stock lift, need A/T tires
Discussion in '2.5 Gen Tundras (2014-2021)' started by sludgepickle, Jan 23, 2021.
  1. Jan 23, 2021 at 8:47 AM
    sludgepickle
    sludgepickle [OP] New Member
    San Diego
    2018 Silver SR5 DC 4x4
    Hi all! After looking through the https://www.tundras.com/threads/largest-tire-you-can-run-stock-for-all-generations.9762/ thread I determined I can get 275/70R18s without a lift and it will be pretty maxed out (side note - that size isn't listed on the OP but many commented later that those fit).
    I will be the casual 3-4x/yr off-roader, nothing major. I also want to go to SoCal mountains to ski 2 times/yr without having to put chains on in the R2 chain requirement. "Requirement 2 (R2): Chains or traction devices2 are required on all vehicles except four wheel/all wheel drive vehicles with snow-tread tires on all four wheels."
    "Snow tread" tires are defined as: "A 'Snow-tread tire' is a tire which has a relatively deep and aggressive tread pattern compared with conventional passenger tread pattern". Snow-tread tires can be identified by examining the sidewall of the tire where the letters MS, M/S, M+S or the words MUD AND SNOW have been stamped into the sidewall."
    So, what A/T tire would work? Do all A/T tires have the M/S designation? Like KO2s, Toyo Open Country, etc?
  2. Jan 23, 2021 at 8:53 AM
    1UP
    1UP Truck Gang
    2019 Red CM TRD sport 4x4
    Saltyhero13 and Cpl_Punishment like this.
  3. Jan 23, 2021 at 8:56 AM
    sludgepickle
    San Diego
    thanks, posted!
  4. Jan 23, 2021 at 9:45 AM
    frichco228
    frichco228 Valued Member
    Frank
    Virginia
    2016 Crewmax 4WD, TRD Offroad
    275/70-18s fit great on a stock 3rd gen Tundra. As far as tire choices, there are many and would depend on your wants/likes/budget/treadware warranty. AT tires are going to be M+S rated and depending on the tire and size, may also be 3 peak rated. Popular tires are Nitto, Cooper, BFG, Goodyear, Hankook, Toyo and more. There are lots of choices. Did a quick search and sort for you- Here are 38 that discount tire has in that size and AT tires- https://www.discounttire.com/fitmen...ategory:allTerrainTires&sort=price-asc&page=0
    sludgepickle[OP] likes this.
  5. Jan 23, 2021 at 11:07 AM
    jordoncloutier
    jordoncloutier New Member
    Jordon
    Alberta , Canada
    2019 Tundra CrewMax SR5 Plus 4x4
    Daily Driver / Tow Vehicle , Retrofitted Trans Cooler , 10 Ply tires , Raptor Lined Ranch Hand Grille Guard
    I have had great luck with multiple sets of Hercules Terra Trac A/T2 tires in the past ,good tread life , 60.000 mile tread life rating . work great in the winter up here in canada , not loud on dry roads , currently running a set of E rated 10 ply stock sized LT275/65/18 on my 19' CM . IMO they are a very underrated tire. Also great pricing compared to other bigger brands. definitely recommend trying them out .
