Looking to buy second gen tundra anything I need to watch out for
Discussion in '2nd Gen Tundras (2007-2013)' started by Texasrangertundra, Jan 17, 2021.
  1. Jan 17, 2021 at 3:05 PM
    Texasrangertundra
    Texasrangertundra [OP] New Member
    Common problem ..... what I need to look for when I’m buying . Thanks
  2. Jan 17, 2021 at 3:08 PM
    mudrunner88
    mudrunner88 New Member
    2011 Black Tundra SR5
    None Yet Just Got Her
    Secondary air injection pumps collecting water, air injection valves stuck, broken clock spring
  3. Jan 17, 2021 at 3:15 PM
    timsp8
    NY
    Any rust or water damage depending on where the truck has been. Search for pictures of the cam tower leak and look for signs of it.
  4. Jan 17, 2021 at 3:32 PM
    Cam tower leaks.
    Welcome from NY.
    mudrunner88 likes this.
  5. Jan 18, 2021 at 6:47 AM
    Gto7419
    Gto7419 New Member
    2010 Tundra
    Water pump
  6. Jan 18, 2021 at 6:48 AM
    timsp8
    NY
    Also front diff growl.
  7. Jan 18, 2021 at 7:07 AM
    mudrunner88
    The bed where the the bolts go in and the frame support goes horizontally across. Bed bubbles up on top side.
  8. Jan 18, 2021 at 7:20 AM
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
    Welcome.
    Take each truck on an extended test drive with the radio off, listen for odd noises, thumps & bumps. Work every switch & button, put it on a lift or crawl under and inspect everything you can see with a flashlight. Open the hood and check fluids and the air filter. Look over the service records, and ask why it's being sold.
    Avoid car dealers, buy from a private owner.
  9. Jan 18, 2021 at 7:27 AM
    Blueknights75
    Ron
    Clayton, NC
    Welcome from NC!
  10. Jan 18, 2021 at 7:38 AM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    Welcome from Nor Cal,
    07 5.7, long bed, original owner, early water pump failure, starter replacement about a year ago so far. 227k at this point... Heavy jack took care of my tailgate pivot point... still holds together pretty well....
  11. Jan 18, 2021 at 10:57 AM
    usaf.2012
    usaf.2012 New Member
    AK
    2010 Black CM Tundra RW
    10" BAMuffler // Bilstein 5100s all around & front on Mid setting // Toytec shackles // BHLM
    Multiple threads going about this issue. The rust is NOT caused by the truck having a plastic bed liner, it starts on the underside due to poor sealing and rusts from the underside up. I have LINE-X and in the bed at each bed mount the LINE-X is being pushed up or looks to be blistering from the rust. I the truck has a plastic bed liner ask to have it removed or pulled out so you can inspect the top side of the bed as well.
    Links to a few of the threads:
    https://www.tundras.com/threads/bed-rust-issue.68880/
    https://www.tundras.com/threads/the-speed-of-rust.73034/
    https://www.tundras.com/threads/rusted-bed-need-your-opinion-please.74014/
    mudrunner88[QUOTED] likes this.
  12. Jan 18, 2021 at 12:47 PM
    CMB
    CMB New Member
    Cecil County MD.
    2010 Tundra DC 4X4 SR5
    Not nearly enough room here!
    Watch out for that Driver's Side Grab Handle, Toyota tells us it's a "Safety Hazard." Might want to hack saw it off, before someone gets hurt!:D
  13. Jan 18, 2021 at 12:49 PM
    Bravohook
    Bravohook New Member
    Addame
    NY
    2007 RCSB
    Cool Things
    Watch out for your wallet getting smaller from buying all kinds of stuff for it
