Show me your truck camping setup!
Discussion in '1st Gen Tundras (2000-2006)' started by Pucks18, Jan 11, 2021.
  1. Jan 25, 2021 at 12:11 PM
    #91
    onesojourner
    SW MO
    06 DBLcab LTD 4x4
    Shower related:
  2. Jan 25, 2021 at 12:22 PM
    #92
    Sunnier
    Sunny
    San Diego, CA
    Uh. I guess I’m not the risk-taker I might be: I’ll drive the truck fast off-road in remote places, but messing with how it runs to create hot water for a shower is not something I’ll likely try.
    I like my well-packed portable propane water heater all day long.
    Edit: that said, if I can check out someone else’s truck that does this, of course I’ll want to do it!
  3. Jan 25, 2021 at 12:34 PM
    #93
    onesojourner
    SW MO
    06 DBLcab LTD 4x4
    This is really well documented in the landcruiser world. If you forgot to winterize it I could see it getting kind of ugly. Either loosing, most likely small amounts of coolant and or water mixing in with the coolant. It is definitely a potential failure point. I don't think it is likely to ever cause the trip to fail though. I am trying to figure out a clean bypass setup so that the heat exchanger can be taken out of the loop completely. I have more research to do.
    Sunnier likes this.
  4. Jan 25, 2021 at 12:38 PM
    #94
    chunk
    chunk New Member
    2001 SR5 Tundra, 2WD
    Bone stock, original owner
    I use a 2.5 gallon solar shower bag, a few hours in the sun and the water is sometimes too hot and I have to add cold water. Not an instant hot shower, but doesn't require anything but the sun and a flat surface, like the hood of the truck. I guess it wouldn't be good for cold WX camping, but I don't go anywhere near cold weather. Mostly SoCal desert and SoCal beach areas.
    Voss and tvpierce like this.
  5. Jan 25, 2021 at 8:13 PM
    #95
    jaunty
    jaunty New Member
    six-pac mini 6.0 camper.
  6. Jan 25, 2021 at 8:38 PM
    #96
    onesojourner
    SW MO
    06 DBLcab LTD 4x4
    How much does it weigh? What's your suspension setup? How fast do you drive? Any elevation?
  7. Jan 25, 2021 at 8:59 PM
    #97
    Skey44
    Skey44 GreenvilleOverland
    Scott
    Greenville SC
    2018 GX 460
    Lift, tires, wheels, roof rack
    D82F550E-CF69-402A-AB17-AAA4813438BD.jpg I have Dobinsons and I drive fast.
  8. Jan 25, 2021 at 9:01 PM
    #98
    Skey44
    Scott
    Greenville SC
    2018 GX 460
    7400+ Lbs In expedition mode. Did 15 nights in a row dispersed camping 4K+ mi SC to AZ. 2 showers. Loves truck stop showers are a luxury!
    Voss, Terndrerrr and Wallygator like this.
  9. Jan 25, 2021 at 9:06 PM
    #99
    Skey44
    Scott
    Greenville SC
    2018 GX 460
    And sorry See first gen... but FWC still awesome. You can get a narrow Tacoma camper for them and build up the floor with a drawer to fit the bedside height. Think model is fleet? I have a raven :drunk:75AD86E3-DB4C-4A48-A41A-DF66F18ABBF3.jpg
    Darkness, Wallygator and skywalker474 like this.
  10. Jan 26, 2021 at 8:26 AM
    #100
    jaunty
    jaunty New Member
    900 lbs wet (water/propane).
    I have a 2" leveling kit, bilsteins. Ride-rite airbags in the rear for leveling (swapping those out for sumo springs now).
    I drive fast, no big deal.
  11. Jan 26, 2021 at 8:55 AM
    #101
    onesojourner
    SW MO
    06 DBLcab LTD 4x4
    Wallygator likes this.
