2020 Tundra ...OEM RIM SIZE 20 inch ....WHAAAT!
Discussion in 'Wheels & Tires' started by virgoguy5, Sep 24, 2020.
  1. Sep 24, 2020 at 5:57 PM
    virgoguy5
    virgoguy5 [OP] New Member
    2020 Cavalry Blue Tundra Crewmax TRD SPORT 4x4
    Truck Cap, drivers grab handle, bug shield, locking gas cap, tail gate black raised insert letters. (Searching for black 20 inch rims.)
    Decided to replace my OEM Rims and Tires. A little help please with the SPECIFICS about my Rims ONLY. This is on a 2020 Tundra Crewmax TRD Sport. 20 inch Rims. Called dealer and even down to San Antonio Tx. No luck. The OEM Tires are Bridgestone Dueler H/L Alenza P275/55 R20 M+S steel belted. 111H.
    I have found out the width of the rims. (8j). 5 LUG. I need to know ONLY about THIS exact year and OEM rim SPECS. BORE SIZE.......Off-SET...LUG DIMENSIONS.
    For now I am just trying to match new tires onto new rims using EXACT SPECS. of OEM RIMS.
    Thank You....for any info. you may have.
    JerryH and Black Wolf like this.
  2. Sep 24, 2020 at 6:01 PM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    5x150. 110mm hub. +60
    AggiePhil, GODZILLA and Jtundra81 like this.
  3. Sep 24, 2020 at 6:09 PM
    virgoguy5
    Danman34.....Your the best. I can not thank you enough. THANK YOU X 100000000. May I ask where you found the Exact off-set of +60. Thank You.
  4. Sep 24, 2020 at 6:12 PM
    Danman34
    Danman34 New Member
    Danny
    You’re welcome. It’s stamped on the back of the wheel. It’ll show the offset as “ET60”.
    AggiePhil likes this.
  5. Sep 24, 2020 at 6:17 PM
  6. Jan 20, 2021 at 10:34 PM
    endless summer
    endless summer New Member
    2020 Tundra Crewmax 4x4
    Looking to do the same with my 2020 stock crewmax rims, replace them with black rims. What did you replace it with? I am worried about the offset don't want a rim and tire set up that sticks out too much. looking into powder coating as well but its time consuming and almost as much as a new set of rims.
  7. Jan 21, 2021 at 4:24 AM
    T-Guy69
    T-Guy69 New Member
    Long Island
    Black 2020 Tundra SR5
    Post pics of your replacement. Share useful information for the rest of us considering this.
