Front Differential and CV Axels
Discussion in '1st Gen Tundras (2000-2006)' started by PowTurns, Jan 28, 2021.
  1. Jan 28, 2021 at 5:27 PM
    PowTurns
    PowTurns [OP] New Member
    2004 Tundra Limited Double Cab
    My beloved 04’ DC (180,0000) wouldn’t go into 4wd. Took it to the shop and they discovered a ton of play in the CV axels and bad front differential. What do you guys think of this quote? $4,800 all said and done. Going to get a second opinion tomorrow. Almost half of what I paid for the truck, but I doubt it’s worth anything if I don’t address the issue. What should I do?97A9AD21-E7D6-494E-B81D-DCE374DACB4E.jpg D079A4D7-A5FF-4485-820F-C014583BDC9E.jpg
  2. Jan 28, 2021 at 6:18 PM
    Damn! I would keep it out of 4wd for the winter and replace it myself with a used front differential, but that's just me.
    Did the guy show you the actual play in the CV axles?
    MS22 and FrenchToasty like this.
  3. Jan 28, 2021 at 6:21 PM
    someone on here had a differential they were trying to get rid of. Otherwise, few hundred bucks at a junkyard or on ebay for a diff and a couple hundred for some CV's and you're back in business for under $6-700. $4800 is too much money to spend on a old truck. At least in my opinion. And the swap can't be that hard. The CV's were pretty straightforward. Front diff is a few bolts, some plug ins and the shafts. I haven't pulled mine but someone else here who has could probably help describe the process. Was that the dealer price? An independent shop may charge less, or allow you to bring your own parts.
  4. Jan 28, 2021 at 6:22 PM
    The driver side will have a decent amount of slop/play naturally, the passenger side will be a little bit tighter.
    Take it to another shop for sure, you probably don’t need the entire diff rebuilt.
  5. Aug 25, 2021 at 1:20 PM
    co2owen
    co2owen New Member
    VA
    2020 Cement Limited CM TRD Off-Road
    Trans Cooler. 5100's up front at mid-setting. ESP Plastic Storage.
    I just checked mine and I have a decent amount of play on the driver's side and a bit less on the passenger side. 2020 with 12,000 miles on the odometer. I leveled the front end (up 1.57") in December and have gone around 4,000 miles since then.
  6. Aug 25, 2021 at 1:22 PM
    SouthPaw
    SouthPaw The headlight guy
    2000 Limited 4x4 AC
    Get him!!!!
  7. Aug 25, 2021 at 1:26 PM
    SouthPaw
    2000 Limited 4x4 AC
    They must be quoting you a brand new diff. I am not sure what book time is do R/R both CV axles and the front diff but I would guess in the neighborhood of 7ish hours? @empty_lord can speak better to it but I would definitely be shopping around. At my company, we have a policy that anything over $2000 requires three price quotes and you would be surprised how much they vary.
  8. Aug 25, 2021 at 4:22 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    Ok get a new quote. The diff likely isn’t bad. Play in the driver side axle is normal too. There’s a needle bearing in it. I would take the truck in to someone else for a second opinion. Personally I’ve never seen a front diff actually go bad unless it’s been run out of fluid. The actuators do go bad, they are replaceable without dropping the diff or transfercase
  9. Aug 25, 2021 at 4:23 PM
    empty_lord
    05 rollover special
    Abs typically if 4x4 is in op, 60% of the time it’s the actuator in the transfercase.
    SouthPaw likes this.
  10. Aug 25, 2021 at 4:29 PM
    I'm going with it being a bad actuator, but I defer to the professional Toyo mech above.
    Honestly? Just take it to a dealership. Pay them to do diagnostics. Shouldn't be more than 2 shop hours to figure out what's up and around here that's billed out $115-150/hr depending which dealership I hit, if memory serves. Depending which actuator it is, it'll be less than $1000 IIRC, I think the most expensive of the lot is in the ballpark of $700? And if that came from a Toyota dealership, find another one and try again.
    And don't be shy about telling the shop quoting, "I always get two opinions on everything, I'll get back to you on this one". Then go do it. If their tune changes suddenly ... don't go back, they're scamming you.
  11. Aug 25, 2021 at 4:32 PM
    Guys, I think he's long gone. He hasn't posted since January. I doubt he's waited this long to fix it. :rofl:
    bmf4069, FrenchToasty and FirstGenVol like this.
  12. Aug 25, 2021 at 4:40 PM
    empty_lord
    05 rollover special
    Oh damnit why am i being tagged then! Lol
  13. Aug 25, 2021 at 4:44 PM
    Because turd gen strolled in, and woke a thread from the dead, but southpaw was still trying to be nice to the fella/fellina
  14. Aug 25, 2021 at 5:15 PM
    NWPirate
    Zach
    WA
    @bmf4069 probably can chime in with a picture or two. :rofl:
    bmf4069 and FrenchToasty like this.
  15. Aug 25, 2021 at 5:19 PM
    PLEASSSSSSSEEEEE
    bmf4069 and NWPirate[QUOTED] like this.
  16. Aug 25, 2021 at 5:31 PM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    @bmf4069 do NOT take the bait....fight the urge, the result could be fatal :eek2:
    bmf4069 likes this.
  17. Aug 25, 2021 at 5:34 PM
    But he’s our resident BGT enforcer :notsure:
    bmf4069, NWPirate and FrenchToasty like this.
  18. Aug 25, 2021 at 5:38 PM
    BubbaW
    Bubba
    Where Eagles Nest
    T150 Lover
    bmf4069 likes this.
  19. Aug 25, 2021 at 5:41 PM
    NWPirate
    Zach
    WA
    Jack McCarthy and BubbaW[QUOTED] like this.
  20. Aug 25, 2021 at 5:47 PM
    NWPirate
    Zach
    WA
    Seams a little excessive to get a vacation over poking fun at someone in the wrong section.
    Oh well! :itllbuffout:
    Jack McCarthy likes this.
  21. Aug 25, 2021 at 6:02 PM
    Dang, didn't realize this was well on its way to zombie thread.
    Would still be cool if @PowTurns was able to let us know what came of it. How'd this one get missed the 1st time?
  22. Aug 25, 2021 at 6:08 PM
    crewmaxlmt
    crewmaxlmt How dare you!
    scott
    2020 Crewmax Limited
    Having just done gears and lockers, $4800 does not seem bad from the dealership. But, as others have stated, you could do better sourcing the parts and doing the work yourself. I don’t know if I would want to do the front diff without a lift though.
  23. Aug 25, 2021 at 6:36 PM
    Huh, guess some people get hurt too easily. So we have a license to provide unwanted opinions on turd gens as long as it’s a serious opinion in nature? I never bothered venturing over into that area anyways myself.
  24. Aug 25, 2021 at 6:42 PM
    SouthPaw
    2000 Limited 4x4 AC
    Well, serves me right for not looking at the date when this thread was started.
    I tagged empty_lord because I wasn’t going down alone!
  25. Aug 25, 2021 at 9:38 PM
    I'll just throw this in here and call it good.
