Likely my first and last toyota - Wiring Harness and electrical
Discussion in 'New Member Introductions' started by first and last toyota, Jan 17, 2021.
  1. Jan 17, 2021 at 9:21 AM
    first and last toyota [OP] New Member
    First and Last Toyot
    2014 Toyota Tundra Platinum
    3" lift, Gibson dual exhaust, Edwards retractable tonneau, TRD pro Bilstein shocks
    2014 Platinum purchased from Capitol Toyota in Salem, OR 30k original miles, certified used, bought extended warranty and SO GLAD I DID! However, now at 55k miles, door locks and windows still don't work after Toyota spent 5 hrs troubleshooting the issue. Truck also mysteriously wouldn't start after sitting for two days during RV trip with a brand new battery at 40k miles. It was during the Oregon fires.... stranded with RV in tow. Thanks Toyota.
    To my shock and horror, now Toyota dealer wants to replace the entire wiring harness because: "It's made out of soy food products and rodents find it DELICIOUS", however, dealer hasn't revealed any actual proof of rodent infestation, so I'm very reluctant to leave it with them, AFTER a $700. warrantly claim for a window switch that still didn't fix the problem. NO AFTERMARKET ACCESSORIES. I live in concrete jungle and truck sees the keys 2-4 times a day and it also doubles as a mobile office, I would know if I had any guests. 2- Tundra household, exact year make and models. Toyota insists that rodent infestation is the root cause although they have zero evidence. I smell a rat alrigtht.
    Have to leave at dealer for days for complete tear-down and try to find the problem.
    I don't do electrical problems.
    I think the truck is therefore garbage, it won't ever be the same again.
    Honda uses anti-rodent shielding on their harnesses. -as per toyota dealer.
    and that is WHY this will be my first and never again Toyota.
    What's more disturbing is that Toyota acts as if I somehow caused the issue and refuses to actually take care of me due to "rodents". I live in the city folk!!! they're lying. VERY DISAPPOINTING.
    I was horrified about tacomas frame rot- but nobody told me about main harness rot.
    yeah, food products and electrical wiring harnesses don't mix, who knew!?!?!?
    so glad I invested in making it a great truck with vegetable wiring cancer.
    never again. I'm no longer enthused, more like bitter disappointment in the quality and the lack of technical service at the dealer.
    YardBird and Blueknights75 like this.
  2. Jan 17, 2021 at 9:27 AM
    Welcome from NY.
    Guess you should trade it in.
  3. Jan 17, 2021 at 9:28 AM
    if only money grew on trees,
    lawsuit.
    I'm looking for a class action lawsuit.
  4. Jan 17, 2021 at 9:29 AM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
  5. Jan 17, 2021 at 9:31 AM
    On what basis?
  6. Jan 17, 2021 at 9:31 AM
    bleach
    bleach MEME Fiend
    DJ
    Battle Ground, WA
    1991 White Xtra-cab SR5 4X4 V6 5 speed 148K
    Why would you have to pay $700 for a warranty claim? Warranty claims shouldn't cost anything. I think your problem is the dealer not the truck.
    Cjames17, GODZILLA, rockmup and 5 others like this.
  7. Jan 17, 2021 at 9:41 AM
    I agree 100%
    The warranty covered the part which wasn't the root cause as they suspected. Why I don't want them to tear it down.
    (I have my suspicions about the stealership for sure Beaverton Toyota not Capitol Toyota
    . willing to tear truck down simply because the window switch replacement didn't resolve the issue and actuallly cuased a few more, like rear windown wont roll down and doors wont lock / unlock)
  8. Jan 17, 2021 at 9:46 AM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    I would side with the dealer being an issue.... I had an issue with the water pump when my truck was under warranty... I called corporate, asked for a name and extension number and what to do since I didn't want to overheat the engine and cause permanent damage.. They said throw water at it and take it in. dealer blamed me, and I called and used the extension issued the same day and it was cleared up... My truck was transported to a different dealer due to a loss of confidence both in my self and corporate.. I had to fly to get it as the next available dealership was over 60 miles away. Had a lot of other issues later on, to which I decided on a mileage penalty vs being blamed and charged for warranty work..
  9. Jan 17, 2021 at 9:53 AM
    yeah, thanks... I'm feeling that this bodes ominously. Really too bad as I have LOVED this truck for past 3 years. difficult to believe it.
    But if all they're going to do is put the exact same (delicious and prone to rott) wiring harness in, then I see no reason to keep it.
    I want peace of mind.
  10. Jan 17, 2021 at 10:01 AM
    blackdemon_tt
    I do believe the soy harness is Globalism standard now, so pretty much you're going to get it from German to Domestic to Asian, don't think switching brands will help as they all have similar issues... I'd suggest you do some digging for yourself though... no one cares more for any other property than their own... just my opinion...
  11. Jan 17, 2021 at 10:02 AM
    Blueknights75
    Ron
    Clayton, NC
    Welcome from NC! Sorry to hear about your issues. Looks like it’s time for another truck!
