Pluto, Spvrtan's Ultra4-inspired build
Discussion in '2.5 Gen Builds (2014-2021)' started by Spvrtan, Jan 25, 2016.
  1. Nov 22, 2016 at 11:29 AM
    #61
    14tundra
    14tundra On Wisconsin!
    WI
    2014 Platinum Crewmax 4x4 5.7L 1G3
    Man sick rig! I check out your build every now and again. It always seems like you added something new or are off on an adventure. You have to have close to $80k in that rig!
    aperezsh likes this.
  2. Nov 26, 2016 at 4:25 PM
    #62
    J4RR3N4
    J4RR3N4 New Member
    South east Texas
    14 Tundra
    3” lift on 35’s
    How does the drop bracket lift and icon's work for you off road? I bought my truck with a pro crap lift on it already and I've been on the fence about putting coil overs on it or taking the lift off completely. Awesome build btw!
  3. Dec 1, 2016 at 10:49 AM
    #63
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    I like the black grill surround much better than the blue painters tape look. Much much much better.
    040Tundra, buckeyes1975 and TheBeast like this.
  4. Dec 2, 2016 at 7:05 AM
    #64
    Backslider
    Backslider Thirsty...
    Tooele, UT
    2022 GMC Sierra AT4 L5P - 2017 4runner SR5P - 2023 Tesla Model 3 LR
    I hope you don't mind, I send links to other Tundra nerds to your build page..
    I'm curious what hood hinge mounts and lights/covers you are using?
    Probably goes without saying, but my keyboard has collected a good amount of drool while viewing this thread.. Amazing build. =]
    buckeyes1975 likes this.
  5. Dec 11, 2016 at 8:36 PM
    #65
    AF_K9
    AF_K9 New Member
    2007 TRD Silver Double Cab...hopefully soon to have a '17 or '28 SR5 CrewMax 4x4
    Very nice rig.
  6. Mar 27, 2017 at 3:46 PM
    #66
    Spvrtan
    Spvrtan [OP] Amateur fabricator
    Kris
    San Diego, CA
    Black '14 CM SR5 w/ SC; 40s on 17s; 5.29s
    ..I should probably get around to updating this.
    TRON and Krezz like this.
  7. Mar 27, 2017 at 3:55 PM
    #67
    csuviper
    Broomfield, CO
    Yes you should!
  8. Mar 27, 2017 at 4:00 PM
    #68
    Krezz
    Krezz Doesn't want to be new member
    Kevin
    Southern Ontario, Canada
    2022 Tundra Crewmax Hybrid TRD Pro
    I concur
  9. Mar 27, 2017 at 4:01 PM
    #69
    Cfincke
    Cfincke Mall Crawler but capable
    San Antonio
    2014 Tundra 1794 CM 5.7 4x4 sunset bronze
    5.29s, Auburn LSD, 37x12.50R18, Icon coilovers and shocks, SPC UCA's, Tech 12 Volts sound system, Enve Grill
    Agreed
  10. Mar 27, 2017 at 4:06 PM
    #70
    Spvrtan
    Kris
    San Diego, CA
    I usually log all my adventures and mods on Instagram but I'll try to do better at doing detailed entries here. For now, I'll port over everything I logged on IG..
    November 16, 2016
    The coilovers finally got rebuilt along with new springs swapped in. These are 800lb-rated KINGs and a huge upgrade from the stock ICONs; a much needed modification to handle all the extra weight on the front end of the truck -- the blue color is a bonus.
    ColoradoTJ likes this.
  11. Mar 27, 2017 at 4:06 PM
    #71
    Spvrtan
    Kris
    San Diego, CA
    November 21, 2016
    No more towing mirrors. The roof rack lights are gone, too; going to be going a slightly different direction with lighting up there. Both sets of parts are now for sale.
    FirstGenTundra likes this.
  12. Mar 27, 2017 at 4:07 PM
    #72
    Spvrtan
    Kris
    San Diego, CA
    December 13, 2016
    Got the new gas tank skid plate mounted finally. 3/16th-inch stainless steel protection at a little over 50lbs in weight that was very much needed because the OEM plastic was torn up bad.
  13. Mar 27, 2017 at 4:08 PM
    #73
    Spvrtan
    Kris
    San Diego, CA
    December 23, 2016
    Very slow progress on my DIY console on top of the dashboard. The left screen will provide views from the roof and belly of the truck via cameras. The right will be for trail maps or movies.
    JC303, 040Tundra, rons23 and 2 others like this.
