Cavernous Crewmax DIY underseat storage
Discussion in '2.5 Gen Tundras (2014-2021)' started by BrakeDust, Jan 31, 2021.
  1. Jan 31, 2021 at 7:00 AM
    BrakeDust
    BrakeDust [OP] New Member
    Hill Country, TX
    2021 CM SR5 4x4 Magnetic
    Built my own backseat storage for my 2021 Crewmax. The hardest part was cutting into a brand new vehicle but I needed the space.
    Combined two ideas from this forum:
    - A hard frame that follows the perimeter of the seat
    - Sunken steel dishes to serve as storage bins
    Advantages:
    - Space is maximized since there are no dividers, spacers or bezels
    - Cost is minimal compared to commercial offerings
    - Very easy to do, no need to cut the metal seat bars under the felt
    The Frame:
    - 52.5" width, 12.5" depth, 2" high, 0.75" frame thickness. I used oak, pine would save money. (Ripped a nominal 1x3 oak plank, resulting size 0.75" x 2")
    - The side posts butt up against the seat mounts on each end with a 0.5" relief cut to allow them to side flush against the seat mount flange and also the floor
    - A piece of aluminum 1.5" x 19" long permits the frame to be bolted to an existing unused hole located within the end seat mounts. No drilling required (except of course in the aluminum bar.)
    The Bins:
    - Purchased two full size 2.5" deep steam trays, one half size tray
    - The driver's side tray fit perfectly between the seat mounts
    - The middle tray is somewhat long and I encountered a metal bar under the foam toward the back. Ended up having to cut a small relief hole in the tray. We are limited by the seat belt mount in the floor, otherwise the tray could have been moved to the other side of the space.
    - The passenger side half size tray fit perfectly. In the back we have the factory jack storage in the way but the tray does not interfere.
    Imgur is giving me trouble with uploads, will add pics of the build later
  2. Jan 31, 2021 at 7:05 AM
    memario1214
    Colton
    Missoula, MT
    '21 Limited MGM CrewMax
    I like this a lot!
    Corndog123 and mcharfauros like this.
  3. Jan 31, 2021 at 7:06 AM
    BrakeDust
    Hill Country, TX
    The frame when it is not bolted to the seat brackets
    Yes, it's big enough to hold an AR15. The seats are 'hollow' underneath and the charging handle only sticks out about a quarter inch above the frame. You could fit something much larger there if needed.
    Bracket detail. The frame is 2" high, the aluminum bar is 19" long and extends to the seat bracket.
    Note the 0.5" relief cut that allows the end of the wooden frame to sit both on the floor and the seat bracket flange.
  4. Jan 31, 2021 at 7:21 AM
    BrakeDust
    Hill Country, TX
    The bins:
    - Two 'full size' 2.5" deep steam pans. Amazon.
    - One 'half' size steam pan
    - Painted flat black
    Cutting:
    - Removed seats, there will be residual outlines of the brackets pressed upon the fabric for reference
    - Marked all outlines with a fabric grease pencil
    - Used the inside edge of my frame as reference
    - Placed the bins between the brackets and butting up against my frame
    - Traced the outside of the bottom of each bin. Do not cut along this line, the trays will not fit.
    - Added 0.5" margin and traced another outline (curve each corner.) This is your cutting line.
    - The trays have a 0.75" lip on all side so you'll end up with a snug fit for the tray and and overlapping tidy finish
    - Use a sharp shop knife, the carpet and underlying 0.5" thick fluffy material cut easily
    - I used a Cutco avocado knife to cut out the 2.5" thick styrofoam. Some use a carpet knife or steak knife.
    Note: Here's the pipe I encountered under the foam of the middle area. Either get a smaller bin, change your design to move the bin 2.5" toward the front of the truck, or cut the bin as I did.
    I took the fluffy material from each carpet piece and placed it under the bins for stability. The remaining top layer of the carpet went back into the bins after trimming. This also covered up the relief cut I made into the middle bin.
  5. Jan 31, 2021 at 7:40 AM
    Rocko9999
    Rocko9999 New Member
    I would add some sound deadening under those bins as they would amplify road noise-like a speaker.
    bulldog93 and Akaklutz like this.
  6. Jan 31, 2021 at 8:04 AM
    BrakeDust
    Hill Country, TX
    There is a 0.5" layer of the factory sound insulation under each bin. You'll see it if/when you tear up your carpeting.
    There is no noise difference as far as I can tell, my passengers can't tell a difference either. (FWIW I now have a thick layer of cargo in there as well)
  7. Jan 31, 2021 at 8:10 AM
    BrakeDust
    Hill Country, TX
    What I keep in the back:
    - Two pairs of gloves (one thick, one thin)
    - Socket set, screwdrivers, wrenches, pliers, hammer
    - Duct tape
    - Full roll of paper towels
    - Pack of wet wipes
    - Flashlights, zip ties
    - Can of tire seal/inflator
    - Mid-size fire extinguisher
    - 1st Aid kit, large box of band-aids
    - Two kinds of rope/string
    - About 6 sets of tie-downs
    - Emergency rations
    - Bottles of water
    - Jumper cables
    - Costco soft freezer bag
    - Two umbrellas (one full size, one compact)
    - Space blankets
    - Regular blanket
    - Small folding shovel
    Still need to add some kind of tow strap
  8. Jan 31, 2021 at 8:13 AM
    C.I.