  12. Jan 26, 2021 at 10:05 AM
    #102
    des2mtn
    SW
    2004 Black DC Limited 4x4
    Tonto cover
    This is what I stick to. I made a setup that uses two solar showers combined to a USB pump that goes to a shower handle. Solar showers work nice if your truck is black. I have also set the showers on the hood and idled the engine to radiate some heat and charge the truck battery but that's not ideal. If I need warm water to shower and I can't set filled bags out all day, I will use my propane stove to heat water in a pot and continuously cycle water in and out of the bags until it is warm enough for me. I will often start the water while I'm cooking or something.
    Voss, Darkness and chunk[QUOTED] like this.
  13. Jan 26, 2021 at 2:03 PM
    #103
    Skey44
    Scott
    Greenville SC
    2018 GX 460
    I stop at truck stops every 5-7 days for a shower. They’re really nice and clean. I don’t mind being filthy when I’m solo, just have to stop when I can’t stand my own smell!
    Voss and Wallygator like this.
  14. Jan 26, 2021 at 2:31 PM
    #104
    chunk
    chunk New Member
    Can u talk about the set up a bit? Camper weight, helper springs, air bags? I would like something like that if the payload would allow. <thanks for sharing>
    onesojourner likes this.
  15. Jan 26, 2021 at 4:27 PM
    #105
    jaunty
    jaunty New Member
    4 posts up :)
    chunk[QUOTED] likes this.
  16. Jan 27, 2021 at 5:03 PM
    #106
    chunk
    chunk New Member
    So, I'm getting more serious about a camper for the Tundra and am leaning towards a pop up style like this. It's an aluminum framed unit and has enough amenities to be a civilized camper, for me at least. I don't know the brand, I was looking at 4 wheel, but they are too pricey for me. These are quite a bit less. Light weight as well. Anybody have any experience with these, quality, customer service? Thanks.
    https://outfittermfg.com/shop-campers/caribou-lite-6-5
    Darkness, Wallygator and Casper421 like this.
  17. Jan 27, 2021 at 5:36 PM
    #107
    myt1
    myt1 New Member
    Richard
    Scottsdale, AZ
    2010 Tundra DC TRD SR5 Desert Sand Mica
    OME Lift, 275/70R 18
    Very nice.
    Do you have access to the long drawer from the top?
    If you are sleeping inside your rig and it's cold or raining, you might want to be able to get at stuff with out going outside.
    Just a thought.
  18. Jan 27, 2021 at 5:51 PM
    #108
    MrDirtjumper
    MrDirtjumper Ol’ dickhead
    Josh
    Slam Angelo, Texas
    06 DC TRD, 2wd to 4wd Conv.
    Long drawer is mainly for cooking stuff and recovery gear. Don’t really see myself putting anything in there that I need instant access to.
    Plus I live in west Texas. What is this cold/rain you speak of?
    tvpierce and myt1[QUOTED] like this.
  19. Jan 30, 2021 at 8:22 PM
    #109
    MrDirtjumper
    Josh
    Slam Angelo, Texas
    So I think I’m going to call this done. Well... at least for the time being.
    Added 3 dividers in the drawer and the false top at the back will slide to the front so that I can lift the stove up on top of it.
    Driver wheel well has room for 4 18ah batteries beneath that shelf. Clearly I’ve already thought about doing this and a battery isolator. But like I said... for now, I’m done.
  20. Feb 1, 2021 at 8:17 AM
    #110
    onesojourner
    SW MO
    06 DBLcab LTD 4x4
    Looking good. How tall did your platform end up being? What do you plan to use for a mattress?
    What is that little block of wood at the bottom of the cabinet on the left?
  21. Feb 1, 2021 at 3:49 PM
    #111
    MrDirtjumper
    Josh
    Slam Angelo, Texas
    Overall height of the platform is about 1 1/2” taller than the wheel well humps. I’m still working on a mattress. The block has an identical one on the drawer side. That way I can pull out the “bike slide” and attach my fork to the fork mount without that piece wanting to teeter off the rear of the tailgate.