  14. Mar 27, 2017 at 4:08 PM
    #74
    Spvrtan
    Kris
    San Diego, CA
    January 9, 2017
    Got around to swapping out the weak OEM battery tray for a stronger one from @artecindustries. Also fabricated a simple plate for the relocated @warnindustries control pack that goes on top of the tray and got the winch wiring completed finally ..now to spool on the synthetic rope under load.
  15. Mar 27, 2017 at 4:09 PM
    #75
    Spvrtan
    Kris
    San Diego, CA
    March 11, 2017
    Installed some @sdhq ABS sensor guards on all 4 corners today. Small skid insurance for what could be a few hundred dollars in parts alone if you break the sensors offroad. You could also potentially lose 4x4 abilities when broken, too.
  16. Mar 27, 2017 at 4:09 PM
    #76
    Spvrtan
    Kris
    San Diego, CA
    March 11, 2017
    Mounted a 36" UWS chest onto the bed with 5 bolts through the floor; and added some D-rings inside it to strap down gear. Also super thankful for the bed liner from @linexsandiego for holding up to all the abuse I've put it through.
  17. Mar 27, 2017 at 4:34 PM
    #77
    Spvrtan
    Kris
    San Diego, CA
    October 2016 Sedona trip picture dump..
    r4z0r51o, FirstGenTundra and J4RR3N4 like this.
  18. Mar 27, 2017 at 4:42 PM
    #78
    Spvrtan
    Kris
    San Diego, CA
    November 2016 Sierras trip picture dump..
  19. Mar 27, 2017 at 4:58 PM
    #79
    FirstGenTundra
    FirstGenTundra R2R
    Daniel
    Wyoming
    2014 Toyota Tundra TRD
    You have a rockin' truck. Jealous of your gear and adventures! :thumbsup:
    Spvrtan[OP] likes this.
  20. Mar 27, 2017 at 8:21 PM
    #80
    Spvrtan
    Kris
    San Diego, CA
    December 2016 Big Bear trip picture dump..
  21. Mar 27, 2017 at 8:34 PM
    #81
    Spvrtan
    Kris
    San Diego, CA
    We took advantage of the cooler desert weather over the past 2 months (February/March) and did about 5 trips out to Anza-Borrego; here's a picture dump from all the trips (a few were group runs I led)..
  22. Mar 27, 2017 at 9:03 PM
    #82
    Spvrtan
    Kris
    San Diego, CA
    Between all those Anza trips, I did a few trips to Joshua Tree and Cougar Buttes (Johnson Valley); another picture dump..
  23. Mar 27, 2017 at 9:32 PM
    #83
    Spvrtan
    Kris
    San Diego, CA
    A smaller picture dump from a trip to Cleghorn last week..
    Halfjap, blue16, r4z0r51o and 3 others like this.
  24. Mar 27, 2017 at 10:17 PM
    #84
    TheBeast
    TheBeast The Beach
  25. Mar 27, 2017 at 10:53 PM
    #85
    Thegr8punkin
    Thegr8punkin A G.D.M/Sofa King Cool/COTJ's dreamboat
    Connor
    Northern Colorado
    08 blue sr5 2wd
    2 +5 hp stickers
    God I love your truck.... Soooooo much bad ass to it. So much better then mall crawlers ;) though I have to ask, do you have a winch?
  26. Mar 27, 2017 at 10:56 PM
    #86
    Thegr8punkin
    Connor
    Northern Colorado
    08 blue sr5 2wd
    2 +5 hp stickers
    Also, why don't you make a few more threads to post these in
    PermaFrostTRD likes this.
  27. Mar 28, 2017 at 12:18 AM
    #87
    Spvrtan
    Kris
    San Diego, CA
    Yea, I have a Warn ZEON Platinum 12k winch mounted in there and wired up to my battery. I just haven't found the time to spool on my synthetic rope.
    Oh, you mean so I "show off my Tundra" for people to "check out my lifted Tundra"? :rofl:
  28. Mar 28, 2017 at 12:22 AM
    #88
    Thegr8punkin
    Connor
    Northern Colorado
    08 blue sr5 2wd
    2 +5 hp stickers
    I thought I saw some pictures over on Instagram with it peeking through but the lack of spool kinda through me off
    And ya something like that lol damn Cali mall crawlers
  29. Mar 28, 2017 at 12:27 AM
    #89
    Thegr8punkin
    Connor
    Northern Colorado
    08 blue sr5 2wd
    2 +5 hp stickers
    Oh! Don't forget to delete the one thread that you catch some shit in! Because your just jealous yours isn't as "cool" and post pictures of Pluto in every new member intro!
    dcsleeper408 likes this.
  30. Mar 28, 2017 at 4:19 AM
    #90
    csuviper
    Broomfield, CO
    That rear travel!!