    C.I. Surf, off road, sleep, repeat
    Cesar Pedrin
    Cabo, Mx
    2016 5.7 4x4 Bronze Crewmax
    Mods: Ongoing... probably never ending
    nice quick build!:thumbsup:
  9. Jan 31, 2021 at 11:44 PM
    Jonnynewton909
    Jonnynewton909 Jonnys_Tundra
    Jonny
    East Texas
    2017 Tundra CrewMax
    Accutune Fox DSC 2.5 front w/ SPC UCAs, Alcan custom spring pack and Accutune Fox DSC 2.5 rear. 37 Toyo RT Trails on Method 312s. SOB Fab F&R high clearance bumpers. AT Overland Atlas.
    Nice build. Any pictures of the relief cut for reference?
    Instead of scooting that particular tray towards the front, could it be shifted towards the passenger side? I see a cut in the carpet there not sure if that's where something bolts down or what???
    Not around my truck to go look.
  10. Feb 1, 2021 at 3:48 AM
    Bammer
    Monroe, CT
    Very nice ! :thumbsup:
  11. Feb 1, 2021 at 4:15 AM
    TXTundra2722
    2015 Black Tundra
    Great job! I've held off on buying the ESP storage and like the idea of going this route. Any rough estimates on total cost for this build? Where did you get the side aluminum pieces?
    GODZILLA likes this.
  12. Feb 1, 2021 at 5:35 AM
    Djone27
    Djone27 New Member
    2017 MGM Crewmax TSS 4x4
    HID Headlights, full LEDs, TRD front and rear sway bars, CB +2s, Eibach Stage 2s, SABM w/ pro intake tube
    Very nice! This might be my next weekend project.
  13. Feb 1, 2021 at 6:20 AM
    BrakeDust
    Hill Country, TX
    Partly covered by carpeting:
    This is the size of the cut in my tray:
    - Measure 1.5" from the top of the tray and mark the side (this will be the 'top' of the cut)
    - Measure 2.5" from the end of the tray and mark (the 'end' of the cut)
    - Make the cut 1" deep, from the long edge of the tray
    This should yield a 1x1x2.5 rectangle to be removed. At first I tried to just beat a dent into the tray with a ball peen hammer but the stainless steel is pretty tough.
    Yes, but you'd overlap with the seatbelt mount. I think it could be done since the seatbelt has an "L" shaped bracket that is not indexed, thus you could loosen the bracket and swivel it around to face the left (and tighten back down.) Then the tray could sit directly over it while still allowing the seatbelt to sneak past the lip. I'd make sure to provide about a half inch clearance so the belt isn't rubbing against the tray.
    If I were to do it again I'd definitely try to move the tray around to make it all fit before making any cuts. I had no idea I'd find a pipe under the foam, previous builds haven't mentioned it but I did see it in one of the pics where someone ripped out _all_ the carpet and foam as part of a different project. Now we know where it is, LOL!
    The wood, aluminum and hardware was all from Home Depot. I didn't sand or scuff up the aluminum prior to painting but I think would have been a good move, it's pretty slick. My frame is easy to pop off for painting if needed, I used black Allen bolts with a little knurling on them, the mounts are just finger tight (ie. the end that connects to the existing factory bolt holes found in the chair brackets.)
    Cost:
    - Oak = $30 (would be $4 with clear pine or poplar, just rip a half inch strip from the width of a 1x3 board and you'll end up with 0.75x2 actual size)
    - Aluminum maybe $10, I went with 19" strips on both ends but you could get away with shorter pieces, even 6" if you wanted
    - Hardware = $10, but could be free if you use stuff laying around in your garage
    The bins were $11 for the small one, $20 for each large one from Amazon. Someone provided links to Sam's Club where they had 2-packs of the large bins for $22, but I'm not a member.
    Total could be around $70 if using pine and less aluminum, I probably spent close to $100. If you use scrap materials in your garage then it's just $50 for the bins. Oak provided a good look and excellent durability, that's why I used it.
    Corndog123, TreeCat, GODZILLA and 4 others like this.
  14. Feb 1, 2021 at 4:08 PM
    Djone27
    Djone27 New Member
    @BrakeDust - Would the 4" deep steam pans fit?
  15. Feb 1, 2021 at 4:13 PM
    Kanobi13
    Kanobi13 New Member
    Nice!! Did this years ago best mod i have done
    Corndog123 likes this.
