2020 Pop n Lock Install
Discussion in '2.5 Gen Tundras (2014-2021)' started by 2020Platinum, Nov 11, 2019.
  1. Jun 28, 2020 at 9:35 PM
    2020Platinum
    2020Platinum [OP] www.youtube.com/NitroZ18Fishing
    Patrick
    Northeast PA
    2022 TRD Pro (Lunar Rock)
    A lot. See my channel for all installs/mods!
    No prob, happy to help!
  2. Oct 10, 2020 at 9:20 AM
    fbingha
    fbingha New Member
    Bakersfield, CA
  3. Oct 10, 2020 at 9:30 PM
    2020Platinum
    Patrick
    Northeast PA
    Steelerjax likes this.
  4. Oct 10, 2020 at 9:34 PM
    2020Platinum
    Patrick
    Northeast PA
  5. Oct 10, 2020 at 10:18 PM
    fbingha
    fbingha New Member
    Bakersfield, CA
    I’m pretty sure I followed the colors in that document, especially the red wire. I need to get back in it tomorrow as I’m wiring up the auto open tailgate mod. I’ll double check.
    My pop and lock is working.
  6. Oct 11, 2020 at 6:26 AM
    2020Platinum
    Patrick
    Northeast PA
    Interesting, yea let us know cause I’m 100% positive I have my blue to white and green to red...the pics are actually up above as well...strange...keep us posted, thank you!
  7. Oct 11, 2020 at 6:28 AM
    2020Platinum
    Patrick
    Northeast PA
    The only other thing I can think of is if they swapped the wires coming from the actuator right from the factory, so if they switched the placement of wires, that’s the only thing that would explain it...it’ll be interesting to see, thanks for letting us know!
  8. Oct 11, 2020 at 6:31 AM
    glowblue
    glowblue From time to time
    VA
    I’m actually getting ready to install mine today. The one I ordered is apparently a new version PL8457HD model. It has different wiring with plug disconnects to remove the tailgate and inline fuses for the connection to the truck wiring. I’ll post some pics when I’m done.
    Steelerjax and 2020Platinum[OP] like this.
  9. Oct 11, 2020 at 6:48 AM
    2020Platinum
    Patrick
    Northeast PA
    Ok awesome, yea they must have fixed it at the actuator end instead of the instructions...lol...I just saw that new version, good to know!...maybe I’ll do an updated video on the channel just so no one gets confused, thanks for heads up!
  10. Oct 11, 2020 at 7:53 AM
    fbingha
    fbingha New Member
    Bakersfield, CA
    I did install the PL8457HD model, going outside to get to work in a moment.
  11. Oct 11, 2020 at 8:45 AM
    glowblue
    VA
    Update: just installed the new version, PL8457HD and it works great. Not too loud. Install was just as @2020Platinum showed in his video, but the new version has Delphi connectors between the tailgate harness and the body wiring for tail gate removal, and an inline fuse with the quick splice wire taps. They updated the wiring so now the instructions are correct (its easy to swap if you mix it up). I normally solder my wiring, but the quick splices were easy and if they don't hold up, I'll just solder it later. All in all, great mod (should be a normally installed feature...) Took me about an hour, pretty easy install.
    Here are pics of new (and old) grommets that come in the kit:
    Here is new actuator with wiring pigtails:
    Body wiring:
    Quick splice connections:
    Installed tailgate wiring:
    And finally, the connectors under the bumper for tail gate removal:
  12. Oct 11, 2020 at 2:02 PM
    2020Platinum
    Patrick
    Northeast PA
    Aw
    Awesome, thanks for the update!...so it looks like the red still goes to green and blue still goes to white, they just changed it in the instructions?...thanks again!
  13. Oct 12, 2020 at 6:29 AM
    glowblue
    VA
    Actually, I posted the wrong pic (updated earlier post with correct one.). The instructions state blue to red, green to white/silver which is now correct as installed (they must have updated the wiring). The nice thing is with the new wiring connections you can easily change it.
