Accessory Switch Question
Discussion in '2.5 Gen Tundras (2014-2021)' started by RilerOfDogs, Jan 30, 2021.
  1. Jan 30, 2021 at 1:11 PM
    RilerOfDogs
    RilerOfDogs [OP] New Member
    Ohio
    2021 SR5
    I have a 2021 SR5 and I would like to find either an aftermarket switch that matches, or the part number from Toyota to put a momentary contact switch in the slot highlighted in the photo. Any suggestions? Thanks - BilTundra Switch.jpg l
  2. Jan 30, 2021 at 2:55 PM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    A switch for what? Define that and suggestions will start rolling in ;)
    RilerOfDogs[OP] likes this.
  3. Jan 30, 2021 at 3:28 PM
    Contact CH4x4. You want the Toyota small switch. You will see it on their site.
  4. Jan 30, 2021 at 3:42 PM
    biebs96
    PA
    That blank is for the power rear window switch. So a small sized Toyota switch will fit nicely.
    also, might want to considering turning your headlights closer to the 1,0 mark.
    You’ll probably see much better at night..
    RilerOfDogs[OP] and HulkSmurf14 like this.
  5. Feb 2, 2021 at 2:39 AM
    El Two
    El Two I’m only talking to my dog today.
    Lisa
    2018 SR5 Crewmax TRD Off Road
    How much time do you have? . . . . . . . . . . . . . . . . . . . . .......... Eaton rear eLocker, Camburg 1.5” shackles, Rear Seat Delete, S&B CAI, sPOD, Air Bag Helpers w/ Daystar Cradles, RCI engine & fuel tank skid plates, ABS Guards, Job Box Storage, Tailgate Power Lock, Desert Eagle Offroad tranny/cat security skid plate, Added Driver’s Side Grab Handle, VLEDS Footwell & Step Lighting, Anytime Front Camera, Illuminated Ignition Ring, Console Molle Panel, Sound Dampening in Ceiling/Doors/Floor, Yakima Rack, Paracord Grab Handle Wraps, BD Underhood Light, Tuffy Console Safe Insert, WeBoost System, Midland GMRS Radio, Console Interior Lighting, Power Inverter, Custom Center Switch Panel, and Dual Air Compressors
  6. Feb 2, 2021 at 4:59 AM
    tttrdpro
    tttrdpro Former Naval Person
    SWGA
    2024 GMC 2500 AT4
    In progress…
    What if he had his bed loaded and the setting was proper?
    biebs96[QUOTED] likes this.
