What battery sizes can the 2010 Tundra take?
Discussion in '2nd Gen Tundras (2007-2013)' started by Mariana, Jan 14, 2021.
  1. Jan 14, 2021 at 1:18 PM
    Mariana
    Mariana [OP] New Member
    Hi. I"m new here..I have had a 2010 Tundra for 11 years now. I absolutely love it! Especially since it drives like a car..so smooth! Anyway my husband died in 2016..so, now I'm trying to learn about the car as I need to.. Now, I need to replace the battery. What size battery does the 2010 Tundra, 4.0, V-6 take? and, if I can't find that battery, since I live in Central America...what variations in the size are acceptable?? For example, I think the correct size is 24F, 575 CCA. If I can't find that, can I replace it with an L24, 530 or a L27, 570? I appreciate all the help!
    WILLINH, YardBird and Rica25 like this.
  2. Jan 14, 2021 at 2:44 PM
    frichco228
    frichco228 Valued Member
    Frank
    Virginia
    2016 Crewmax 4WD, TRD Offroad
    Main things are to replace with a battery that fits in the battery box/location. You can often fit a slightly larger battery in there. Next, the replacement battery should have the same or more CCA- cold cranking amps.
    24F is correct, however you may be able to fit a 27F in there. And I think the CCAs you listed seem low, 600-750 CCA seems more appropiate.
    Mariana[OP] likes this.
  3. Jan 14, 2021 at 3:47 PM
    YardBird
    YardBird Native San Diegan
    Jonesy
    2005 RCLB
  4. Jan 14, 2021 at 3:59 PM
    Rgross2112
    Rush
    2020 Silver TRD Limited
    Welcome from Pennsylvania
    2001sr5 _yota and Mariana[OP] like this.
  5. Jan 14, 2021 at 4:18 PM
    Bucks04
    Bucks04 New Member
    2013 TRD Tundra
    Working on it
    Welcome fro ILL. Sorry to hear about your husband, good luck with truck ,there is plenty of help right here. GO WITH 27F , I have 4.6 in 2013. Went with OEM,
    NewImprovedRon and Mariana[OP] like this.
  6. Jan 14, 2021 at 4:27 PM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    Where in Central America are you?
  7. Jan 14, 2021 at 5:14 PM
    A 27F will fit. I put the 27F out of my 2020 into my 2013 before I sold it.
  8. Jan 15, 2021 at 1:09 PM
    Mariana
    Hi everyone! I never met so many people who love trucks this much! But it is fun, I get so many compliments on my Golden Beauty! ha! Anyway, I've been a bit leery about putting the 27F with higher CCA's in because what I read on the internet is that if your alternator has to work that hard to recharge the battery, you can where out the alternator. That's why I wanted to just go with exactly what the manufacturer says, but I don't remember what the original battery size was, I just am pretty sure the battery plate won't fit a 27F, although there seems to be enough room to put the battery in anyway..Don't want alternator problems... Anyone know what the original manufacturer battery size is?
    Hi Baker shack, I am in Nicaragua, we actually shipped the truck over here and it is 1 of 2 Tundras in all of Nicaragua, that's why I can't seem to find exact parts.
  9. Jan 15, 2021 at 1:14 PM
    Mariana
    Hello, yes the battery plate that the battery sits on seems to fit the 24F size, but the most CCA I can find in that size is 250 instead of 275. I was concerned about putting a larger battery in because I researched on the internet, and it said that a larger battery could where out the alternator faster.. Anyone know about that? This is why I'm inclined to go with the exact specifications that the truck came with...which I think is the 24F. 575. I appreciate good, informed advice!! Nice to talk to you all!
  10. Jan 15, 2021 at 1:20 PM
    timsp8
    NY
    I have had dual group 25 batteries in my truck for years and no issue from the alternator. People run larger batteries all the time with no issues.
  11. Jan 15, 2021 at 1:29 PM
    frichco228
    Frank
    Virginia
    Original battery is 24F. Look for one with at least 600CCA, more CCA the better. You will probably find that size with CCA ranging from 600 to 750CCA.
    But like I said earlier, 27F will fit and work fine too.
  12. Jan 15, 2021 at 1:42 PM
    audiowize
    audiowize New Member
    Paul B.
    2008 Tundra SR-5 4x4 5.7
    This is an old wive's tale and the exact same argument could be made against using a battery with insufficient CCA, as it will deplete itself more from starting and present a more difficult load to recharge than a more robust battery might otherwise.
    Mariana[QUOTED][OP] likes this.
  13. Jan 15, 2021 at 5:28 PM
    Mariana
    I did not know people do larger batteries frequently..but I see pretty much everyone agrees with you. Thank you for the advice.
  14. Jan 15, 2021 at 5:30 PM
    Mariana
    Thank you audiowize...you're right I did hear the same about the lower CCA too..Thanks again!
  15. Jan 16, 2021 at 3:48 AM
    diavel
    diavel New Member
    Simon
    Tundra Platinum Flex Fuel 4x4
  16. Jan 16, 2021 at 6:27 AM
    Bucks04
    Bucks04 New Member
    2013 TRD Tundra
    Working on it
    The bigger the battery the less it has to work to start truck ,and that's easier on the charging system also. Especially if you add alot of lights wired directly to battery later. Go with the 27F
  17. Nov 30, 2024 at 9:46 AM
    2001sr5 _yota
    2001sr5 _yota New Member
    Dev
    01 tundra 2r5
    3in cat back. Rest stock
    fellow Pennsylvanian got to love pensyltucky!!
  18. Nov 30, 2024 at 6:02 PM
    Cruiserpilot
    Cruiserpilot New Member
    Jon
    Ladysmith
    2010 5.7 RCSB 4WD
    When it comes to batteries size matters. Bigger is always better. 24F is factory. Not sure about the output as my 5.7 has
    150Amp alternator. Do you know your alternator output? Once the new battery is in, have a voltmeter check done at
    the positive terminal of the battery and ensure that the voltage charge is sufficient. But if everything was working properly
    this should just be a formality, it's just worth doublechecking.
  19. Apr 8, 2025 at 8:29 PM
    FrankJake
    FrankJake New Member
    Frank
    So Cal & Hawaii
    2007 Limited Edition 4x4 Leather interior Doublecab 5.7
    Low Mileage. Immaculate all leather interior. Truck runs like a champ. No issues. 5.7liter million mile motor that has had every oil - - Tow package with tow mirrors. - King reservoir shocks front and rear - 6” Pro Comp Lift - SPC Upper Control Arms -20” Monster wheels w/35x13.50 Cooper STT Pro’s - Volant air intake - Maganaflow dual-in/ dual-out exhaust - onboard ViAir compression with tank - Kenwood upgraded audio for CarPlay, etc - Bought from original owner who has done too much to remember or list. - a few things I need help, suggestions and SUPPORT with that just need fixing
    My goal once my nearly new battery goes out is to have someone build me a spot for a 2nd battery. Probably overkill. But I’d like to have a power inverter installed but don’t want to get stuck with two dead batteries. That’s me. Others will argue it’s unnecessary but it’s what I want. A 27 should fit fine in your truck, a little more juice than a 24.
    TRIVER3207 likes this.
