Tundra doesn't like the cold
Discussion in 'General Tundra Discussion' started by Tundralicious, Jan 30, 2021.
  1. Jan 30, 2021 at 3:37 AM
    Tundralicious
    Tundralicious [OP] New Member
    Toytoy
    2020 Tundra TRD Sport Premium
    Stock for now
    Hey everyone,
    I bought a 2020 Tundra (10 000km) in April last year and I live in North Ontario. Where I live, it's usually always around -10 to -30 degree Celcius.I always use my keyfob to start my truck in the morning a few times to let it warm up before I use it. Anyhow, all that to say, I come out of my workplace yesterday to find out there's a machine squeaking from under the hood. Turns out, it's my brand new truck. I'm not too happy about it.
    Truck runs fine. Just annoying at idle. Sounds like it has something to do with a bearing, a belt somewhere in the middle near the fan.
    Anybody else ran into the same issue? I already arranged an appointment but if it could be a DIY, I could save myself some time.
    Cheers to the weekend
  2. Jan 30, 2021 at 4:24 AM
    snomoman
    snomoman New Member
    North Aurora, IL
    2020 Cement SR5 4WD Tundra
    Bed liner, truxedo tonneau cover, Westin step rails, cover king seat covers
    Sorry to hear of your predicament, the only thing I would say is that for you to go to the dealer for service, it’s under warranty still, right? Whereabouts in northern Ontario do you live? I was born in Kirkland Lake
  3. Jan 30, 2021 at 4:31 AM
    Tundralicious
    Toytoy
    Stock for now
    Hey. I live in Kirkland Lake it's been 3 years give or take. Yes, it's still under warranty until 60 000km. I guess I'll have to take a day off to bring it to the dealership.
  4. Jan 30, 2021 at 4:36 AM
    snomoman
    snomoman New Member
    North Aurora, IL
    You live in Kirkland Lake, wow that’s pretty amazing, it is indeed a small world, my mom grew up in Cochrane, I was only in Canada for around six months, then my dad got transferred to Detroit and I’ve lived in the states ever since
    Tundralicious[OP] likes this.
  5. Jan 30, 2021 at 6:25 AM
    frichco228
    frichco228 Valued Member
    Frank
    Virginia
    2016 Crewmax 4WD, TRD Offroad
    Very cold weather makes vehicles do odd things. Things squeak that never make noise any other time. Fluid in the shocks gets dense, making for a potentially jarring ride. Tires get hard and ride like bricks. Everything just feels stiff and painful. Hope you get it worked out. And living where you do, I am sure you know all about that really cold weather can do to a Tundra.
  6. Jan 30, 2021 at 6:54 AM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    If its squealing like a pig at idle, it's most likely the serpentine belt... condensation gets trapped in the grooves and it squeals... pretty normal across all vehicles.. if you don't like it, swap to a gatorback serpentine belt which can prevent condensation getting trapped between the grooves and keep the squeal from happening.. if I understand you correctly
    Tundralicious[OP] and kparrow like this.
  7. Jan 30, 2021 at 7:13 AM
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    My truck squeals pretty badly when I first start it at -30. Pretty typical. I'm pretty sure it's just the fan belt complaining about the cold. But mine goes away after a few seconds.
    kparrow likes this.
  8. Jan 30, 2021 at 7:19 AM
    kparrow
    kparrow New Member
    Kevin
    Nampa, ID
    2008 Tundra DC 4x4 5.7l V8 Blue Streak Metallic
    Goodyear UltraTerrain AT 275/70/r18, Stoptech Cryo Slotted Rotors/Hawk LTS Pads, DECKED, and lots more!
    Sounds just like serpentine belt stretch to me. Mine would squeal as well. I recommend replacing the belt with Gates or others have had luck with gator back. If at all possible add the block heater and plug it in to warm it up a couple hours before you start it. My truck was much happier starting in -20F in MT when I plugged it in and got warm faster. Not saying it HAS to be plugged in but it helps for sure. I had to replace idler pulley and tensioner as well and that stoped all of the squeaking, but I do have 140k miles on it too
    Cpl_Punishment likes this.
  9. Jan 30, 2021 at 7:21 AM
    Terndrerrr
    Terndrerrr 923000 miles to go
    Music City
    6UR-FE
    How many times do you start it in the morning before driving it?
  10. Jan 30, 2021 at 7:23 AM
    DSLKSL
    DSLKSL New Member
    Don
    Had the same thing on a 2007, it was the idler pulley, it would only do it when cold. It split the belt as well. I had to have the deal pop the hood and listen after it sat overnight.
  11. Jan 30, 2021 at 10:01 AM
    Tundralicious
    Toytoy
    Stock for now
    You're right. It's just that I owned many vehicles in my life and not many did that. Especially not a brand new one.
  12. Jan 30, 2021 at 10:03 AM
    Tundralicious
    Toytoy
    Stock for now
    Depends on how cold it gets. Sometimes once, sometimes twice.