  22. Feb 1, 2021 at 4:16 PM
    #112
    bmc02
    bmc02 New Member
    Buddy
    E WA
    05 DC SR5 / 06 SEQUOIA LTD
    Started canopy camping this last summer. Threw together a sleeping platform pretty quickly that worked well. I will be starting my 2nd generation setup for my 1st gen in the next month or so. Learned some things on first build so going to start over with improvements. Can't wait to post my results when I'm done, but for now I'm lurking and gathering inspiration.
    Pucks18[OP] and Wallygator like this.
  23. Feb 2, 2021 at 2:20 PM
    #113
    onesojourner
    SW MO
    06 DBLcab LTD 4x4
    Like what?
  24. Feb 2, 2021 at 3:31 PM
    #114
    bmc02
    bmc02 New Member
    Buddy
    E WA
    Primarily that I built a platform for sleeping 2 people but I will often be alone at which point I'd like to have more storage. So need to have a single and double version.
    Also I was a little overbuilt and I could lighten it up a bit.
  25. Feb 2, 2021 at 4:32 PM
    #115
    Gman8P0W1
    Gman8P0W1 New Member
    Utah
    21 Lunar Pro
    ADD Venom w/Rigid 30” AT Overland Summit KMC: 315/70/17 KO2
    looking into building a lighting set up for my camper any tips?
  26. Feb 2, 2021 at 4:34 PM
    #116
    Pucks18
    Pucks18 [OP] Fleabit peanut monkey
    2001 Tundra 4x4 Limited trd
    Honestly this thread is awesome, I now have a shit ton of examples to base my camping setup off of. The more pics and explanations the better!
    Liferider98 and Sunnier like this.
  27. Feb 2, 2021 at 5:29 PM
    #117
    MrDirtjumper
    Josh
    Slam Angelo, Texas
    Honestly I went with the cheapest $10 Amazon weatherproof 12v leds. They specifically said they weren’t dimmable but I had an extra dimmer and well... what do you know? Hindsight, I would have gone with a set that does RGB so that I could set it to red. That way it would attract less bugs and be easier on the eyes at night.
    I peeled off 1” sections of the adhesive back and stuck little 1” sections of sticky back Velcro to it. Seems to be holding it pretty well but then again, that depends on if you have carpet or not.
    I think I’ve mentioned it here before but I also have a cheapo 6 port fuse box behind the driver taillight. It’s powered from a single run of 8awg straight off of my starting battery. That way I can use the lights at anytime.
  28. Feb 2, 2021 at 5:54 PM
    #118
    MrDirtjumper
    Josh
    Slam Angelo, Texas
    I drew each individual piece of my entire set up in CAD and even created an optimized cut sheet for a 4x8 sheet of plywood. I’m sure I could put a little more work into it and PDF it into a neat little instruction sheet if anyone that wants it would be willing to PayPal me whatever you think it’s worth.
  29. Feb 2, 2021 at 6:03 PM
    #119
    bmc02
    bmc02 New Member
    Buddy
    E WA
    I have ability to fully model and draft a setup if I'd like as well... However on my first build I threw it together after work the day before I needed it with very little thought. Hence the need for an improved second version. Once I get to it I'll be sure to share what I come up with. But it's still winter for 2 months so I'm in no hurry at the moment.
    Threads like these are awesome for design inspiration and motivation!
    Sunnier and MrDirtjumper[QUOTED] like this.
  30. Feb 2, 2021 at 6:30 PM
    #120
    onesojourner
    SW MO
    06 DBLcab LTD 4x4
    It's the wrong truck but here is my old setup. The whole setup could be pulled out and hung on the wall in about 5 minutes. You can see the holes for hanging in the back, 2 on each part.
    tacoguybill, Voss, Wallygator and 5 others like this.
