2007 5.7 Tundra Transmission the same as 2008?
Discussion in '2nd Gen Tundras (2007-2013)' started by NewTundra4X4, May 27, 2019.
  1. May 27, 2019 at 1:02 PM
    NewTundra4X4
    NewTundra4X4 [OP] New Member
    T
    2007 Tundra 4X4
    I have a 2007 Tundra 5.7 4x4 with newer body style that has a bad transmission. Can I put in a 2008 4x4 5.7 transmission?
  2. May 27, 2019 at 1:59 PM
    Trooper2
    JR
    Houston, TX (Suburban South)
    Should work.
  3. May 27, 2019 at 3:27 PM
    Dr_Al
    Dr_Al New Member
    Al
    Do you know what's wrong with the transmission?
    Smiley likes this.
  4. May 27, 2019 at 4:01 PM
    NewTundra4X4
    T
    2007 Tundra 4X4
    transmission does not shift and redlines
  5. May 27, 2019 at 4:15 PM
    You can. Have you had your current tranny diagnosed?
  6. May 27, 2019 at 5:00 PM
    NewTundra4X4
    T
    2007 Tundra 4X4
    yes they said transmission needs a rebuild
    Black Wolf likes this.
  7. May 27, 2019 at 5:02 PM
    Find the lowest miles wrecked 07 and up and swap it in
    LuvniForce likes this.
  8. May 27, 2019 at 5:06 PM
    NewTundra4X4
    T
    2007 Tundra 4X4
    thanks! I found one out of a 2008 tundra 4x4
  9. May 28, 2019 at 3:46 AM
    Dr_Al
    Dr_Al New Member
    Al
    I'm not saying they aren't right but what makes them sure that it's a bad transmission? Did they give you details? There's several issues that could cause that. A bad solenoid in the valve body. The heat exchanged could have gone bad mixing radiator coolant with trans oil. Low fluid level. If you're sure that the shop did an adequate job diagnosing the problem then replace the transmission. Unless you are planning on doing the work I would expect replacing a transmission to cost $4k or so.
  10. May 28, 2019 at 3:54 AM
    NewTundra4X4
    T
    2007 Tundra 4X4
  11. Feb 1, 2021 at 6:24 AM
    07Tundra93
    07Tundra93 New Member
    07 Tundra Limited 5.7L 4WD
    Were you able to swap the 08 transmission into your 07 successfully?
