lug nuts
Discussion in 'Wheels & Tires' started by scturndra, Mar 28, 2017.
  1. Mar 28, 2017 at 6:19 AM
    scturndra
    scturndra [OP] New Member
    wall
    2012 tundra extra cab sr5 4.6v8
    I got a great deal on these OEM aluminum rims, so I went to have the 275/70R18's pulled off my trunda and put on these rims. The problem is that my lug nuts wont work on these rims. I was told the lug nuts needed a rim or a cap. Can someone point me in the right direction? maybe post a picture or a part number The rims came off a 2007 SR5 5.7 and I have 2012 SR5 4.6.
  2. Mar 28, 2017 at 6:22 AM
    scturndra
    wall
  3. Mar 28, 2017 at 6:27 AM
    r4z0r51o
    r4z0r51o have fallen off the forum, but I’m still alive.
    Dave
    Northeast San Francisco Bay Area
    2016 Silver Sky Metallic Crewmax 5.7L TRD 4x4
    22x12”HostileRage/33”NittoRidgeGrap/StealthFighter/FOX-BDS
    I'm sure someone will be able to help ... in the meantime, have a picture of the lugs that came off your 2012 wheels?
    When I changed out my OEM wheels to my current Fuels I had to use a different type of lug as well.
  4. Mar 28, 2017 at 6:31 AM
    BlueFalconActual
    BlueFalconActual Field Day Inspector Extraordinaire
    Kevin
    29 Palms, CA
    Tundra-less
    Im guessing you had stock steelies to begin with? If so, then yes, you will need 20 of these bad boys:
    NewImprovedRon and r4z0r51o like this.
  5. Mar 28, 2017 at 6:33 AM
    scturndra
    wall
    Yes i have the Stock Steel wheels. Do you know where I can buy them and or the part number?
  6. Mar 28, 2017 at 6:37 AM
    BlueFalconActual
    Kevin
    29 Palms, CA
    Tundra-less
  7. Mar 28, 2017 at 6:38 AM
    BlueFalconActual
    Kevin
    29 Palms, CA
    Tundra-less
    I would check eBay as well. You can get stock parts from dealerships that they take off for usually much cheaper.
  8. Mar 28, 2017 at 6:39 AM
    r4z0r51o
    Dave
    Wow, is that $11.48 each ... if so that nearly $230 for a set of 20! Yeah, a used set sold for $40 before.
  9. Mar 28, 2017 at 6:43 AM
    BlueFalconActual
    Kevin
    29 Palms, CA
    Tundra-less
    Yeah, that's through a dealership website. I just posted that for the part #. Im sure one could find them much cheaper on eBay. Lug nuts are not cheap though. It was always fun watching a customers face when they brought in their 8-lugs for custom wheels without accounting for the price of new lug nuts.
  10. Mar 28, 2017 at 6:46 AM
    r4z0r51o
    Dave
    I've got a set of 16 minus the lock lugs that needed to be broken off that I guess I'll never let go in case I ever need to put back on my OEM wheels. It would be cheaper to just buy new lock lugs.
    BlueFalconActual likes this.
  11. Mar 28, 2017 at 6:46 AM
    scturndra
    wall
    thank you for the information. After seeing some of these prices on lugs, I sure makes me more glad that the rims were given to me.
  12. Mar 28, 2017 at 6:50 AM
    Alloutdrs1
    Alloutdrs1 New Member
    Andrew
    Virginia Beach, VA
    17' Tundra SR5, 12' Tacoma TRD offroad
    The lugs are very expensive, I am in the same boat and searching for a set. Like mentioned above search ebay for a dealer take off set.
    Wheelers off-road has the gorilla lugs for $5 a piece.
  13. Mar 28, 2017 at 6:53 AM
    r4z0r51o
    Dave
  14. Mar 28, 2017 at 6:55 AM
    r4z0r51o
    Dave
  15. Mar 28, 2017 at 7:22 AM
    scturndra
    wall
    lugn nut.jpg wonder if these would work.
  16. Mar 28, 2017 at 8:31 AM
    scturndra
    wall
    well that was lucky... I was looking and looking on ebay and I found someone that is just outside of the city in another town and he had the lugs in stock. Got a new set of 20 for $70.00, not to bad.
    Thank you everybody for your help
  17. Mar 28, 2017 at 9:03 AM
    LS2
    LS2 New Member
    2017 Tundra SR5 TRD
    I notice on mine, four lugs are normal and one needs a special key to loosen/open. I forgot to ask the dealer about it when I drove off the lot. Can I find that key somewhere in my truck? or I have to buy that key separate? Thanks.
  18. Mar 28, 2017 at 9:05 AM
    BlueFalconActual
    Kevin
    29 Palms, CA
    Tundra-less
    It's usually in your glovebox. Or in the bag where they keep the tire tools
