Softer ride?
Discussion in 'Suspension' started by PonyMan, Feb 1, 2021.
  1. Feb 1, 2021 at 7:43 PM
    PonyMan
    PonyMan [OP] Old Man
    Central, Louisiana
    2021 Tundra CrewMax 4WD Limited Nightshade Special Edition MGM
    Hey guys, so which shocks offer a SOFTER ride? - the TRD off road yellow/blue or the Sport red/blue?
    (not my pic)
  2. Feb 2, 2021 at 3:51 AM
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
    Bilstein claims that the HD Yellow & Blue are the smoothest riding shocks they make for these trucks.
  3. Feb 2, 2021 at 3:59 AM
    PonyMan
    Central, Louisiana
    Thanks guys!
  4. Feb 2, 2021 at 5:27 AM
    bmc02
    bmc02 New Member
    Buddy
    E WA
    05 DC SR5 / 06 SEQUOIA LTD
    Sport usually means cornering and speed which needs tighter suspension. So agreed off road ones would be softer.
  5. Feb 2, 2021 at 6:36 AM
    UTAHRTK
    UTAHRTK New Member
    SOCAL
    2017 MGM Tundra TRD CM
    Dirty Deeds 8" standard exhaust, King 2.5's/Bilstein 5160's, Built Right UCA,s, Method 701's, TOYO ATIII 35x12.5x17, TRD LED headlights, Pro Grill
    I switched to 6112/5160, 17" wheels and larger E load rated tires. Ride is firm- I conducted chalk test several times and have adjusted tire pressure- surprised at the difference a few PSI makes - ride is sweet!
    Chucho and PonyMan[OP] like this.
  6. Feb 2, 2021 at 7:29 AM
    Sport ones are tuned for cornering (as much as reasonable in a big ol' truck) so they are going to be stiffer to stay planted. The OR are designed to soak up bumps off the pavement. My truck has them stock, and I wouldn't say they are the smoothest thing ever, but they do a good job.
    Another thing that will soften your ride is your tire type and wheel size. 18" wheels will have more cushion than 20" because of the additional sidewall. A passenger or street tire is generally going to ride softer than your AT or other more aggressive tires.
    Oey12 likes this.
