Trivia Tuesday: NAME THAT PART
Discussion in '2nd Gen Tundras (2007-2013)' started by James-mf-thomas, Jan 19, 2021.
  1. Jan 19, 2021 at 7:06 PM
    James-mf-thomas
    James-mf-thomas [OP] New Member
    NAME THIS PART:
    Hint 1: 2009 Tundra Dual Cab SRT.
    Hint 2: Steering Column
    I was doing some work on the tilt/tele steering lock lever (it kept slipping and became free-flowing while driving) . i.e. tightening this bolt:
    fixed the slippage perfectly.
    Then this piece of a part, fell onto the floorboard:
    It fell from further back nearing the pedals or the column linkage. I could not find the source.
    If you know what it is please, don't be shy.
    Thanks fellas.
  2. Jan 19, 2021 at 8:41 PM
    James-mf-thomas
    Time's up.
    I found the source:
    on the inside of the this plastic casing:
    Given I only gave half a turn on the 10mm it had to have bee pre-cracked before it popped out of there (given the slippage).
    The lever still holds true with half the gear in there, for now. Now that I know the part, gotta find the part.
  3. Jan 20, 2021 at 2:14 AM
    Blueknights75
    Ron
    Clayton, NC
    Did somebody say Toyota part?? Paging the parts master @Roman
    James-mf-thomas[OP] likes this.
