275/70r18 Duratrac roll call!
Discussion in 'Wheels & Tires' started by TundraBC, Jan 21, 2021.
  1. Jan 21, 2021 at 7:30 PM
    TundraBC
    TundraBC [OP] New Member
    2021 Cement Crewcab Max
    Pending
    Looking to pull the trigger on some of these, looking at doing the 2.5” toytec/eibach kit. Would love to see what kind of stance it would look like with something similar, Thanks all!
  2. Jan 21, 2021 at 7:42 PM
    skylinekin
    skylinekin New Member
    Michigan
    2021 Tundra DC TRD PRO (Current), 2014 Tundra SR5 DC TRD OR (Sold)
    Bilstein 5100 at middle setting (1.5” lift) and 18x9 +25 wheels with 275/70/18 Duratrac tires. No rubbing after removal of small flap in front of wheel well, retained factory front mud flaps.
    BentJr likes this.
  3. Jan 21, 2021 at 7:49 PM
    TundraBC
    Pending
    Yup! Looks Rad!...I hate to even ask shit about mpg, but did you notice a difference? maybe slightly?
  4. Jan 21, 2021 at 7:53 PM
    Blueknights75
    Ron
    Clayton, NC
  5. Jan 21, 2021 at 8:09 PM
    skylinekin
    Michigan
    no, the wheels offset the weight penalty of heavier tires as the OEM wheels are quite heavy compared to aftermarket wheels. Now the lift, that does hit the gas mileage a bit I’d say 1mpg maybe?? It doesn’t bother me much.
  6. Jan 21, 2021 at 8:19 PM
    TundraBC
    Pending
    Right on, truck looks awesome. Will definitely be more inclined to do something like that, thanks
  7. Jan 21, 2021 at 8:24 PM
    skylinekin
    Michigan
    no problem, many guys on here like to run larger lifts and larger tires but I prefer to keep it closer to OEM for how I use the truck (towing, hauling, everyday driving and some light off-roading). Looks better in person than pictures as well if you can find someone locally to check theirs out. Good luck!
  8. Jan 21, 2021 at 9:25 PM
    Terndrerrr
    Terndrerrr 925000 miles to go
    Music City
    6UR-FE
    Following. Curious about this size as well.
    The stock Michelins are 41lb each. Duratracs in 275/70 are 57lb each. You’ll definitely be sitting with more weight at each corner regardless of your aftermarket wheels.
    It’s probably less noticeable than my 285/75s at 65lb each, but it will still be a bit of a difference.
  9. Jan 22, 2021 at 8:41 AM
    Wrongside
    Wrongside New Member
    AB
    2016 Tundra
    I put this tire on my Tundra last fall. The Duratracs weren’t my first choice- #1 choice had an unknown availability- but I’ve had a few sets on other trucks and been happy with them. So far I’m loving them on the Tundra. Far, far better snow and off-road traction than the previous 2 sets its had. There was a slight drop in mileage from the previous Toyo ATIIs of the same size, but it was around the time we switch to winter mix gasoline up here and it could’ve been the main factor.
  10. Jan 22, 2021 at 8:58 AM
    Wrongside
    AB
    2016 Tundra
    I don’t have any good pictures. Truck is squatting pretty good here, on a moose hunt up north hauling a quad & other gear.
    Y0TA PR0 likes this.
  11. Jan 22, 2021 at 9:03 AM
    frichco228
    frichco228 Valued Member
    Frank
    Virginia
    2016 Crewmax 4WD, TRD Offroad
    Moving from the stock size to 275/70-18, you are going to see a MPG hit of 1.5-2MPG. Also, 275/70-18 fit on a stock truck, no suspension lift needed.
  12. Jan 22, 2021 at 9:11 AM
    BentJr
    BentJr New Member
    Ben
    2019 Tundra Crewmax Limited Cement 4x4
    Do you have a picture of how much the wheel sticks out from the fender? Maybe a shot down the side?
    How much stiffer if any is the front suspension with the 5100's?
    Thanks
  13. Jan 23, 2021 at 6:57 AM
    skylinekin
    Michigan
    Here you go, the wheels do stick out a bit but the tire contact surface doesn't go too far past the side of the truck.
    The 5100's in the middle setting ride pretty close to the stock OR 4600's. Both are firmer than for example the TRD pro bilstein/fox setup.
    BentJr[QUOTED] likes this.
  14. Jan 23, 2021 at 8:32 AM
    BentJr
    BentJr New Member
    Ben
    Thanks man! I was considering a RRW rim with +25 and it seems to be as much stick out as I will be good with. Thanks man!
  15. Jan 23, 2021 at 10:24 AM
    TundraBC
    Pending
    I know the duratracs excel in snow and gravel, How are the duratracs in the highway/wet conditions everyday conditions?
  16. Jan 23, 2021 at 10:54 AM
    BentJr
    BentJr New Member
    Ben
    I have them on my tacoma and I am on my 3rd pair and about 140000 mi. The snow and ice, they aren't my favorite but everywhere else they are great. Not too much road noise and good in the water for sure. I know they won't last near that long on a tundra but they will be one of the better tires for sure
    TundraBC[QUOTED][OP] likes this.