  16. Feb 1, 2021 at 4:14 PM
    18" TRD Off Road Wheels
    If I didn't have an ESP system sitting at home I would definitely be down for this one! Great mod!
    Corndog123 and Tundra_Curt like this.
  17. Feb 1, 2021 at 6:34 PM
    BrakeDust
    Hill Country, TX
    Yes, but then you must add a 1.5" bezel around it to cover the projecting lip. The styrofoam is about 3" thick in most places and tapers off to about 2.5" at the back. Many people have 1.5" thick sheet/board in the area under the seat and sunk their 4" pans. I didn't want to lose the extra space.
    TreeCat likes this.
  18. Feb 1, 2021 at 6:40 PM
    Djone27
    Djone27 New Member
    Got it, thanks for the explanation. Was just curious since the ESP one is 4".
  19. Feb 2, 2021 at 5:05 AM
    BrakeDust
    Hill Country, TX
    The ESP version comes with the bezel included. It's a nice turn-key solution but the plastic version doesn't offer very much space IMO. The gun safe is much larger but requires very extensive surgery to the vehicle - and it's very expensive.
  20. Feb 2, 2021 at 6:04 AM
    Hugemoose
    Hugemoose New Member
    Philly
    2016 Tundra Crewmax
    Not enough....
    Awesome job! I might have to steal this exact design once we don't have a foot and a half of snow on the ground.
  21. Feb 2, 2021 at 6:16 AM
    YotaBro
    YotaBro This forum will make me broke
    Calvin
    FL
    2017 Cement Grey Tundra TRD PRO
    Lots of shenanigans.
    That's super smart to use the steam pans! Never would have thought of that! Looks great!
  22. Feb 27, 2021 at 9:51 PM
    LisaPrice
    LisaPrice New Member
    Lisa
    Pismo Beach, Ca
    2000 Toyota Tundra
    None YET
    “Still need to add some kind of tow strap”
    Might I suggest a Freedom Recovery Rope? Not sure if I’m allowed to share the link here so if you want it just ask and I’ll provide it. They are awesome kinetic ropes with soft shackles that are exceptionally effective.
    I was actually looking for ideas on how to store mine when I stumbled across this thread. Great storage ideas! I think I’m going to follow your lead and implement this in my first gen Tundra.
  23. Feb 27, 2021 at 9:58 PM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    Share away Lisa. That’s part of how we all end up :spending: over new mods!
    Corndog123 and thedoodab1des like this.
  24. Feb 27, 2021 at 10:07 PM
    LisaPrice
    Lisa
    Pismo Beach, Ca
    2000 Toyota Tundra
    None YET
    Thanks! I’m brand spanking new here and didn’t want to piss anybody off LOL!
    www.freedomropes.com
    These things are amazing! The company is local to me here in Oceano, Ca (Pismo Dunes) and use kinetic energy in a highly efficient manner. I love the soft shackles; no rub or wear from metal connections and they store in a nice soft, lightweight custom bag. So glad I ran across the owners on the beach one day; they work great!
    Corndog123 and bulldog93 like this.
  25. Mar 1, 2021 at 7:44 AM
    dorton
    dorton #RockCreekOverland
    North Carolina
    2020 Black Tundra SR5
    CBI Off Road Front Bumper, Rock Sliders, Skids, and Bed Rack. Prinsu Designs Roof Rack, CVT Hybrid Rainier Tent, Old Man Emu lift, Fuel Vectors, Yokhama 305/70r18s
    Very cool post @BrakeDust
    Thanks for sharing!
  26. May 9, 2021 at 8:52 AM
    Tundra-Canuck
    Tundra-Canuck New Member
    Les
    2014 Crewmax
    Bags, command air, flares, light bars, titan tanks
    Great idea for sure. I've pondered doing this before. The link to the "Steam pans" doesnt work, so could you supply some dimensions? Thanx. Im going to do this for the extra storage under the seats.
  27. May 18, 2021 at 4:16 PM
    Claystundy805
    Claystundy805 Beachbum805
    Clay
    White 2016 Tundra TRD/Limited
    Thanks for sharing, I’m going to try this
  28. May 25, 2021 at 5:46 AM
    Evictor
    Evictor New Member
    Anybody know what that tube is?
    Anybody have a pic of the smart key antenna wire to see if this mod is possible before I start cutting.
  29. Sep 2, 2021 at 4:55 PM
    Bentarm13
    Bentarm13 New Member
    I went with the ESP. Total time spent 40 minutes. Would have gone quicker but I was so worried about the wiring for the smart key that I just kept creeping up on it with the knife. Very happy with it, much more expensive than the OP design I’m sure..
  30. Sep 2, 2021 at 4:57 PM
    Bentarm13
    If you are cutting the middle section, the sensor is in the front right corner if you are staring straight down at the hole. Remove 6-7 inches from the left and start working your way towards the drivers side.
    thedoodab1des and bulldog93 like this.