    2020Platinum[OP] likes this.
  14. Oct 12, 2020 at 6:34 AM
    2020Platinum
    Patrick
    Northeast PA
    Ok great, good to know!...thanks for posting!!
  15. Oct 12, 2020 at 9:12 AM
    bunz559
    bunz559 New Member
    2020 SR5 TRD Sport
    I'm definitely going to add this to my truck. I'm learning that it's a slight inconvenience to have to pull the key out to lock/unlock the tailgate everytime.
  16. Jan 29, 2021 at 6:44 AM
    MatD13
    MatD13 New Member
    2018 Limited Cement Crewmax 4x4
    Has anybody who installed the pop and lock have a wire already coming out of the grommet under the front passenger grommet like the picture attached. Trying to figure out how I’m going to make this work. I have a 2018 limited
  17. Jan 29, 2021 at 9:35 AM
    blackoutt
    blackoutt YEAH BUDDY!
    NWA
    07 DC Long Bed - Old Man Tan
    OEM+
  18. Jan 29, 2021 at 9:39 AM
    matictundra
    matictundra New Member
    Franco
    AZ
    2017 Red Tundra SR5 4x4 CM
    3"/1.5" Lift (Fox 2.5 DSC all around, JBA UCA's and Toytec Shackles at 1.5") Front and Rear TRD Sway Bars Nitto Ridge Grappler 37x12.5R18 w/ Brz 18x9 +25mm Methods MR701 Wheels AFE Dry Filter with TRD Flow Acc Dirty Deed No Muffler Exhaust Nitro 5.29 Gears RCI Engine, Trany/Trans-Case and Fuel Skid Plates Relocated Rear Diff Breather | Rear Brake Line Extension Jomax ABS Sensor Armor Colored Matched Front Bulge and TRD Pro Grill Assy Modded ADD Stealth Fighter Front Bumper Custom High Clearance Rear Bumper with Modded Tow Receiver Behind Plate and Chopped Rear Fender Custom Bed Stiffeners 2019 TRD PRO LED Headlights w/ Ihacker Harness | BD 40" ARC AMB/WHT DC OnX6 BD 10" Onx6 in the Grill (2X) Rago Low-Profile Ditch and Extended Brkt with Daul BD Squadron Pros - AMB & WHT AMB LED Chase Light (Cargo) | Dual BD Squadron Sports in Rear Bumper Prinsu Roof Rack with a Pair of BD S1 For the Sides and Rear Mictunning C2 Rock Lights, 2 per wheel, and Toyota style switch 2X 55" Quick Light Whips with Toyota style switch Switch Pros SP-9100 with Custom Switch Mount, Custom Engine and Roof Terminal Junction Boxes 12K Lbs Smittybilt Winch with wireless remote and Factor 55 FlatLink E Amp Power Step EVO-One Remote Start Limo Tint (All Around) | De-Badged LED Interior lights with Front / Rear Interior Footwell LED Blue LED Lit Lock/Window Switch Mod AJT Full Chrome Delete Kit w/ 3R3 Painted SHCS Toyota LED Bed Lights Leather Perforated Wrapped Steering Wheel Black TRD Shift Knob ESP Long Box BakFlip MX4 Bed Cover Thinkware Q800Pro Dashcam (Front & Rear) Rago Dashmount w/ Ram Phone Holder
    I have three cables going through that grommet and not done all at the same time. The 1st time was for the pop n lock. The 2nd time was the amp power step. The last one was for the roof rack light cable. I just punch through the grommet each time and added RTV to seal it.
  19. Jan 29, 2021 at 11:09 AM
    MatD13
    MatD13 New Member
    thanks, earlier I ended up taking the old grommet out, drilling a hole in the new grommet, then cutting a slit to the side with a razor blade to get the bed lighting wire to fit. Sealed it up and good to go.
  20. Jan 29, 2021 at 1:04 PM
    #50
    Penberrf
    Penberrf New Member
    2020 Tundra
