Buzzing/Vibration at 60mph
Discussion in '2.5 Gen Tundras (2014-2021)' started by stautert, Dec 28, 2020.
  1. Dec 28, 2020 at 10:04 AM
    stautert
    stautert [OP] New Member
    Tanner
    Silver 2015 Tundra Limited CrewMax
    Stock right now
    I am getting a pulsing buzz/vibration in the gas pedal and steering wheel right at 60mph. It’s very light but noticeable. If I put the truck in 4hi (at around 45-50) the vibration can be felt as well. Would this be the needle bearing issue? I thought the vibration would normally go away when the truck is put in 4hi? Truck is a completely stock 2015 Limited Crewmax with 90k miles. I have an appointment at the dealer next week but wanted to get any input from you guys. I am thinking ECGS, but like I said the vibration is there in 4wd.
  2. Dec 28, 2020 at 11:23 AM
    timsp8
    NY
    The needle bearing issue usually goes away in 4wd and is present at slower speeds in 2wd. Have you rebalanced or rotated your tires?
  3. Dec 28, 2020 at 11:48 AM
    stautert
    Tanner
    Stock right now
    No, but why would it get more pronounced in 4wd if it were the tires?
  4. Dec 28, 2020 at 1:03 PM
    DMB4x4
    DMB4x4 New Member
    2014 Tundra SR5 CM 4x4
    Try checking or re torquing your UCA’s. If they are a little loose you won’t necessarily feel it at lower speeds but will get some vibrations at highway speeds depending on how loose they might be.
  5. Jan 17, 2021 at 9:44 AM
    stautert
    Tanner
    Stock right now
    Brought it to Toyota, rear right wheel bearing was bad. Vibration is gone.
