Another alignment headache
Discussion in '2.5 Gen Tundras (2014-2021)' started by Jman245, Jan 24, 2021.
  1. Jan 24, 2021 at 2:05 PM
    Jman245
    Jman245 [OP] Just moving about my way.
    Jay
    R.CUCAMOMGA,CA
    '19 Tundra TRD SPORT, ‘21 Trail Edition
    Trd pro suspension
    This is my alignment after the install of Total Chaos uca's with bushings. I was hoping for +7° like others have seen so I can run 37s with 0 offset wheels. I'm on 5100s maxed out with. 25' spacer. My numbers prior to install was at +4° on oem uca's. How did I lose caster when I asked for max numbers forward? Thanks for any help
  2. Jan 24, 2021 at 2:20 PM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    All they did was set your Toe. You didn’t even get an alignment done.
  3. Jan 24, 2021 at 2:23 PM
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    I "believe" with Camburg only you achieve 7+.
    They have 3 to 4 built into them.
    Pros and cons to that.
    Jman245[OP] likes this.
  4. Jan 24, 2021 at 2:41 PM
    Jman245
    Jay
    R.CUCAMOMGA,CA
    Trd pro suspension
    Is that the same with Tc?
  5. Jan 24, 2021 at 2:43 PM
    Jman245
    Jay
    R.CUCAMOMGA,CA
    Trd pro suspension
    That's what I said to the guy there. My numbers barely moved! At the end I wasn't charged but now I'm concerned that I can't get the numbers I need in caster. Hopefully they just didn't know what they were doing
  6. Jan 24, 2021 at 2:49 PM
    14burrito
    2014 SR5 CM 4x4 5.7
    TC keep the uniball more forward, closer to OE location, than Burg.
  7. Jan 24, 2021 at 2:53 PM
    Jman245
    Jay
    R.CUCAMOMGA,CA
    Trd pro suspension
    So I wouldn't get the #s camburg's do?
  8. Jan 24, 2021 at 3:04 PM
    Danman34
    Danman34 New Member
    Danny
    Why do you want so much caster? All you need is between 2-3*
  9. Jan 24, 2021 at 3:12 PM
    14burrito
    2014 SR5 CM 4x4 5.7
    I do not believe so. Eccentrics can only do so much. You can visually see the difference in uniball placements.
    Jman245[QUOTED][OP] likes this.
  10. Jan 24, 2021 at 3:24 PM
    Jman245
    Jay
    R.CUCAMOMGA,CA
    Trd pro suspension
    To run 37s with 0 offset wheels.
  11. Jan 24, 2021 at 3:33 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    IMO you only want about 4* left 4.5* right caster for what you wanna do. 7* can cause problems with your setup. Having run both I think you're better off with the TC UCAs and it should be easy to hit those numbers. You just need a real alignment and quality shops can be hard to find.
  12. Jan 24, 2021 at 3:44 PM
    biebs96
    PA
    For what it’s worth, these are my alignment numbers with stock UCA and a 2” lift up front. Hope it helps, or at least gives you a jumping point.
  13. Jan 24, 2021 at 4:29 PM
    Mill72
    Mill72 New Member
    California
    2021 Tundra DC 4x4 TRD
    My ‘14 Tundra I got 4-5* postive with TC uca’s and 6* positive with Camburg uca’s. Your alignment shop tech sucks.
    My current truck with Fox coilovers with stock uca’s I have 2*-2.5* postive castor with 0 toe and camber.
    14burrito and Jman245[OP] like this.
  14. Jan 24, 2021 at 4:45 PM
    Jman245
    Jay
    R.CUCAMOMGA,CA
    Trd pro suspension
    Yea, I need old school tech guys! In California, they were on every corner!
  15. Jan 27, 2021 at 1:47 PM
    Jman245
    Jay
    R.CUCAMOMGA,CA
    Trd pro suspension
    So I went to another spot and they were able to do this...
    Only problem now is, the truck pulls to the right. The first alignment,truck drove great but no caster for th 37s. Now I have the caster, but it wanders right. Is this normal? Thanks!
  16. Jan 27, 2021 at 4:02 PM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    The caster should be higher on the right, not lower as indicated by your print out. Toe looks much better now. It'd be better if they could 0 the camber but sometimes you have to sacrifice camber for caster. How much time did they spend on it?
  17. Jan 27, 2021 at 4:05 PM
    14burrito
    2014 SR5 CM 4x4 5.7
    Pulls to least positive caster. Add road crown and there is no surprise you drift right.
    Jman245[OP] and 831Tun like this.
  18. Jan 27, 2021 at 4:17 PM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    As alluded to by @14burrito, road crown is why you generally set the right side caster higher/ more positive.
  19. Jan 27, 2021 at 4:34 PM
    Jman245
    Jay
    R.CUCAMOMGA,CA
    Trd pro suspension
    About an hour...
    831Tun[QUOTED] likes this.
  20. Jan 27, 2021 at 4:36 PM
    Jman245
    Jay
    R.CUCAMOMGA,CA
    Trd pro suspension
    Thanks for the help guys! I'm gonna bring it back with these advices!
    831Tun likes this.
  21. Jan 27, 2021 at 4:42 PM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    Have you driven your truck hard off road? I bent my coil buckets in, toward the engine and had trouble with alignments. I've since had the buckets pulled back out and a brace over the engine connecting both buckets installed. But, that's 'cause I drive it really hard off road.
    I'm curious 'cause that's a significant amount of time to spend on the alignment and they should be able to get it a little better unless there's another factor like bent buckets.
  22. Jan 27, 2021 at 4:51 PM
    Jman245
    Jay
    R.CUCAMOMGA,CA
    Trd pro suspension
    Naw, I have only been doing light off roading here in Texas, nothing equivalent to Cali. Mostly overland type trails
