How Often Do You Adjust Bass Control Knob?
Discussion in 'Audio & Video' started by FISHN43, Jan 8, 2021.
  1. Jan 8, 2021 at 11:01 AM
    FISHN43
    FISHN43 [OP] New Member
    Ohio
    2020 Super White TRD Pro
    I ordered-and is currently on its way-the OEM Audio+ JBL enhancement system for my truck. The system includes a separate bass control knob that I’m not sure where I’m going to mount or if I am going to mount it at all. In my past vehicles I’ve always set the stereo EQ for the best sound for me and pretty much left it alone after that (maybe slight adjustments through the years but never on the fly for every song). Seems like most aftermarket “systems” nowadays include a separate bass control knob that is mounted independently on the dash or console area. I’ve never had a separate bass control knob. So my question is, no mater what system you have, if you have the separate bass control knob, how often do you actually adjust it?
  2. Jan 8, 2021 at 11:23 AM
    apwisher
    apwisher New Member
    Everett, WA
    2007 CM SR5/TRD 4x4 White
    canopy, TRD Sway, audio
    I think it depends on your music source. Some sources, say Pandora, or other streaming can vary pretty wildly in sound quality. If I stream from my Plex Server I get a mix of FLAC amd MP3 sources. That said, I have a bass knob on my system and use it all the time for both the reasons above and when I just want to rumble.
    ForceV4 and Wynnded like this.
  3. Jan 8, 2021 at 11:24 AM
    apwisher
    apwisher New Member
    Everett, WA
    also... I have an Alpine amp, and the knob is mounted to the left of the head unit in the bezel. However, I have a 2nd Gen.
  4. Jan 8, 2021 at 11:30 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Pretty much this ^. Every source can be different, so can recording levels. Some radio station DJs/announcers "color" their voices pretty bass heavy as well. I find this particularly annoying, so I adjust.
  5. Jan 8, 2021 at 11:32 AM
    Netmonkey
    Netmonkey Don't be a Dumbass
    Georgetown, TX
    I use the bass knob all the time. Here is where I installed mine:
    For normal listening, I keep it at about 1/3. When I want to blast a song, I turn it up all the way.
    My system has so much bass and it would be too much to keep it at max all the time.
    ScottB, Haggis777 and Trooper2 like this.
  6. Jan 8, 2021 at 11:35 AM
    jalam321
    jalam321 New Member
    2018 Tundra CM Platinum 4x4 and Sequoia Platinum 4x4
    I use it all the time. Some songs need more or less bass. I like that I can adjust it on the fly without having to go into the audio control settings on head unit.
    Trooper2 likes this.
  7. Jan 8, 2021 at 11:36 AM
    mountainpete
    mountainpete Explore more
    2018 Cement Crewmax TRD
    Function before sparkle.
  8. Jan 8, 2021 at 12:28 PM
    robabeatle
    robabeatle New Member
    AZ
    2002 Tundra 4x4 LTD AC
    Bilstein 6112 & 5160, Katskinz, audio upgrades
    My DSP has a knob that controls the sub volume only. I have it right next to the center console and adjust it for almost every song.
  9. Jan 8, 2021 at 12:58 PM
    FISHN43
    Ohio
    This makes sense. About 99% of the time I play my music through Apple Music via Bluetooth. But I have noticed the sound difference between the different sources.
  10. Jan 10, 2021 at 10:51 AM
    james33440
    james33440 New Member
    James
    2010 Tundra Double Cab
    Magnaflow Exhaust
    I use Apple Music all the time but some songs are definitely containing more bass than others. However, I have my amp’s gain set with the bass knob all the way up, so I know when it’s cranked up there’s no clipping going on. Sounds great.
    But I will soon change my setup. It’s time for more bass. Probably do the 4 8’s bandwagon under the rear seat or say the hell with it and do a blow through with either a pair 15’s or 18’s. Have to do some more research to see how much space I would give up in the truck bed.
