Please show me your 285/70/17's
Discussion in 'Wheels & Tires' started by Highsierraguy, Oct 13, 2019.
  1. Jan 3, 2021 at 7:53 PM
    ultra1988
    ultra1988 New Member
    2019 tundra
    I want to do the same thing. I hate the E load tires, C load would work just fine for how much weight the tundra can handle and the E loads ride like shit. I was looking at icon or rock warrior 17’s. My E loads seem to be lasting a long time, almost wish one would blow out.
  2. Jan 3, 2021 at 9:25 PM
    Highsierraguy
    Highsierraguy [OP] New Member
    Nor Cal
    Since that post I went with 285/75r17 Toyo AT3 in load C and am really happy with the ride and performance.
    EDDO likes this.
  3. Jan 3, 2021 at 10:47 PM
    ultra1988
    2019 tundra
    Those were the exact tires I was looking at.
  4. Jan 6, 2021 at 4:54 PM
    16TRD
    16TRD New Member
    Norcal
    2016 White crewmax
    Were you at 1.9 front and stock rear right? Have a side pic?
  5. Jan 6, 2021 at 4:59 PM
    jabula_za
    jabula_za New Member
    Shaun
    Sabre Springs, CA
    2017 Tundra SR DC 4x4
    Icon 2.5s with RR & CDCV, 17x8.5 Method MR316 with BFG AT K02 32.6x17x10.5. K&N Filter, Blacked out tailgate emblems.
  6. Jan 6, 2021 at 11:41 PM
    Highsierraguy
    Nor Cal
    Here's as side as I have on my phone right now. I'm currently at 1.9 front and stock rear, however I just ordered Coachbuilder +2 shackles because after my cap the rear is just a tad bit low and the +2 should make it perfect with maybe a half inch rake. Did you get those Bilsteins installed yet? If I remember you have a snugtop on your rig so probably will need rear shackles as well if you're going the same route.
    adoboyota_newengland likes this.
  7. Jan 6, 2021 at 11:53 PM
    16TRD
    16TRD New Member
    Norcal
    2016 White crewmax
    I was waiting for the stock tires to wear down. They still doing good but its time for some new tires. Never got around to installing them yet. Looking to do everything here this next month. Yeah I wanted to see what it looks like first before I do the shackles. Your wheels are the mr313 right? I want to do the mr702 because of the bronze but not sure of the 0 offset.
  8. Jan 7, 2021 at 5:52 AM
    Highsierraguy
    Nor Cal
    Yep 313's. There was quite a few wheels I was interested in but I was certain I didn't want 0 offset. Even with +25 and 285/75 they still stick out a little more than I like personally.
  9. Jan 7, 2021 at 3:10 PM
    Barrett50
    Barrett50 New Member
    Barrett
    Wisco
    2015 DC silver
    Hey, those are exact same wheels and tires I’m contemplating. Any chance you have a pic that shows the poke? And what you had to trim to fit? I’m gonna have about same lift and really think that size tire is perfect.
  10. Jan 8, 2021 at 8:32 AM
    Highsierraguy
    Nor Cal
    I had to melt the front fender liner on both sides and push it forward about a half inch as they were rubbing in reverse at full lock.
    Barrett50[QUOTED] likes this.
  11. Jan 8, 2021 at 9:09 AM
    Barrett50
    Barrett
    Wisco
    2015 DC silver
    Thank you sir. Helps a lot.
  12. Jan 8, 2021 at 9:15 AM
    tdawson05
    tdawson05 New Member
    Todd
    2013 MGM DC Rock Warrior
    Cooper Discoverer AT3 XLT LT285/75R17's on RW Alloys
    Had to remove the front liner mudflap due to rubbing at full lock in reverse, other than that, no rubs anywhere!
    Blang805, EDDO and Shuffler like this.
  13. Jan 8, 2021 at 2:45 PM
    manofsteele2003
    manofsteele2003 New Member
    24 Sequoia TRD Pro, 03 Tundra Limited 4WD
    Westcott designs 3"/1" lift 295/70/18 Falken Wildpeak RTs Canvasback cargo liner aFe Tow hooks
    I just had these put on after I installed an Eibach 3/1, I think they fit perfect.PXL_20210108_220919615.jpg PXL_20210108_220759096.jpg PXL_20210108_220749820.jpg
    JMGmanAZ likes this.
