Mounting Tray
Discussion in '2.5 Gen Tundras (2014-2021)' started by so_juanderful, Jan 28, 2021.
  1. Jan 28, 2021 at 7:40 PM
    so_juanderful
    so_juanderful [OP] New Member
    Honolulu, HI
    2017 Cement Tundra TRD Pro
    Anybody looking for a mounting tray for their Tundra? These just came out from SD Off-road. Comes in 2 models Fuse and Terminal Block Tray and ARB + Fuse and Terminal Block Tray (compatible with ARB Single or Twin compressors). Both are compatible with Switch Pro modules. They are currently offering a $20 off prefab sale until Sunday and will ship out end of next week. For more info you can contact Derek on IG: sdoffroadmt
    I’m not a vendor and I’m not making anything from this, just sharing for a really good guy. Admins please let me know if this isn’t allowed.
    brkncly, junior, HulkSmurf14 and 3 others like this.
  2. Jan 28, 2021 at 8:39 PM
    Oats87
    Oats87 Dirt Rider
    Sunnyvale, CA
    A Non-Toyota
    This looks good. I wonder if it's compatible with the Genesis dual battery kit considering the fuse box needs to be moved back when installing that kit.
  3. Jan 28, 2021 at 8:42 PM
    eick
    eick New Member
    2020 CrewMax TRD Off Road
    I just built one of these for a blue sea acr and relay block etc.
    If I had known how much hassle it all was I would have just bought this lol
    bulldog93 likes this.
  4. Jan 29, 2021 at 10:21 AM
    matictundra
    matictundra New Member
    Franco
    AZ
    2017 Red Tundra SR5 4x4 CM
    3"/1.5" Lift (Fox 2.5 DSC all around, JBA UCA's and Toytec Shackles at 1.5") Front and Rear TRD Sway Bars Nitto Ridge Grappler 37x12.5R18 w/ Brz 18x9 +25mm Methods MR701 Wheels AFE Dry Filter with TRD Flow Acc Dirty Deed No Muffler Exhaust Nitro 5.29 Gears RCI Engine, Trany/Trans-Case and Fuel Skid Plates Relocated Rear Diff Breather | Rear Brake Line Extension Jomax ABS Sensor Armor Colored Matched Front Bulge and TRD Pro Grill Assy Modded ADD Stealth Fighter Front Bumper Custom High Clearance Rear Bumper with Modded Tow Receiver Behind Plate and Chopped Rear Fender Custom Bed Stiffeners 2019 TRD PRO LED Headlights w/ Ihacker Harness | BD 40" ARC AMB/WHT DC OnX6 BD 10" Onx6 in the Grill (2X) Rago Low-Profile Ditch and Extended Brkt with Daul BD Squadron Pros - AMB & WHT AMB LED Chase Light (Cargo) | Dual BD Squadron Sports in Rear Bumper Prinsu Roof Rack with a Pair of BD S1 For the Sides and Rear Mictunning C2 Rock Lights, 2 per wheel, and Toyota style switch 2X 55" Quick Light Whips with Toyota style switch Switch Pros SP-9100 with Custom Switch Mount, Custom Engine and Roof Terminal Junction Boxes 12K Lbs Smittybilt Winch with wireless remote and Factor 55 FlatLink E Amp Power Step EVO-One Remote Start Limo Tint (All Around) | De-Badged LED Interior lights with Front / Rear Interior Footwell LED Blue LED Lit Lock/Window Switch Mod AJT Full Chrome Delete Kit w/ 3R3 Painted SHCS Toyota LED Bed Lights Leather Perforated Wrapped Steering Wheel Black TRD Shift Knob ESP Long Box BakFlip MX4 Bed Cover Thinkware Q800Pro Dashcam (Front & Rear) Rago Dashmount w/ Ram Phone Holder
    That looks great but would be a pain in the ass if you ever have to replace a fuse, lol.
    dorton likes this.
  5. Jan 29, 2021 at 10:50 AM
    crewmaxlmt
    crewmaxlmt How dare you!
    scott
    2020 Crewmax Limited
    This, and fuses seem to blow at the most inconvenient places. It would be great if the mounting had a quick release system similar to the 1/4 turn fasteners on my quads plastics.
  6. Jan 29, 2021 at 11:44 AM
    matictundra
    Franco
    AZ
    Even with quick release it would be a pain due to wires and cables routing, which are usually just have enough length to make it neat and OE look. This is why I mounted mine on top of the junction box next to the airbox. You virtually never access the junction box unless you are re-wiring the truck.
  7. Jan 29, 2021 at 11:48 AM
    crewmaxlmt
    scott
    I was thinking about that as well. In order for it to work you would need quick disconnect plugs.
  8. Jan 29, 2021 at 12:27 PM
    matictundra
    Franco
    AZ
    It will be a lot of qd plugs, lol.
  9. Jan 29, 2021 at 1:28 PM
    crewmaxlmt
    scott
    That is the cleanest setup that I have seen on here.
    matictundra[QUOTED] likes this.
  10. Jan 29, 2021 at 9:16 PM
    fisherman951
    fisherman951 MT dreams
    Tony
    2017 crewmax 4x4
    This is an older switch pro so mounting on its side is not a problem. Warranty is expired anyways
  11. Jan 30, 2021 at 6:56 AM
    eick
    eick New Member
    I thought about placing my wiring there but my washer fluid bottle will be going there to make room for the second battery mount from sdhq in the original washer bottle location.
  12. Feb 1, 2021 at 9:47 AM
    matictundra
    Franco
    AZ
    Why the 2nd battery? Are you better off upping the alternator amp output?
  13. Feb 1, 2021 at 9:48 AM
    eick
    eick New Member
    alternator output is zero when the truck is off :rofl:
    The second battery is powering aftermarket ‘leave it on while the truck is off’ stuff.
  14. Feb 1, 2021 at 9:55 AM
    matictundra
    Franco
    AZ
    My plan is to put the 2nd battery underneath the truck bed if I ever need it.
  15. Feb 5, 2021 at 4:48 AM
    eick
    eick New Member
    Yes I looked at that to. I decided to keep it all in the engine bay in the end. Shorter wiring, no worry about it getting crushed. Not sure I could weld a good box under the bed.
    you have a sick truck btw
  16. Jan 4, 2025 at 9:21 PM
    brkncly
    brkncly New Member
    Oregon
    Where can I find out where to get the tray that you can mount Switch Pro SP9100 & ARB Twin Turbo Air Compressor.
  17. Aug 6, 2025 at 6:13 PM
    Yota303
    Yota303 -Running on hope and gasoline-
    Washington
    2016 MGM Crewmax 4x4 Limited
    If you don’t mind me asking, where might I be able to find/purchase this accessory tray? Have been looking at options for mounting electrical components in this same area and stumbled upon this. Looks great by the way.
  18. Aug 15, 2025 at 10:02 AM
    matictundra
    Franco
    AZ
    I designed and a friend 3D printed it for me, so custom.
