King 2.5 from sdhq
Discussion in 'Suspension' started by BigHornMtnTundra, Jan 23, 2021.
  1. Jan 23, 2021 at 1:19 PM
    BigHornMtnTundra
    BigHornMtnTundra [OP] New Member
    2018 Barcelona Red SR5
    Road Armor Stealth Lonestar King 2.5 RR EXT Coilovers King 2.5 RR performance shocks Icon delta joint tubular UCA Coachbuilder +3 shackle kit Durobumps bump stops Cooper discover at3 xlt 275/70/18 ARE Overlander
    Anyone running this setup from SDHQ? I was wondering what spring rate these are from them, and if hoping that they are tuned already.
  2. Jan 23, 2021 at 1:21 PM
    Mill72
    Mill72 New Member
    California
    2021 Tundra DC 4x4 TRD
    They’ll come 600lbs standard. You might be able to request a different rate if spoke to them direct, and generic valving from King for Tundras.
    14burrito likes this.
  3. Jan 23, 2021 at 1:29 PM
    BigHornMtnTundra
    I’ll have to try Monday. I ordered the oem ones they have with non adjusters. I have a heavy front bumper but it didn’t give me an option to select 700
  4. Jan 23, 2021 at 1:34 PM
    BigHornMtnTundra
    Anyone know what height these will be at and if I need a diff drop?
  5. Jan 23, 2021 at 1:37 PM
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    FYI I believe King does not recommend going above 2.5" of lift.
    BigHornMtnTundra[OP] likes this.
  6. Jan 23, 2021 at 1:38 PM
    Mill72
    Mill72 New Member
    California
    You’ll get 2.25”-2.5” of lift out of the box, and I would not bother with diff drop unless going higher.
  7. Jan 23, 2021 at 1:48 PM
    BigHornMtnTundra
    One last Question I hope ‍♂️ Will I need an alignment with putting the shocks and camburg uca on?
    TheBeast likes this.
  8. Jan 23, 2021 at 2:01 PM
    14burrito
    2014 SR5 CM 4x4 5.7
    Yes
    Find a place who knows what they are doing especially since the Camburg have a lot of camber built in.
  9. Jan 23, 2021 at 2:20 PM
    BigHornMtnTundra
    Would the tubular delta joint icons have been better?
    TundraLaw likes this.
  10. Jan 23, 2021 at 2:28 PM
    14burrito
    2014 SR5 CM 4x4 5.7
    Camburg is the only one that has about 3 to 4 degrees built in. I currently run them and have a little issue getting numbers where I want with about 2.75" of lift. Unsure which direction I'll head, but until then I can work with where my numbers lie.
    Lot of good reviews on the DJ, lot of negative comments on Icon tubular arms here (quick search you'll find those).
  11. Jan 23, 2021 at 2:40 PM
    BigHornMtnTundra
    Is there a SDHQ REP that answers quickly through this site and can help me out?
  12. Jan 23, 2021 at 2:48 PM
    14burrito
    2014 SR5 CM 4x4 5.7
  13. Jan 25, 2021 at 7:01 AM
    The Patriot 1776
    The Patriot 1776 Asskick Fabrication: Shit Is Sick!
    Great State Of TEXAS
    '16 TSS CM 4x4
    600lb springs weren’t strong enough for my Tacoma with a winch and front bumper so I highly doubt they be strong enough for a Tundra (5.7L) even without a winch and/or bumper. I wouldn’t go lighter than 700lb.
  14. Jan 25, 2021 at 8:23 AM
    BigHornMtnTundra
    Got everything changed. Non adjuster Extended travel 2.5 with 700lbs spring rate, with a tuning request. Icon tubular delta joints uca. It is going to be a long wait, about 12 to 20 weeks.
  15. Jan 25, 2021 at 9:17 AM
    timsp8
    NY
    12-20 weeks is a long time to be checking order status and tracking #s. Maybe it’ll be faster. I have the icon dj and so far my only issue is it pulls to the left. I kept having that issue before. Go to a place that offers an alignment deal. I had to go to Goodyear here to get a 3 year deal.
    I have icon coilovers with 600 lbs spring rate and a winch and bumper. So far I haven’t noticed any issues, but I don’t drive fast off road or jump my truck. If I did it again, I’d probably go with the 700 lbs too.