  14. Jan 8, 2021 at 6:07 PM
    UTAHRTK
    UTAHRTK New Member
    SOCAL
    2017 MGM Tundra TRD CM
    Dirty Deeds 8" standard exhaust, King 2.5's/Bilstein 5160's, Built Right UCA,s, Method 701's, TOYO ATIII 35x12.5x17, TRD LED headlights, Pro Grill
    The 295/70/17s are pretty nice with no metal cut. Zero offset is the kicker.
  15. Jan 23, 2021 at 5:59 PM
    16TRD
    16TRD New Member
    Norcal
    2016 White crewmax
    Do you have pics with the 285/75 with the new shackles? Still debating on 70 or 75s.
  16. Jan 23, 2021 at 9:36 PM
    Highsierraguy
    Nor Cal
    Shackles are scheduled to be installed in a couple weeks. Here's the only pic I have on my phone of 75's, sorry it's not the best. If you're on the fence just go with 75's, learn from my mistake.
    cran2 likes this.
  17. Jan 24, 2021 at 9:48 AM
    Tundraofnv
    Tundraofnv New Member
    2020 Cement Crew
    I learned from your “mistake” and went with 285/75/17.
  18. Jan 24, 2021 at 9:51 AM
    Tundraofnv
    2020 Cement Crew
    I think I read on another post that I could of fit 315’s?
  19. Jan 24, 2021 at 9:56 AM
    Highsierraguy
    Nor Cal
    Looks great! I'm a big fan of these tires.
  20. Jan 24, 2021 at 12:21 PM
    #50
    16TRD
    16TRD New Member
    Norcal
    2016 White crewmax
    How much are you lifted in the front? I see you still have the little flap. Also whats the spacing of those wheels. Im set on these tires as well.
  21. Jan 24, 2021 at 12:55 PM
    #51
    Tundraofnv
    2020 Cement Crew
    Front: Bilstein 6112 set at 1.9, CB shim: 2 on passenger, 1 on driver. CB bumper spacer. ( I had to remove front flap due to rub at full lock in reverse.
    Rear: stock
    Wheels: 17 x 8.5 +25
    16TRD likes this.
  22. Jan 24, 2021 at 1:56 PM
    #52
    Highsierraguy
    Nor Cal
    Here you go
    radon222, cran2 and 16TRD[QUOTED] like this.
  23. Jan 24, 2021 at 2:07 PM
    #53
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    IMHO 285/75/17
    Pic has a 285/75/17 up front and a 285/70/17 in the back
    TheCAPA1, Skey44 and UTAHRTK like this.
  24. Jan 24, 2021 at 2:11 PM
    #54
    14burrito
    2014 SR5 CM 4x4 5.7
    Some more 285/75.
    I am very seriously considering going back to 285/75 in a ridge grap vs my current 35x12.5s. Size is near negligible IMO.
    Andrew4776 likes this.
  25. Jan 24, 2021 at 2:26 PM
    #55
    NoRcptn
    NorCal
    2017 Platinum
    Run the mullet setup. Business in the front party in the back.
    14burrito[QUOTED] likes this.
  26. Jan 24, 2021 at 2:28 PM
    #56
    14burrito
    2014 SR5 CM 4x4 5.7
    Broooooooo
    TheCAPA1 and NoRcptn[QUOTED] like this.
  27. Feb 12, 2021 at 3:54 PM
    #57
    TundraDDS
    TundraDDS New Member
    2020 White Tundra Limited 4x4
    What offset and tire size are you running?
    NoRcptn likes this.
  28. Feb 12, 2021 at 6:11 PM
    #58
    manofsteele2003
    +25, 285/70/18
  29. Feb 12, 2021 at 6:15 PM
    #59
    tonynw318
    tonynw318 New Member
    Tony
    Oregon coast
    2020 silver sky SR5 crewmax
    Oh my this is nice looking. I love those wheels with the silver sky!
  30. Sep 3, 2021 at 6:02 PM
    #60
    Andrew4776
    Andrew4776 New Member
    Andrew
    2018 tundra trd off-road
    Hey, just wondering in those pics, the 35s or 285/75. About to order a new wheel setup and had the same 70 vs 75 dilemma
