Oil filter fit
Discussion in '2.5 Gen Tundras (2014-2021)' started by weirdbeard, Jan 28, 2021.
  1. Jan 28, 2021 at 11:57 AM
    weirdbeard
    weirdbeard [OP] New Member
    2020 black sr 4x4
    Doing my first oil change and this filter has me concerned. It’s the Wix
    57041xp
    It’s a very sloppy fit compared to the oem. It doesn’t seal around the perforated center tube at all.
    Is this right?
  2. Jan 28, 2021 at 12:07 PM
    Oey12
    Oey12 New Member
    Joey
    New York
    2020 SR5 TRD OFFROAD
    I cannot answer your question but I would go to the local Toyota dealership and get an OEM filter. I have never liked aftermarket filters. Personally Toyota’s reliability in general is attributed to their parts, filters included. But that’s just me...
  3. Jan 28, 2021 at 12:29 PM
    Ronin73
    Ronin73 New Member
    2019 Tundra Crewmax SR5 4x4 5.7 Magnetic Grey Metallic
    That does not look right at all. It should fit snug around the tube. I use OEM filters and when I put it on, I have to put a bit of effort into it because it is so snug.
  4. Jan 28, 2021 at 12:33 PM
    RitcheyRch
    RitcheyRch New Member
    Richard
    Star, Idaho
    TRD Lowered and Supercharged
    My local dealer always had the OEM oil filters on sale for $3.99
    Oey12[QUOTED] and AZBoatHauler like this.
  5. Jan 28, 2021 at 12:40 PM
    AZBoatHauler
    So.Arizona
    I went back to the normal OEM filters after trying the TRD filters. The TRD filters sat a little wonky which I did not like but they were not as bad as what is pictured above.
    Check your local Wal Mart if your dealer is far away - many Wal Marts are now carrying Toyota filters in their auto dept.
  6. Jan 28, 2021 at 12:49 PM
    matictundra
    matictundra New Member
    Franco
    AZ
    2017 Red Tundra SR5 4x4 CM
    3"/1.5" Lift (Fox 2.5 DSC all around, JBA UCA's and Toytec Shackles at 1.5") Front and Rear TRD Sway Bars Nitto Ridge Grappler 37x12.5R18 w/ Brz 18x9 +25mm Methods MR701 Wheels AFE Dry Filter with TRD Flow Acc Dirty Deed No Muffler Exhaust Nitro 5.29 Gears RCI Engine, Trany/Trans-Case and Fuel Skid Plates Relocated Rear Diff Breather | Rear Brake Line Extension Jomax ABS Sensor Armor Colored Matched Front Bulge and TRD Pro Grill Assy Modded ADD Stealth Fighter Front Bumper Custom High Clearance Rear Bumper with Modded Tow Receiver Behind Plate and Chopped Rear Fender Custom Bed Stiffeners 2019 TRD PRO LED Headlights w/ Ihacker Harness | BD 40" ARC AMB/WHT DC OnX6 BD 10" Onx6 in the Grill (2X) Rago Low-Profile Ditch and Extended Brkt with Daul BD Squadron Pros - AMB & WHT AMB LED Chase Light (Cargo) | Dual BD Squadron Sports in Rear Bumper Prinsu Roof Rack with a Pair of BD S1 For the Sides and Rear Mictunning C2 Rock Lights, 2 per wheel, and Toyota style switch 2X 55" Quick Light Whips with Toyota style switch Switch Pros SP-9100 with Custom Switch Mount, Custom Engine and Roof Terminal Junction Boxes 12K Lbs Smittybilt Winch with wireless remote and Factor 55 FlatLink E Amp Power Step EVO-One Remote Start Limo Tint (All Around) | De-Badged LED Interior lights with Front / Rear Interior Footwell LED Blue LED Lit Lock/Window Switch Mod AJT Full Chrome Delete Kit w/ 3R3 Painted SHCS Toyota LED Bed Lights Leather Perforated Wrapped Steering Wheel Black TRD Shift Knob ESP Long Box BakFlip MX4 Bed Cover Thinkware Q800Pro Dashcam (Front & Rear) Rago Dashmount w/ Ram Phone Holder
    I buy bulk OEM filter at Amazon.
    nasher75 likes this.
