Rear End Lean and Uneven Shocks
Discussion in '2nd Gen Tundras (2007-2013)' started by yota_best, Jan 16, 2021.
  1. Jan 16, 2021 at 1:00 PM
    yota_best
    yota_best [OP] New Member
    2014 Tundra SR5 5.7L 4WD Double Cab TRD
    I had a ton of free time last month and it was long overdue so I decided to revamp my whole suspension and tighten my steering. After spending so much time under the truck and changing the ride height I'm paying more attention to details about how it sits and such.
    I noticed my passenger side rear bumper is sitting about half an inch lower than the driver side. So it's NOT tundra lean. Even though I do have a bit of that in the front. Then I measure my shocks and one side is extended almost an inch more??
    The leaf springs do look a little flat but they're even. It's almost like it's just dipping behind the axle if that makes sense.
    Anyone have any ideas on what the issue could be? Maybe a bad body mount bushing?
    08 Tundra DC 5.7L 4wd TRD Off Road with 160k
    Front:
    Bilstein 6112s top setting
    coachbuilder shims(2 driver, 1 passenger)
    Energy Suspension steering rack bushings
    Rear:
    Bilstein 5160s
    Toytec 1.5 Shackles
    Polyurethane leaf spring bushings
    Coachbuilder carrier bearing drop kit
    Coachbuilder abs/brake relocation brackets
    Driver side shock: ~7.75" to center of nut
    Passenger side shock: ~8.25" to center of nut
    Driver side leaf to frame: ~6.5" to bottom of leaf
    Passenger side leaf to from: ~6.5" to bottom of leaf
  2. Jan 16, 2021 at 1:12 PM
    frichco228
    frichco228 Valued Member
    Frank
    Virginia
    2016 Crewmax 4WD, TRD Offroad
    12+ year old truck with 160k miles, the springs are likely showing their age. Toyotas lean some anyway, add in age and miles and I think what you are seeing would be considered normal.
    Hbjeff likes this.
  3. Jan 16, 2021 at 1:27 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Measure the bumper lean full vs empty gas tank.
    I agree though, 160k miles on relatively soft leaf springs, i would expect them to be worn out imo
  4. Jan 16, 2021 at 1:36 PM
    yota_best
    With that much difference in shock extension do you think that’ll shorten the shock life?
  5. Jan 16, 2021 at 2:21 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Doubt it. They are both operating within their range. Is the shock angle the same left and right?
  6. Jan 16, 2021 at 4:31 PM
    Half Assed
    Half Assed me ne frego
    Heartland Florida
    10 crewmax, 07 reg cab
    The shocks are mounted different. One is behind the axle and the other is ahead.
    Measure from the axle housing to the frame on each side.
  7. Jan 17, 2021 at 8:30 AM
    TechWrench
    TechWrench New Member
    Gary
    Hawley, PA
    '08 Tundra White, DC SR5 5.7, TRD Off Road Pkg
    Toyota Bedliner, Under Cover Bed cover, Oem back-up camera system.
    Unless you have coil overs or air assisted lift shocks, the rear shocks have nothing to do with ride height. All standard shocks do is control suspension rebound (bounce). Rear ride height is controlled by the springs/shackles and load placed on the rear of the truck. The difference in the amount of shock extension is a direct result of a difference in spring lift between left/right sides.
    Stewie likes this.
  8. Jan 17, 2021 at 1:34 PM
    yota_best
    Thanks for the feedback. The leaf packs do look fairly flat. Looks like I'll be researching leaf spring replacement options. Thanks again guys
    Hbjeff likes this.
