Bilstein 6112 or 5100 in the front for my 2006 sr5?
Discussion in '1st Gen Tundras (2000-2006)' started by grant m, Jan 18, 2021.
  1. Jan 18, 2021 at 11:40 PM
    grant m
    grant m [OP] New Member
    Grant
    2006 silver tundra SR5
    none
    I was thinking about the adjustable 5100’s but I’ve seen some threads about the 6112’s. Which one would be better? What’s the difference?
  2. Jan 19, 2021 at 12:04 AM
    georgiey22
    georgiey22 SW Idaho
    2019 Tundra | TRD Sport | Cavalry Blue | Crew Max
    Own a 2019 Tundra with 6112’s, and had 5100 on my 2016 4Runner. 6112’s have a larger diameter piston and shock body when compared to 5100 (unsure of actual dimensions). The rebound is much more controlled with 6112’s which benefits daily driving comfort. The 6112 come with coil springs to match the truck and shock, for the price difference I’d say the 6112 is the easy choice.
    grant m[OP] and frichco228 like this.
  3. Jan 19, 2021 at 7:05 AM
    frichco228
    frichco228 Valued Member
    Frank
    Virginia
    2016 Crewmax 4WD, TRD Offroad
    Ditto on the 6112s, they are probably a better option since they some with new springs and I am sure replacing your stock 06 springs would be a wise choice.
  4. Jan 19, 2021 at 8:31 AM
    grant m
    Grant
    none
    thank you guys!