  7. Jan 28, 2021 at 1:19 PM
    Ronin73
    Ronin73 New Member
    Walmart carries them, but you can get great deals on Amazon. I buy mine in 5 piece package through them.
    Finnbear likes this.
  8. Jan 28, 2021 at 1:19 PM
    weirdbeard
    2020 black sr 4x4
    Thanks for the reply’s. I ended up buying all the filters at Oreillys. Which was only two others.
    The wix 57041 fit a lot better, but now I’m kicking myself for not getting an OEM filter. I never would have guessed they would vary so much.
    I’ve got her all buttoned back up now, but I might replace the filter tomorrow with an oem for piece of mind.
  9. Jan 28, 2021 at 1:32 PM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    If you pull the oil filter again I would suggest that you shit-can the plastic oil filter housing cap and replace it with a Toyota OEM aluminum one.
    AZBoatHauler and FrenchToasty like this.
  10. Jan 28, 2021 at 1:38 PM
    Johnsonman
    Johnsonman New Member
    Austin
    Sequoia
    What is important is the seating top and bottom, those spots must be snug so the oil can be sucked thru the filter sides towards the crush tube. Doesn't matter crush tube is super snug or not, that is not its job, its to keep the filter from collapsing inward and provide throughput for the oil. So as long as the filters are the same Height, all is gonna be Good.
  11. Jan 28, 2021 at 1:39 PM
    weirdbeard
    2020 black sr 4x4
    I guess I’m gonna run to the dealership in the morning and talk to them about that. I was planning on replacing that too.
    I’m pretty annoyed with this whole filter situation.
  12. Jan 28, 2021 at 1:41 PM
    That’s how I understood the filter situation
  13. Jan 28, 2021 at 1:59 PM
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    @weirdbeard @Johnsonman is correct.
    Cartridge filters designed by Toyota, and by others for Toyotas, seal at the top and bottom of the center tube as marked below. At the top, the filter element seals against the filter adapter. At bottom, the element seals against the spring-loaded relief valve plate. The spring for the relief valve holds the element tight against the top adapter surface, and the seals at each end force oil to flow through the paper media pleats and not around the filter element. The filter shown uses a full cover over the end of the folded paper element, Toyota seals the media fold ends by gluing them shut.
    Wix is the only filter I would consider if I couldn't find the OEM filter. In the past, Wix has made Toyota OEM filters, and they haven't forgotten how they did it.
    FrenchToasty and Bprose like this.
  14. Jan 28, 2021 at 2:25 PM
    weirdbeard
    2020 black sr 4x4
    Thank you for the explanations. I think I am beginning to wrap my mind around how it works. I measured them with a caliper and they are indeed the same length.
    One thing that is weird to me. The oem and cheaper wix filter I used have rubbery seals on top and bottom. The wix xp “which was not cheap “ is hard plastic which doesn’t seem like it would seal well under the spring tension.
    I guess I just really don’t like that filter.
  15. Jan 28, 2021 at 2:31 PM
    JohnLakeman
    Yeah, I'm with you. I prefer a little resiliency in my seals.
    The harder plastic probably works because the filter adapter and the relief valve plate are both smooth, flat surfaces that don't require the seal to conform to a rough or uneven surface. As long as the spring compression is higher than the pressure drop across the filter media, the hard plastic will probably work fine. As soon as the back pressure overcomes the spring compression (dirty oil filter), and the oil pressure eases the seals off their seated positions, it's a moot point anyway.
  16. Jan 28, 2021 at 2:41 PM
    matictundra
    Franco
    AZ
    I never had an issue with my Toyota thermoplastic oil housing cap. I don't go gorilla tight on it. The o-ring seals diametrically not a face seal so how tight you go doesn't make a difference in sealing. There is also anti-rotation tab that prevents it from vibrating loose. When I re-install mine, it always ends up practically back in the same spot.
