Wheels
    It could be a loose or disconnected wire under the seat. I'd take a peak at that.
  7. Feb 3, 2021 at 7:05 AM
    Gene5253
    Gene5253 New Member
    Gene
    Boise ID
    OP says he did that
  8. Feb 3, 2021 at 9:33 AM
    Oops. Missed that.
