2005 tundra SR5 fog lights not working
Discussion in '1st Gen Tundras (2000-2006)' started by TrooperCole02, Jan 23, 2021.
  1. Jan 23, 2021 at 2:25 PM
    TrooperCole02
    TrooperCole02 [OP] New Member
    Hey guys new to the forum. I have a 2005 double cab V8 SR5. It originally didn’t come with fog lights but I have put in some fog lights and a new switch. Now only my high beams turn on and both my fog lights and low beams don’t turn on. Has anyone done this before or have a solution.
    thanks!
  2. Jan 23, 2021 at 2:28 PM
    AV8R4AA
    AV8R4AA New Member
    Greg
    Justin Texas
    2005 Tundra XSP
    Did you install the required relay?
  3. Jan 23, 2021 at 2:34 PM
    TrooperCole02
    I haven’t installed the relay yet. I have the relay but I never found the spot for it. Other Toyota owners say it’s behind the inside fuse box but I believe all my spots are filled.
  4. Jan 24, 2021 at 6:36 PM
    Lil Steve
    Lil Steve Living the dream
    Gilbert, AZ
    Not sure if the 2005 differs from my 2002, my fog light relay is in the engine compartment next to the battery.
  5. Jan 25, 2021 at 2:35 AM
    TrooperCole02
    I’ve checked there too, but there’s no FOG light slot as far I as can tell. I’ll keep looking tho....
  6. Jan 25, 2021 at 4:52 AM
    HanD
    HanD New Member
    Maryland
    05 DC
    there's a fog light relay there? is that different from the drl relay?
  7. Jan 25, 2021 at 9:47 AM
    Lil Steve
    Gilbert, AZ
    My 2002 doesn't have DRL so not sure if it has a different relay. Here's where the fog light relay is located in my 2002.
    HanD[QUOTED] likes this.
  8. Jan 25, 2021 at 11:33 AM
    2006Tundra
    2006Tundra Financially Irresponsible
    Lou
    Long Beach, CA
    2006 Toyota Tundra Double Cab SR5, 4.7L V8
    @TrooperCole02 If you believe all the spots are filled up, then you may have the relay pre-installed.
    I did this mod about a year ago on my 06 DC, without the relay being
    pre-installed.
    The relay location is under that driver side dash. I followed the instructions to the link below and read #6. The relay goes in the empty spot.
    Also, If you're using LED headlamps and fog lamps, you'll need one of these to make everything work properly. https://www.superbrightleds.com/mor...ad-resistor-h4-led-headlight-bulbs/2932/6284/ You just need one and install it either on driver or passenger side. Make sure you mount it away from anything plastic. It gets VERY HOT.
    Its very easy to install. You just plug one end into your headlight wire harness and the other into the head lamp.
    This is the back side where the relay needs to be. Copy, paste the link in the URL to bring up the PDF.
    file:///C:/Users/LBG29620/Downloads/DC%20Relay%20(1).pdf
  9. Jan 29, 2021 at 1:10 PM
    TrooperCole02
    I believe I already have the relay installed however nothing happens I still don’t have any lights.
  10. Jan 29, 2021 at 1:20 PM
    2006Tundra
    Lou
    Long Beach, CA
    Do you have LED head lights and LED fog lights?
  11. Jan 29, 2021 at 1:21 PM
    TrooperCole02
    Neither, I’ve always had factory halogen headlights and wanted to install fog lights. They are halogen as well.
  12. Jan 29, 2021 at 1:26 PM
    2006Tundra
    Lou
    Long Beach, CA
    Well the only other idea that I have is you don't have the relay installed. Have you checked?
  13. Jan 29, 2021 at 1:28 PM
    TrooperCole02
    Yes I’ve checked, All my relay spots behind the fuse box is full. I don’t know what else to do :(
  14. Jan 29, 2021 at 1:34 PM
    2006Tundra
    Lou
    Long Beach, CA
    So you have a new stalk, halogen head lamps and fogs and you say the relay is installed. hmmm...
    Try this. You said you have an extra relay, try replacing the relay that's installed there now with the new one. See if that works.
  15. Jan 29, 2021 at 3:57 PM
    TrooperCole02
    I did swap the relays and nothing happened. At this point I may just take out the fog lights and forget that I ever bought them. I can’t find anything else online regarding my predicament, but if anyone else has an idea or has figured it out please let me know!
  16. Jan 29, 2021 at 4:21 PM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC 2wd
    Do low beams still not work?
    Is it a perhaps a Sequoia stalk and not a Tundra one?
  17. Jan 29, 2021 at 4:24 PM
    TrooperCole02
    I bought it from eBay and it says tundra so I’m not sure. From what I understand they should be the same.
  18. Jan 29, 2021 at 4:24 PM
    Professional Hand Model
    Fred
    Hand Protectors
    I’ll be hoping for better light Mojo. Check your inbox for thoughts and prayers.
  19. Jan 29, 2021 at 5:59 PM
    assassin10000
    Andrew
    Northern CA
    '05 SR5 AC 2wd
    They are different part #'s.
    Sequoia is: 84140-0C030
    Tundra is: 84140-0C050
    The fact low beam stopped working is why I think you may have the wrong switch.
  20. Jan 29, 2021 at 6:02 PM
    TrooperCole02
    Hmmm interesting I’ll have to look at it later. I’ll keep you updated thanks for the info.
  21. Jan 31, 2021 at 9:38 AM
    AV8R4AA
    AV8R4AA New Member
    Greg
    Justin Texas
    2005 Tundra XSP
    I got my fog lights installed and they work!
    Thank you guys. Never had an issue, just glad mine
    are working like you fine folks said.
  22. Jan 31, 2021 at 10:07 AM
    2006Tundra
    Lou
    Long Beach, CA
    What was the issue?
  23. Jan 31, 2021 at 12:46 PM
    TrooperCole02
    Yes what was the issue?
  24. Jan 31, 2021 at 1:51 PM
    2006Tundra
    Lou
    Long Beach, CA
    Lol avatars are nice. @TrooperCole02 Did you replace the relay?
  25. Jan 31, 2021 at 1:57 PM
    TrooperCole02
  26. Feb 13, 2021 at 4:03 PM
    TrooperCole02
    Hey Greg how’d you solve your issue?
  27. Feb 13, 2021 at 4:56 PM
    AV8R4AA
    AV8R4AA New Member
    Greg
    Justin Texas
    2005 Tundra XSP
    Mine are working. It’s the other fellow that is having problems. The community here fixed me tight up.
  28. Feb 13, 2021 at 5:00 PM
    Fred
    Hand Protectors
    People have asked how you fixed your issue and are curious.
  29. Feb 13, 2021 at 5:27 PM
    AV8R4AA
    AV8R4AA New Member
    Greg
    Justin Texas
    2005 Tundra XSP
    I actually piggybacked on the other persons post. I bought the correct stalk, and relay and followed the forum directions. They work perfectly. Thank you guys for all the tips and directions. Mine was plug and play.
  30. Feb 13, 2021 at 5:32 PM
    TrooperCole02
    Great! Now I just have to do it:rofl:
