2015 nsv light bar
Discussion in 'Lighting' started by Talal78, Jan 5, 2021.
  1. Jan 5, 2021 at 9:42 AM
    Talal78
    Talal78 [OP] New Member
    Talal
    Kuwait
    2015 tundra 1794
    Kings 2.5 shocks Total chaos UCA Kings pump stop Method wheels Cooper tires Rigid lights
    Hello guys
    New member here
    i installed my gen2 NSV light bar couple of days ago and lost my back tail lights i changed the fuse several time with no luck !!
    I disconnected the harness going to the front light and all worked fine !!
    I have the 2018 headlights with headlight revolution harness
    Any idea on how to work this out ?? Should i re-pin the turn signal to stock ? Or should i redo the nsv light bar harness?
    Also anyone know how to get the strop function back ?
  2. Jan 8, 2021 at 4:54 PM
    Talal78
    Talal
    Kuwait
    2015 tundra 1794
    Pump up
  3. Jan 31, 2021 at 10:13 PM
    Scud
    Scud New Member
    San Francisco Bay Area
    2017 1794 Tundra Super White
    Working on it :-)
    I have a similar setup as you. 17 1794, 18 LED HL's with iHacker harness. I have gen 2 NSV bar and have both dimming DRL's and strobe working now on the lightbar. Not sure about your taillight issue but maybe snap some photos of your wiring/connectors and I can compare with mine.
