2021 average mpg reset
Discussion in '2.5 Gen Tundras (2014-2021)' started by Redsarman, Feb 1, 2021.
  1. Feb 1, 2021 at 8:14 PM
    Redsarman
    Redsarman [OP] New Member
    2021 limited
    Ok so I must have missed the boat. How do you reset average mpg screen on a 2021 limited?
  2. Feb 1, 2021 at 9:05 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    I don’t think you can. It just auto resets when you fill up. It’s pretty annoying.
  3. Feb 1, 2021 at 9:18 PM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    Depends on what setting you have it set to. There is the TANK average (which is how the truck is set up when you buy it, and resets every tank), and there is the overall, which is a setting you can change in the setup of the dash display settings. Then, there is the “ECO” history setting in the head unit, which I’ve not really spend much time playing with.
    As for resetting it, I know that pulling the negative battery terminal does a good job of resetting that data (and telling me I’ll get 600 miles on my next tank of gas!).
    20Tundra_sauce21 likes this.
