Best rear Dif fluid to use
Discussion in '1st Gen Tundras (2000-2006)' started by Motopilot, Feb 2, 2021.
  1. Feb 2, 2021 at 10:08 AM
    Motopilot
    Motopilot [OP] New Member
    Josh
    NC/FL
    2017 Tundra crewmax 4x4 Platinum edition
    2” level 285/75R17 Falken wild peak RT 34.1”x11.5” bilstein 5100
    Gonna change my rear differential oil this weekend on my 05’ DC 4wd. Any opinions on best one to use? It’s probably never been changed (175k miles) also hope to do the front and transfer case oil as well. Btw I live in Florida so not cold here.
    I feel like I need to change the tranny as well (due to age and miles) but it shifts butter smooth. I do drive like a old man and never tow. All opinions and suggestions welcomed.
  2. Feb 2, 2021 at 10:20 AM
    Motopilot[OP] likes this.
  3. Feb 2, 2021 at 10:50 AM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
  4. Feb 2, 2021 at 10:52 AM
    bft305
    bft305 New Member
    2016 tundra limited
    GAknight and Motopilot[OP] like this.
  5. Feb 2, 2021 at 10:57 AM
    Rear diff fluid is 75/90, I used Royal Purple synthetic which I got on sale for 12.99/qt. Took 3 or 4 qts for the rear, 2 or so qts for the transfer case and 2 or so for the front diff. Think I bought 7 or 8 total but it's been awhile so don't quote me there. I would do all three if they've never been done, but my transfer case and front diff looked like new fluid when I drained it. The rear looked and smelled like crap. Old dino oil was in there. The synthetic fluids do not suffer the same thermal breakdown issues as the dino oil. Much better at long life use and only need to be replaced if they get water in them or get dirty.
    Transmission can be drained and filled resulting in about half the fluid getting swapped for fresh. It's harmless and keeps the transmission with a fresh supply of additives. They are "sealed" in that they are not exposed to air, or combustion and thus the fluid doesn't so much get dirty as it suffers from thermal breakdown over time. Your 05 with the 5 speed is also sealed in another sense I believe. The process to exchange and refill the fluid is much more tedious than a drain plug and a refill through the dipstick (which yours does not have). Should you mess with the transmission fluid in a sealed transmission? let the debate begin. If it's my truck, I would. I would be leery of a transmission flush at 175k if it's never been done and you are not experiencing problems. If it's my truck, I would not personally do that.
  6. Feb 2, 2021 at 11:27 AM
    Motopilot
    Josh
    NC/FL
    @KNABORES lol yeah wasn’t trying to open a can of worms on that question. I’ve heard both camps arguments. That’s why I added mine shifts butter smooth.
  7. Feb 2, 2021 at 1:44 PM
    Professional Hand Model
    Fred
    Hand Protectors
    ick23 and Motopilot[OP] like this.
  8. Feb 2, 2021 at 1:47 PM
    Motopilot[OP] and Darkness like this.
  9. Feb 2, 2021 at 2:11 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    ^ the Toyota LSD calls for dino oil. I also run Lucas in mine.
    Somebody posted some test results that didn't go well for royal purple (or Lucas Synthetic) but I don't know how much those tests relate to real world use. Those tests favored Valvoline and Mobil did okay.
  10. Feb 2, 2021 at 2:13 PM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    huh weird...I thought I remember reading to use Royal Purple and thats what I did. Been fine for about 11K miles so far.
  11. Feb 2, 2021 at 2:15 PM
    Fred
    Hand Protectors
    You must have red that in the Turd Gen Section. I’d drain and re-fill with Lucas. :boink:
  12. Feb 2, 2021 at 2:16 PM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    haha.
  13. Feb 2, 2021 at 2:17 PM
    I ran Royal Purple in my front Diff and T Case for a few years without issue but they specifically called it out as the worst.
  14. Feb 2, 2021 at 2:18 PM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    yeah i saw that too...
    dammit.
  15. Feb 2, 2021 at 2:21 PM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    I've never been a fan of them, mostly because I think the purple is a gimmick, but to be fair I never used it either.
    Not the same results posted before, this is data from Amsoil so possibly biased. I guess I'm confusing valvoline for Castrol, but Royal and Lucas did pretty bad here. Again, not sure how much this data relates to real use.
    http://ultimatesyntheticoil.com/stop-differential-failure
    Motopilot[OP] and CodyP[QUOTED] like this.
  16. Feb 2, 2021 at 2:24 PM
    @CodyP I'm sure running R.P won't hurt anything for a while. I would just make a point to use something else next time. They said the best approach is to just change the fluids regularly.
    Motopilot[OP], Darkness and CodyP like this.
  17. Feb 2, 2021 at 2:25 PM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    yeah, maybe I'll change at 15K instead of the 30K this time
  18. Feb 2, 2021 at 2:30 PM
    PlatinumPro
    PlatinumPro New Member
    2015 PlatinumPro Crewmax
    Bilstein 6112+5100s, Rigid Lighting, Fuel 20x9 Bronze Blitz
    :smash: i've put royal purple in my quad diffs since 2013. :annoyed:
    Lucas oil from here on out.
  19. Feb 2, 2021 at 2:48 PM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    I agree with @FirstGenVol that the most important thing is frequent changing. I only run Lucas because its hard to find dino oil in the 80-90w. If I were going synthetic I would go Amsoil or maybe Redline. I run Amsoil in my GTI transaxle, it started shifting like butter after the first day.
    I'm not sure why Toyota recommends dino for the LSD. I know it has to do with the clutches but I can't think that a synthetic fluid can't mimic a dino fluid for that.