  16. Jan 25, 2021 at 5:21 PM
    AccuTune Offroad
    AccuTune Offroad New Member Vendor
    El Cajon, CA
    Do they actually offer tuning? Some companies are claiming they do, but are just ordering the standard valving from King. Also, a 600lb spring on a Tacoma is different than a Tundra. Different lengths, different motion ratio etc.
    saybng and TheBeast like this.
  17. Jan 25, 2021 at 5:54 PM
    BigHornMtnTundra
    The guy I spoke with said he would put in a customer request to King to tune when they finally send them out. I don’t know how they would ride straight out of the box, but hopefully everything will be good. My bumper does weigh over 300lbs without winch so I think 700lbs spring rate won’t be a bad idea.
  18. Jan 25, 2021 at 6:00 PM
    TheBeast
    TheBeast The Beach
    King is pretty backed up right now.
  19. Jan 25, 2021 at 6:56 PM
    GreatBasinTundra
    GreatBasinTundra Beer Me!
    Reno, NV
    2020 Tundra SR5 DC
    Kings f/r, TC UCAs, RCI skids, RCI sliders, C4 bumpers f/r, Warn 12s winch, 35s on 17” Rebounds, softopper, wet okole covers
    I waited 16 weeks for my Kings. With a 300 pound bumper 700 lbs springs are probably what you want.
  20. Feb 11, 2021 at 11:08 AM
    BigHornMtnTundra
    Anyone know if I need a sway bar relocation with these kings? Also still getting diff drop and carrier bearing drop just because might as well.
  21. Feb 11, 2021 at 11:27 AM
    timsp8
    NY
    With 2.5” of lift or so you won’t need to do anything with the sway bar or a diff drop kit, although that won’t hurt. Just make sure you have the spacers for your skid plate. Carrier bearing drop is definitely something you should do though. It’s cheap and takes 10 to do. I got the shudder on takeoff with around 2.5” of lift until I installed it.
  22. Feb 11, 2021 at 11:36 AM
    BigHornMtnTundra
    Nice I’ll just do all of it for future upgrades. Never heard of the skid plate spacer though. My local Toyota dealer is doing install for around 800 with alignment.
  23. Feb 11, 2021 at 1:38 PM
    timsp8
    NY
    Here is an example of the spacer kit. Some diff drop kits come with it and other mfgs sell them, like how RCI sends spacers with their skids if you ask for them.
    This says TRD Pro skid plate, but I’m pretty sure the stock one needs to too or you can’t put it back on with the diff drop.
    https://www.readylift.com/tundra-trd-pro-skid-plate-spacer-kit.html
  24. Feb 17, 2021 at 5:18 PM
    TundraLaw
    TundraLaw New Member
    Northern Nevada
    Delta Joint is great, as you stated, but Icon Tubular is the devil. It's like they didn't cut the steel to the correct length. Nearly impossible to get them aligned properly.
  25. Feb 17, 2021 at 5:46 PM
    BigHornMtnTundra
    I got the Icon Tubular with the Delta Joint. Is that bad then?
  26. Feb 17, 2021 at 6:46 PM
    14burrito
    2014 SR5 CM 4x4 5.7
    That is the general consensus I heard around their tubular.
    TundraLaw[QUOTED] likes this.
  27. Feb 18, 2021 at 5:14 AM
    timsp8
    NY
    I have those same uca and my truck was able to be aligned. It took 3 tries before it felt right though. But it also took 3 times with 6112s and stock uca.
  28. Feb 18, 2021 at 6:20 AM
    TundraLaw
    Northern Nevada
    yup. I swear it’s not just some internet bs. There’s something wrong with the Tundra Tubular Icon’s.
  29. Feb 18, 2021 at 11:23 AM
    eick
    eick New Member
    2020 CrewMax TRD Off Road
    If you read the instructions for them you have to cut a little off the tie rod to get them to align 'in some rare cases'
    Sounds like they effed up and modified the instructions to cya. But from what I have read, if you cut that little bit off (like a 1/4 inch) they align just fine. Taking a little off the tie rod doesn't hurt anything anyway
  30. Feb 18, 2021 at 11:29 AM
    toyofan87
    toyofan87 Beer thirty
    Seth
    Gettysburg, Penna
    Top shelf lift