  12. Jan 17, 2021 at 10:03 AM
    NWPirate
    Zach
    WA
    Welcome from WA.
    Sounds like a better dealership is your answer to get a more accurate diagnosis. Find a master tech that doesn't just want to throw parts at it.
    It could be something simple and you could go back to being a happy camper.
    Cheers :cheers:
  13. Jan 17, 2021 at 10:07 AM
    ABSOLUTELY TRUE!
    but this is a "known problem" on tundras. not all Toyotas use the material.
    Dealer suggested claiming it on my comprehensive insurance (RED FLAG!) as extended warranty doesn't cover rodent infestations (and I reminded the dealer that insurance, and myself, won't accept it without any proof of residence.)
    Toyota should make it a recall, and use different, APPROPRIATE materials to fix the root cause. Asinine!!
  14. Jan 17, 2021 at 10:16 AM
    NWPirate
    Zach
    WA
    Agree its a known issue.
    Lots of red flags with that dealer, I would take it elsewhere for the issue without giving any back story on dealer #1.
  15. Jan 17, 2021 at 10:21 AM
    ElNopal
    Willis TX
    19 Cavalry Blue CM
    Same thought came to mind too.
  16. Jan 17, 2021 at 10:23 AM
    JimboSlice413
    JimboSlice413 Super Nice Guy
    Bakersfield
    Bilstein 5100/5160 Toyo at2 295/70r18 Ray10 GunMetal
    I would take all this frustration and walk it back to that dealer. If there is rodent damage, make them prove it. Especially if they're using that to deny warranty work. From what I get from you, they don't sound completely competent. Don't let them talk you into a radical repair like this
  17. Jan 17, 2021 at 10:27 AM
    Kung
    KG, VA
    1. Honestly, aside from the issue you're dealing with, it seems like 95% of the issue is the dealership, not the truck. I mean yeah, you've had issues with the truck; and I've had issues in the past with other vehicles, but the dealership makes or breaks the experience.
    2. I mean, Toyotas are statistically far more reliable than other makes. If you're going to shy away from them, just make sure you do your research on vehicles *AND* dealerships.
  18. Jan 17, 2021 at 10:29 AM
    I like that idea.
    Despite Toyota America telling me that once the warranty claim is started, I cannot switch dealers mid-course.... however, they did try to give it back to me after I signed all the paperwork and I believe that was "closing the claim" went outside and found more issues than I came into dealer with.... so it really wasn't fixed. which also didn't help build any trust..... Hmmmmmm….. OK, new dealer it is then.... fck em.
  19. Jan 17, 2021 at 10:33 AM
    Kung
    KG, VA
    Yeah, definitely; I've done that myself in the past. Dealerships/corporate doesn't 'like' it, but I flat out told them "YOU said I could take this to any dealership I wanted." LOL They didn't appreciate me saying that.
  20. Jan 17, 2021 at 11:38 AM
    YardBird
    YardBird Native San Diegan
    Jonesy
    2005 RCLB
  21. Jan 17, 2021 at 12:51 PM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
  22. Jan 17, 2021 at 12:53 PM
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    I predict nipple snapping.
  23. Jan 17, 2021 at 1:08 PM
    SimpleMan
    SimpleMan New Member
    Chuck
    2021 SR5 TRD OR 4x4
    Diamondback HD
    The rodent issue isn't just Toyota. When I was deployed overseas we had problems with rodents chewing wiring insulation on vehicles, we didn't have any Toyotas, everything was Dodge or Ford.
    Cpl_Punishment likes this.
  24. Jan 17, 2021 at 1:14 PM
    BravoDeltaRomeo
    Bruce
    MB Canada
    2019 Cavalry Blue Tundra CM
    So you joined a Tundra forum to complain about your Tundra?
    :crazy:
    Tundyfundy likes this.
  25. Jan 17, 2021 at 1:15 PM
    NoRcptn
    NorCal
    2017 Platinum
    No Aftermarket Accessories? I’m not sure what you’re looking for, but there’s tons of Toyota stuff out there. Maybe a little more specificity on what you want,
    And I’m sure you’ll get some good advice or be pointed I the right direction .
  26. Jan 17, 2021 at 4:42 PM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
  27. Jan 17, 2021 at 5:54 PM
    Rgross2112
    Rush
    2020 Silver TRD Limited
    If not I bet there were a bunch of mailboxes involved though
  28. Jan 17, 2021 at 5:58 PM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    Welcome aboard First Last Toyota Kiss My Ass.
    Mods: don't we have a Dear Abby subforum???
    Cpl_Punishment and Tundyfundy like this.
  29. Jan 17, 2021 at 6:21 PM
  30. Jan 17, 2021 at 6:25 PM
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    2022 Ram TRX Level 2
    Welcome. Rodent chewing on electrical is a massive problem everywhere. Trust me, I work in the electric industry.
    post up some pics of this beauty.
