Interior
Discussion in '2nd Gen Tundras (2007-2013)' started by andymckinnon, Jan 15, 2021.
  1. Jan 15, 2021 at 5:38 PM
    andymckinnon
    andymckinnon [OP] New Member
    Andy
    2011 White Tundra SR5 double cab
    What is this?
  2. Jan 15, 2021 at 5:45 PM
    KingsAustin
    KingsAustin Grey Goose II
    Morgan County, AL
    2021 Limited Night Shade
    BakFlip MX4, Gator All Weather mats, Console Safe, Ceramic Tint, Roadmaster Active Suspension, Interior/exterior LED conversion, Wireless console charger, AJT designs.
  3. Jan 15, 2021 at 6:06 PM
    side curtain air bag. Reading the manual helps.....:thumbsup:
  4. Jan 15, 2021 at 6:15 PM
    bleach
    bleach MEME Fiend
    DJ
    Battle Ground, WA
    1991 White Xtra-cab SR5 4X4 V6 5 speed 148K
    That's where you add the blinker fluid.
  5. Jan 15, 2021 at 6:16 PM
    Mattyc
    Mattyc <insert custom title>
    Matthew
    NY
    2008 Limited Rock Warrior
    Not stock
    It’s an aftermarket microphone
    bleach and Black Wolf like this.
  6. Jan 15, 2021 at 6:16 PM
    BravoDeltaRomeo
    Bruce
    MB Canada
    2019 Cavalry Blue Tundra CM
    Maybe a little more info in your title or post would help?
    It's like starting a thread called "Truck". o_O
  7. Jan 15, 2021 at 6:17 PM
    or....."beer" which would be ok........:burp:
  8. Jan 15, 2021 at 6:18 PM
    That sh*t really works!!!
  9. Jan 15, 2021 at 7:05 PM
    Cruiserpilot
    Cruiserpilot New Member
    Jon
    Ladysmith
    2010 5.7 RCSB 4WD
    Black Wolf likes this.
  10. Jan 15, 2021 at 8:58 PM
    Half Assed
    Half Assed me ne frego
    Heartland Florida
    10 crewmax
    looks like a harbor freight tool store to me
  11. Jan 15, 2021 at 11:29 PM
    Nemesis
    Nemesis New Member
    sunglass holder
  12. Jan 16, 2021 at 8:51 AM
    audiowize
    audiowize New Member
    Paul B.
    2008 Tundra SR-5 4x4 5.7
  13. Jan 16, 2021 at 9:11 AM
    AZTundra
    Paul
    Phoenix, AZ
    Appears to be the enterance of a Goodwill store, but I cannot clearly make out the listed business hours.
    BravoDeltaRomeo and Haggis777 like this.
  14. Jan 16, 2021 at 9:17 AM
    Alt0174
    Alt0174 New Member
    Virginia
    2021 Limited
    Chromerectomy
    It's the flux capacitor receptacle...not sure why Tundras have those though, no way you can produce 1.21 Gigawatts!
  15. Feb 9, 2021 at 12:09 PM
    Cruiserpilot
    Jon
    Ladysmith
    2010 5.7 RCSB 4WD
    Just there to offset opposite grab handle to hold the headliner in. Nothing else, simple.
    JFA2E1A66-417A-444D-B80A-A8BC98949C9C.jpgF3C4BF07-C395-4406-9418-733DA35E0F4F.jpg005FBD3D-7115-4690-8634-FF3D4C210355.jpg302C51D2-DB16-4FFD-9933-00A1B8134CB3.jpg
    bleach likes this.
  16. Mar 7, 2021 at 11:33 AM
    andymckinnon
    Andy
    Thank you! Imma start running that microphone to it then. Appreciate the actual intelligent response!
    Cruiserpilot[QUOTED] likes this.
  17. Mar 7, 2021 at 3:40 PM
    Cruiserpilot
    Jon
    Ladysmith
    2010 5.7 RCSB 4WD
    Most people pull the grab handle A Pillar and just clip the microphone about 3” from the top. To
    go straight to this plug, you have to remove that anyway to feed the wire. BTW, to remove the
    grab handle plugs. Insert plastic flat blade into the upper edge of the upper plug. If when you
    see it start to come out and it’s got a plastic tail insert that slides in, then keep prying it out
    slowly and so the ‘tail’ keeps coming out. It will allow the tab on the other side to just slide out.
    It seems counterintuitive but seems Toyota did it so when you reinstall, you insert the short tab
    and then slide and push down on the other side that has the tail, and it just clicks into place.
    If you do this right, you won’t damage the plastic housing around the plug.
    I hope this makes sense.
    If you look on my pound puppy thread, there are pics there.
    airosey likes this.
  18. Mar 8, 2021 at 4:24 AM
    Danny3737
    Danny3737 New Member
    2012 Tundra Limited Platinum
    I use this brand
