Will this be level?
Discussion in 'Suspension' started by WhiteTundra04, Jan 19, 2021.
  1. Jan 19, 2021 at 7:44 PM
    WhiteTundra04
    WhiteTundra04 [OP] New Member
    Cole
    2017 white platinum tundra
    Hey, I have a Toytec Aluma series boss suspension with rear shackles. If I put 1 inch shims in the front it would make it 4 in the front and 1.5 in the back. Would that be level? Thanks in advance!
  2. Jan 20, 2021 at 8:03 AM
    bjohnson425
    bjohnson425 New Member
    Brandon
    Measure from ground to wheel well and add 4 to the front and 1.5 to the back.... that’s where it should be before settling. With that said you will definitely need an aftermarket UCA and diff drop going 4” in the front unless you want to destroy your driveline and not be able to get a proper alignment. The most I would comfortable go is about 2.5” without diff drop or uca.
  3. Jan 20, 2021 at 8:10 AM
    WhiteTundra04
    Cole
    yes, I have UCA’s and a dif drop kit. Thanks!
  4. Jan 20, 2021 at 8:56 AM
    You will void the Toytec warranty by adding shims to the front. I have Alumas and shackles at 1.5 along with 1/2 inch rear axle shims and I am level.
  5. Jan 20, 2021 at 9:07 AM
    WhiteTundra04
    Cole
    Oh ok, I’m not sure how good Toytecs warranty is but I’m not going to mess with shims if it voids the warranty. Thanks!
  6. Jan 20, 2021 at 9:23 AM
    These trucks vary in height on the front end. The best thing to do is install it, let it settle, and then see how it looks. I actually got a little more than 3 inches in the front with mine.
  7. Jan 20, 2021 at 9:31 AM
    Figgy
    Figgy New Member
    Rene
    Vancouver, BC
    2018 White CM TRD Off Road
    Speaking about shims and Toytec lifts, down the road I am considering getting this particular set, just curious, is the tundra "lean" significant with this setup if you don't shim?
  8. Jan 20, 2021 at 9:53 AM
    The Alumas are adjustable to compensate for a lean if you have one.
    Figgy[QUOTED] likes this.
  9. Jan 20, 2021 at 9:58 AM
    Figgy
    Figgy New Member
    Rene
    Vancouver, BC
    Awesome, thank you for answering my question :D