  11. Jan 13, 2021 at 7:52 PM
    ScottB
    ScottB New Member
    Scott
    Long Island
    2019 Barcelona Red 1794
    I had the OEM Audio+ JBL enhancement system, I found that I had to adjust the bass frequently. Also depends on volume level, as the factory JBL head unit drop the bass off as the volume increases. The bass knob was installed in the dash to the the left of the steering wheel. I really like what NetMonkey did with the bass knob, that is the perfect location.
    Netmonkey likes this.
  12. Jan 13, 2021 at 8:18 PM
    NoRcptn
    NorCal
    2017 Platinum
    How often?
    Every.Damn.Song.
    1lowlife likes this.
  13. Jan 13, 2021 at 8:19 PM
    shackleford rusty
    shackleford rusty New Member
    TEXAS!
    absolutely love my oem jbl enhancment! running the dual sub. sound stage is PERFECT!
    you will believe it soon enough, but the jbl speakers sound pretty damn good once you install the oem acoustical filters at the factory amp.
    listen to a lot of ac/dc, zep, floyd, and other great classic rock. was concerned about the 8" subs, but they do deliver. rear view and side mirrors move w/ the music. i usually run about volume 45-55. i like it loud and clear. (however, it's not obnoxious)
    thunderstruck absolutely screams!
    on the rare day i listen to rap, bone thugs will thump the subs. and i turn the bass knob down to about 50%
    my bass knob is at 75%, and i never adjust. (except for tha bone thugs) my head unit settings are pretty much dead center at trebble, mid, and bass. i mostly listen to music from my iphone.
    make sure your phone eq is set to flat. (read that on a thread here some where) makes a difference.
    listened to some old music from the wifes android (stuff she "sourced" from unknown and a LONG time ago). was disappointed in the sound, however, i had to consider the source, or lack there of.
    music i have legitimately purchased through itunes, and play through my phone, sounds really great.
    could not be happier w/ my decision!
  14. Jan 13, 2021 at 8:31 PM
    Hightide
    chadington von banks
    Abalama
    Magic School Bus
    Virtually, every song as needed.
  15. Jan 13, 2021 at 10:01 PM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    Maybe not every song, but if you change channels or genre of music, you will probably need to adjust it a touch.
    Although sometimes it is indeed needed every song when iPhone shuffling ...:eek2:
    Depends on what you are using as far as a input source.
    I listen to a lot of XM.
    Even though my Kenwood HU has a SiriusXM SXV300V1 Tuner, I now run Sirius/XM thru my iPhone app with wireless Carplay.
    The sound is a 1000X better thru the app than using the satellite tuner source.
    I mounted my Alpine knob on the console so it literally sits at my fingertips as I drive.
    Right arm rests on the console, right hand usually rests on my TRD shift knob..
    I never even have to look at it or look to reach for it, I just put my hand down on the console and adjust it..
    4DD469E0-92EA-4AA9-8767-41A633C7CCDB_zps_e9846c7d644359abaceea037700758d01526c349.jpg
    WillTunBlack20 and FISHN43[OP] like this.
  16. Jan 14, 2021 at 6:06 AM
    ScottB
    ScottB New Member
    Scott
    Long Island
    I concur this statement
  17. Jan 14, 2021 at 6:13 AM
    bsktball55
    bsktball55 New Member
    Missouri
    16 Tundra TRD Pro
    Bakflip MX4 Toneau cover Esp storage Audio system (Helix speakers, JL audio amp and sub) Front windows and windshield tinted LED interior and bed lights
    I never touch mine, but I a only have a 10 in sub so I'm not shaking the truck by any means.
    AZBoatHauler and FISHN43[OP] like this.
  18. Jan 15, 2021 at 7:42 PM
    Minarets
    Minarets New Member
    Nashville
    2021 TRD PRO
    What is the JBL OEM enhancement?
  19. Jan 15, 2021 at 7:46 PM
    shackleford rusty
    TEXAS!
    Minarets[QUOTED] likes this.
  20. Jan 15, 2021 at 7:51 PM
    Minarets
    Minarets New Member
    Nashville
    2021 TRD PRO
