Cant open my door with dead battery
Discussion in '2.5 Gen Tundras (2014-2021)' started by stangless40, Jan 29, 2021.
  1. Jan 30, 2021 at 5:40 AM
    #61
    The AM radio could get fried...ha!
    tttrdpro[QUOTED] likes this.
  2. Jan 30, 2021 at 5:42 AM
    #62
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    In this situation, I would concentrate on the alternator.
    I know you can at least SEE the alternator with the front passenger-side splash shields off. In fact, you can see the harness that connects to the alternator. Inside that harness, there are two wires that go directly to the battery; one is the ALT wire, the other is the ALT-S wire. If you can remove the alternator connector, and identify the two terminals, maybe you can attach your +12V wire, then ground to the chassis. If you can't remove the connector, you'll have to open up the harness and repair later.
    Maybe others can help you with the wire colors...short on time today.
    Edit: Those are small gage wires. If you use a charger, pay attention to your charging rate vs. fuse ratings. If you pop those fuses, you're done with this plan.
  3. Jan 30, 2021 at 5:44 AM
    #63
    tttrdpro
    tttrdpro Former Naval Person
    SWGA
    2024 GMC 2500 AT4
    In progress…
    When EMP weapons are used AM radios will be useless, but an old school vehicle will still start. Priorities.
  4. Jan 30, 2021 at 6:17 AM
    #64
    NoRcptn
    NorCal
    2017 Platinum
  5. Jan 30, 2021 at 6:47 AM
    #65
    blackdemon_tt
    blackdemon_tt Battery Slayer
    Don't know if you're not paying attention, but I've posted 6 different methods to either pop the hood, or open the passenger door.... just because you started reading at this post it doesn't mean I haven't been paying attention...
    BravoDeltaRomeo likes this.
  6. Jan 30, 2021 at 6:59 AM
    #66
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    So is this a problem for every modern vehicle or are the Tundra designers just a special kind of stupid?
    smslavin and Melikeymy beer like this.
  7. Jan 30, 2021 at 7:02 AM
    #67
    shawn474
    shawn474 Lego connoisseur
    MoCo, Maryland
    you can slide a blood pressure cuff into any door seam and pump it up. Use a rod to unlock the door. It's actually very simple to do and doesn't risk permanent damage to the truck.
    deptrai likes this.
  8. Jan 30, 2021 at 7:11 AM
    #68
    PJR202
    PJR202 New Member
    Call a locksmith. Too much time will be wasted or too much damage done. You've already saved enough in gas money to cover the cost. ;)
  9. Jan 30, 2021 at 7:40 AM
    #69
    Vizsla
    Vizsla pretend2send
    Don’t use those wires, bad idea. This is the alternator connection to the battery, can hook positive there and ground frame to open door.
    Half Assed, MJoeP, sr5shark and 2 others like this.
  10. Jan 30, 2021 at 8:00 AM
    #70
    Pangaea
    Pangaea New Member
    BC
    2021 Cement Tundra CM TRD Off Road Premium
    :popcorn:
    This is the kind of post that has me up at 3AM worrying. Especially since I’ve got a ‘21 with no knobs, or even a key, which is a new thing for me... I’ve always been about triple redundancy, since I’m sometimes out dozens of miles in the bush. It seems like this solution could work, no? Anyone think it’s a bad idea? Wire’s only 18 ga., but I always travel with a Yeti or smaller 12v power source capable of jump-starting my truck.
    Sure hope this gets solved in an elegant manner...
  11. Jan 30, 2021 at 8:09 AM
    #71
    glowblue
    glowblue From time to time
    VA
    I like the earlier posted solutions with a way to extend the electrical leads to your battery so you camp jump the battery without opening the hood. Of course if your jump start battery pack is in the cab that might be a problem...
    JimboSlice413 likes this.
  12. Jan 30, 2021 at 8:10 AM
    #72
    JohnLakeman
    The problem for the OP is that the cord has to be installed BEFORE the battery is dead.
    If you set up your truck to plug in a smart trickle charger when idle, you have already installed this "elegant" solution.
    https://www.amazon.com/gp/product/B000FRLO9Y/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
    https://www.amazon.com/CTEK-56-382-...ld=1&keywords=ctek+cord&qid=1612022972&sr=8-3
  13. Jan 30, 2021 at 8:29 AM
    #73
    JohnLakeman
    @stangless40, The alternator harness is accessible right next to the frame. The most damage you can cause is removing the harness covering over a short area.
    If you want to try tapping the alternator charging wire to the battery as I posted above, the 2015 wire colors at the alternator connector are Black (ALT), Black w/Yellow (ALT-S), Green w/Yellow (IGnition), and Red (ECModule). The Black wire (ALT) is the one you should tap since the wiring diagram shows that fuse to be 180 amps, where ALT-S (Black w/Yellow) is only 5 amps. You can probably confirm which are the charging wires by simply probing through the insulation with a voltmeter lead (tape the probe sites). The charging wires will show whatever voltage the battery has remaining, maybe around 10+ volts.
