Hi guys i need help
Discussion in '2.5 Gen Tundras (2014-2021)' started by Rob67, Jan 20, 2021.
  1. Jan 20, 2021 at 4:05 PM
    Rob67
    Rob67 [OP] New Member
    Roberto
    2015 sr5
    None
  2. Jan 20, 2021 at 4:07 PM
    jewsNbrews
    Jewiston Idaho
    2019 TRD PRO
    Bolt on
  3. Jan 20, 2021 at 4:10 PM
    Rob67
    Roberto
    2015 sr5
    None
    Hi just made led headlightd conversion on my 2015 tundra using the special harness but o
    jewsNbrews likes this.
  4. Jan 20, 2021 at 4:11 PM
    CaptainGrumpus
    CaptainGrumpus The Mailman
    Maine
    2018 Inferno Tundra TRD
  5. Jan 20, 2021 at 4:12 PM
    Rob67
    Roberto
    2015 sr5
    None
    One side is much brighter can some one help and know what's wrong
  6. Jan 20, 2021 at 4:13 PM
    CaptainGrumpus
    Maine
    Bad ground?
  7. Jan 20, 2021 at 5:25 PM
    SLA10
    SLA10 New Member
    2019 Tundra TRD Pro
    I would swap the harness adaptor between headlights, see if problem moves. Could be a loose pin, bad wire crimp, see if problem is harness issue. Unless they're physically different R/L
    Sunnier, AZBoatHauler and 2mchfun like this.
  8. Jan 20, 2021 at 5:28 PM
    2mchfun
    Defective product? You could also direct power them with jumpers to Troubleshoot
  9. Jan 20, 2021 at 5:51 PM
    Bad connection. :monocle:
  10. Jan 21, 2021 at 5:58 AM
    Rob67
    Roberto
    2015 sr5
    None
    Thank you. Did you make the conversion and had same problem ?
  11. Jan 21, 2021 at 8:11 AM
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    Which "special harness" did you use?
  12. Jan 21, 2021 at 9:28 AM
    Rob67
    Roberto
    2015 sr5
    None
    A drl harness from headlights revolution
  13. Jan 21, 2021 at 2:30 PM
    Rob67
    Roberto
    2015 sr5
    None
    Thank you all i figured out the problem it was the drl harness
    JohnLakeman likes this.
  14. Jan 21, 2021 at 2:52 PM
    Uhhhh....
    Uhhhh.... New Member
    Dave
    Virginia
    2016 Silver Limited DC
    7” BDS, 37s
    Get an iHacker harness. They’re fantastic
    DSTundra and jewsNbrews like this.
  15. Jan 21, 2021 at 3:17 PM
    1UP
    1UP Truck Gang
    2019 Red CM TRD sport 4x4
