How much 'margin' did Toyota leave in the GVWR numbers?
Discussion in 'Towing & Hauling' started by BrakeDust, Jan 29, 2021.
  1. Jan 29, 2021 at 6:24 AM
    BrakeDust
    BrakeDust [OP] New Member
    Hill Country, TX
    2021 CM SR5 4x4 Magnetic
    So I looked at my doorjamb sticker:
    (2021 SR5 Crewmax)
    - GVWR: 7200 lbs
    - GAWR Front: 4000 lbs
    - GAWR Rear: 4150 lbs
    - Payload: 1270 lbs
    Seems like I would have a 'real' weight capacity of 4000+4150=8150 lbs
    What happened to the other 950lbs that aren't included in the GVWR?
    There's also a yellow sticker that says "Modifications to this vehicle have reduced the original load carrying capacity by 70kg or 154 lbs." I got the TSS package which includes steps and 20" allows, Goodyear Duratracs. Also factory spray-in bedliner.
    I don't see how wheels & tires would factor into the GAWR ratings at all since they don't push down on the axles at all, therefore I can ignore them. The steps & bedliner, yes.
  2. Jan 29, 2021 at 6:28 AM
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
    I believe their publish ratings are very conservative, but I don't know by how much.
  3. Jan 29, 2021 at 6:29 AM
    18" TRD Off Road Wheels
    Axles aren't the only thing that is used to calculate GVWR. Wheels, tires, suspension, frame. You have narrow leaf springs in a Tundra for one thing.
    Cpl_Punishment likes this.
  4. Jan 29, 2021 at 6:31 AM
    Your add ons do not affect the GVWR at all. They affect your payload. The GVWR never changes.