    How quickly you can open the door lock will depend on how far discharged the battery. I would connect a charger to the charging wire tap, ground the other charger lead to the engine, and let it charge for an hour or so.
  14. Jan 30, 2021 at 8:30 AM
    #74
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    This is only a problem for crazy people who refuse to call a locksmith.
  15. Jan 30, 2021 at 8:34 AM
    #75
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    I still don't understand why you can't put the key in the door and turn it. Works on my 2012 Kia.
    Knowing that the Toyota batteries are shit and that my truck has sat for most of the last year (outside so no, I'm not putting my trickle charger on it), if you can't open the door with the key when the battery eventually dies, I'm definitely replacing this truck with something else. No way am I paying a locksmith for Toyota's poor design.
  16. Jan 30, 2021 at 8:38 AM
    #76
    JohnLakeman
    On Toyota's typical door lock design, there's a rod that connects to the lock mechanism from a small arm on the key cylinder. That rod is secured at the key cylinder with a plastic lock that snaps back onto the rod. If that plastic lock becomes unsecured (say, if someone previously tried to unlock the truck) or breaks, and that rod falls out of the key cylinder arm, you are screwed if you can't unlock it electrically.
    OP can put the key in the lock cylinder and turn it...it's just that nothing is happening at the lock mechanism.
    TTund16 likes this.
  17. Jan 30, 2021 at 8:42 AM
    #77
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    His key won’t work. But locksmiths can get into a car without using the tumbler. Any AAA guy would’ve been inside that truck in 10 mins using a coat hanger. Maybe they don’t have AAA in Canada but I’m sure there’s something similar. CCC??
  18. Jan 30, 2021 at 8:43 AM
    #78
    stangless40
    stangless40 [OP] New Member
    Alberta Canada
    17 Platinum
    lots
    people are saying get a lock smith, what can they do that i can't, battery is dead, key does not open the door, what can they do.
  19. Jan 30, 2021 at 8:45 AM
    #79
    JohnLakeman
    What I'm wondering. Toyota designed this door lock to not be openable with tools. Everything inside the door is shielded with metal guards.
  20. Jan 30, 2021 at 8:45 AM
    #80
    stangless40
    Alberta Canada
    17 Platinum
    lots
    And i can't even pry my window with that rubber seal that the window goes up into.
  21. Jan 30, 2021 at 8:46 AM
    #81
    pickeledpigsfeet
    pickeledpigsfeet New Member
    Sierra Foothills, Ca
    Kings & Icons
    In his situation yes, but this thread has been great for all of us that drive into the middle of the desert/woods with no cell service and the nearest locksmith is hours away. In my area neither AAA or the local locksmith will travel offroad. I have had to drag my friends rigs out to a gravel road to meet AAA. I could easily see my wife leaving the cab light on all night and me waking up to this same issue.
    Pangaea and JohnLakeman like this.
  22. Jan 30, 2021 at 8:46 AM
    #82
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    So his truck is broken and this shouldn't be an issue for anyone else. Thank you for clarifying.
  23. Jan 30, 2021 at 8:46 AM
    #83
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    They will wedge the door. Shove a long wire through and pull the manual lock. Get your door open. You pull the hood release. Jump the battery. And you’re done.
  24. Jan 30, 2021 at 8:47 AM
    #84
    JohnLakeman
    Yeah, like it's Two F'ups = One Aw S***.
  25. Jan 30, 2021 at 8:48 AM
    #85
    pickeledpigsfeet
    Kings & Icons
    As everyone keeps saying, call a locksmith. Now if you were stuck way out in the woods, I would be cutting through the grille to get to the hood latch. Grilles are cheapish and no collateral damage.
    Black Wolf likes this.
  26. Jan 30, 2021 at 8:50 AM
    #86
    JohnLakeman
    Wiley bastiches put a guard on the hood latch too specifically to block access to the latch mechanism and cable. Not been mentioned yet, but better check it out in advance. Been there.
  27. Jan 30, 2021 at 8:55 AM
    #87
    BravoDeltaRomeo
    Bruce
    MB Canada
    2019 Cavalry Blue Tundra CM
    CAA in Canada. :canada:
    OP...make sure to disconnect the battery before working on anything. :crapstorm:
  28. Jan 30, 2021 at 8:58 AM
    #88
    pickeledpigsfeet
    Kings & Icons
    Yeah it has a guard on it, but you can bend it easily. For future reference here is a couple pics
  29. Jan 30, 2021 at 9:01 AM
    #89
    JohnLakeman
    Yeah, but you have the hood up. Check out access to that cable end, and see how easy that guard is to bend, with the hood down. :D
  30. Jan 30, 2021 at 9:08 AM
    #90
    pickeledpigsfeet
    Kings & Icons
    In a emergency, I would cut through the grille with a multi tool and use needle nose plyers to bend it down. Then grab the cable sheath as far away from the latch as l could reach with the plyers and jerk on it to try and get the latch to pop.
    But I am going to do like the earlier user posted and run a pigtail out my grille so I can try and run some juice into the battery.
    JohnLakeman[QUOTED] likes this.
