New tundra owner
Discussion in '1st Gen Tundras (2000-2006)' started by Schneider591, Jan 23, 2021.
  1. Jan 23, 2021 at 11:55 AM
    Schneider591
    Schneider591 [OP] New Member
    Just picked up my first tundra 02 v6 5speed 2wd. 220k miles. Unknown. Previous service so I changed all fluids did the timing belt water pump bearings and both lower ball joints. Any other issues these trucks have? Just want a reliable second vehicle for myself.
    Black Wolf and hammeron like this.
  2. Jan 23, 2021 at 1:09 PM
    Welcome from NY.
  3. Jan 23, 2021 at 1:12 PM
    Welcome to the forum and congrats on the new ride. At 220k miles, everything suspension should be inspected. For some reason the average joe never replaces shocks on their vehicle. They do not last 220k miles. Few last beyond the 80k mile mark. Ball joints were a great choice, they are a failure point. Brakes are also in need of inspection. If not already done, the larger caliper upgrade, complete brake system flush and rear brake adjustment. The usual suspects after that. Spark plugs, air filter, Fuel filter (since yours is an 02), throttle body cleaning and MAF cleaning. That should get you another 80-90k miles. Then rinse and repeat.
    Jack McCarthy and FrenchToasty like this.
  4. Jan 23, 2021 at 1:23 PM
    RitcheyRch
    RitcheyRch New Member
    Richard
    Star, Idaho
    TRD Lowered and Supercharged
    welcome from so cal
  5. Jan 23, 2021 at 1:57 PM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
  6. Jan 23, 2021 at 1:57 PM
    Lovetrucks
    Lovetrucks Member
    2019 Ram Rebel
    Welcome from Ontario Canada.
  7. Jan 23, 2021 at 2:18 PM
    Polished Rock
    Polished Rock New Member
    Charlie
    Grand Junction, CO
    2018 SR5/TSS Off Road, 285/55/20" KO2s, +Roadmaster AS
    none yet
    Welcome from Western Colorado.
  8. Jan 23, 2021 at 3:14 PM
    Original radiator? Next coolant change you should inspect the transmission hose line into/out of the radiator. Corrosion at the junction has led to the pink milkshake which can destroy your engine. Personally I think if someone changes their coolant regularly it won’t be an issue as I haven’t seen an ounce of corrosion on mine with changes every 30k miles. Just my 2 cents since you don’t have a maintenance history.
    Welcome for MA.
  9. Jan 23, 2021 at 4:31 PM
    N84434
    N84434 In the Frozen Tundra
    Milwaukee WI.
    2001 Limited TRD
    We’ve had a rash of 1st time posters today. There must have been a coupon or something...?
    Welcome to the club Schneider. Frame rust can be an issue, but as others have said these are pretty stout trucks.
  10. Jan 23, 2021 at 4:53 PM
    BobsYourUncle
    BobsYourUncle New Member
    2021 Super White Tundra TRD Pro
  11. Jan 23, 2021 at 5:04 PM
    Sean492
    Sean492 New Member
    Winston Salem, NC
    2018 MGM Tundra Sport
    Sounds like a great truck, we'd like to see it!
    Welcome from Winston Salem, NC!
  12. Jan 23, 2021 at 7:33 PM
    Schneider591
    Rust free frame az truck all it’s life. Took a fence post hit to the hood grill and radiator that’s how I came across it. Replaced the core support along with radiator I plan to replace all the front end parts as well as rubber suspension pieces as they are all dry rotted. The truck does however drive extremely straight and smooth minus a groan when you compress the front suspension. Just plan on a smooth driver to do truck stuff. I e read that the bilstine shocks are the way to go. I’m not planning a lift or prerunner just stock height.
    N84434 likes this.
  13. Jan 23, 2021 at 7:37 PM
    ACDC2ZZTop
    ACDC2ZZTop Rock n Roll!
    Travis
    Oregon
    2012 MGM Tundra double cab 5.7L V8
    All cosmetic so far see my posts in 2nd gen Black out chrome in progress….
    Welcome from Oregon
  14. Jan 24, 2021 at 6:43 AM
    Front suspension groan, that's not good. Could be busted shock, UBJ, or some of those dry rotted bushing bits. Groans are often metal to metal, like an upper ball joint.
  15. Jan 24, 2021 at 7:43 AM
    Schcoman
    Schcoman From behind the Redwood Curtain
    Humboldt Co. CA
    2000 Access Cab 4.7L V8 4x4 SR5
    None
    Welcome from True NorCal.
  16. Jan 24, 2021 at 7:48 AM
    Mitch09
    Mitch09 New Member
    NC
    2022 SR5 TRD Off-road
    Welcome from NC!
  17. Jan 25, 2021 at 4:56 AM
    HanD
    HanD New Member
    Maryland
    05 DC
    congrats!
  18. Jan 25, 2021 at 5:31 AM
    Ely010606
    Ely010606 New Member
    SPARKS, NV
    2017 QS SR5 CM TRD 4x4
    Welcome from Nevada
  19. Jan 25, 2021 at 7:34 AM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    Welcome. Sounds like you have to know how to work on vehicles so that’s a plus. I’ve got 209K miles and about to do upper and lower control arms as well as upper ball joints. Yours may need to same with the groaning noise or it COULD just be shocks. Hard to know without hearing it.
