Pics of plus sized tires on Pros
Discussion in '2.5 Gen TRD Pro (2014-2021)' started by ProTundra8806, Mar 26, 2017.
  1. Mar 26, 2017 at 3:44 PM
    ProTundra8806
    ProTundra8806 [OP] New Member
    Robb
    17 Trd Pro Tundra
    I know this has probably been beat to death but can yall post some pics of plus sized tires on some pros. If suspension mods what are they and sizes. Thanks. Stock now buy looking at tires, don't wanna lift and lose my ride quality.
    Robb
    CJ21 likes this.
  2. Mar 26, 2017 at 3:56 PM
    ktharbour6
    ktharbour6 New Member
    2016 Toyota Tundra TRD Pro MGM
    Check out the 295/70 and 275/70 tire threads.
  3. Mar 26, 2017 at 3:56 PM
    ktharbour6
    Oh, better check out tundratalk.net under the pro section for those threads I just listed.
    trayday and lionix like this.
  4. Mar 26, 2017 at 7:50 PM
    bobeast
    bobeast really old member
    Bob
    Hollister, CA
    2008 DC
    TundraTss, trayday, PaRunnerd and 2 others like this.
  5. Jun 8, 2017 at 12:21 PM
    dmeneses1983
    dmeneses1983 New Member
    Dennis
    2016 Silver Tundra
    35s look aggressive but that requires a lot of fender modding
  6. Jun 13, 2017 at 11:34 PM
    TRDpro619
    TRDpro619 Follow My Build on Instagram:TRDorcaTUNDRA
    San Diego
    TRD Pro CM
    I'm on 35s no mods bone stock don't notice any rubbing at all 35x11.5 r18 nitto trail grapplers
  7. Jun 14, 2017 at 6:25 PM
    allybear21
    allybear21 New Member
    Walker
    2017 Toyota Tundra 1794 Barcelona Red
    Looking good!
    treihing likes this.
  8. Jun 16, 2017 at 5:21 AM
    Rbtrd
    Rbtrd New Member
    So Cal/Oregon
    2017 Tundra trd pro CM wht
    275/70 duratracs. No mods no rubs....all goodimage.jpg
    831mic, nasher75, bulldog93 and 4 others like this.
  9. Jun 16, 2017 at 5:23 AM
    Rbtrd
    Rbtrd New Member
    So Cal/Oregon
    bulldog93 and 16TRD like this.
  10. Jun 16, 2017 at 6:12 AM
    TRON likes this.
  11. Jun 16, 2017 at 6:57 AM
    KOZ
    KOZ New Member
    Indiana
    2008 Toyota Tundra SR5 Regular Cab
    TRD Supercharger TRD Lowering Springs TRD Front Sway Bar TRD Rear Sway Bar URD Pulley 2.345" TRD 22" Wheels SOS 2.5"/4.5" Lowering Kit StopTech Big Brakes Front & Rear JBA Headers JBA Cat Delete w/O2 Sims Dirty Deeds Budget Dump
    7" BDS lift with 37" BFG A/T KO2's
    sulverado7, Munk, CJ21 and 5 others like this.
  12. Jun 29, 2017 at 7:26 PM
    Justin9
    Justin9 New Member
    Justin
    Utah
    2017 Cement TRD Pro
    4" Ready Lift 295/70/18 Nitto Ridge Grapplers.
    CJ21 and marcelo73 like this.
  13. Jun 29, 2017 at 7:40 PM
    Over the LINE
    Over the LINE New Member
    New Orleans
    2016 Limited CM 4x4 2025 SR5 CM 4 x 4
    295/65/18 Duratracs. Not a Pro but I am on a 2/0 lift so the exact same stance.
    dbrown and CJ21 like this.
  14. Jun 29, 2017 at 7:50 PM
    Voyagermike
    Voyagermike New Member
    California
    295/70r18 Cooper Discoverer ST MAXX
    1in Bora wheel spacers on front only.
    Inner wheel well liner has been trimmed. Rubs the mud flaps in reverse.
    1rufftrdpro, CJ21 and Watt maker like this.
  15. Jun 29, 2017 at 10:05 PM
    boardude
    boardude I am Batman
    Kris
    Tucson, AZ
    [YODAGAN]
    2015 Inferno Ex-Pro
  16. Jun 30, 2017 at 10:32 AM
    trdlife
    trdlife Toyota Master Technician
    ICT
    2015 Tundra TRD PRO
    'TRD REX'
    35x12.5r18 with coachbuiler shims up from & +3 shackles in he rear
  17. Jun 30, 2017 at 10:49 AM
    lionix
    lionix The Grey Moose!
    Cape May, New Jersey
    2017 Tundra TRD Pro CM Cement
    BD Lights, Any Time Fog, Coachbuilder, Pelfreybilt, Bakflip, Custom Bed Rack w/ Tent
    Not rubbing on mud flaps?
  18. Jun 30, 2017 at 11:01 AM
    trdlife
    ICT
    2015 Tundra TRD PRO
    'TRD REX'
    none, I have a 1/4 spacer on the front. no rubbing at all.
    But if your having some rubbing with the mud flaps, I do have a trick for you. get a 10mm socket for the flap screws and a heat gun(harbor freight will do just fine). Now loosen the screws on the flap you dont have to take them out. Put heat to the flap and push back and up on it(gloves will help from burns) and kinds form it against the frame and then tighten the screws. should give you just enough clearance. If you need more pull the flap off take a drill and bit matching the bolt size and trim straight down so the flap will go up.
    bulldog93, ARES, texbambam and 2 others like this.
  19. Jun 30, 2017 at 11:03 AM
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    Are your 37's 13.5 wide??
  20. Jul 1, 2017 at 11:18 AM
    texbambam
    texbambam New Member
    Tundra TRD PRO sand
    I am on 35's with stock PRO suspension886102f898bf03c037042b5dd14c3b3d_219521afd5667a50557af11e6698331dc1545d59.jpg
  21. Jul 1, 2017 at 11:29 AM
    boardude
    Kris
    Tucson, AZ
    [YODAGAN]
    2015 Inferno Ex-Pro
    That front bumper helps with clearance too. Looks good!
  22. Jul 1, 2017 at 8:27 PM
    bobeast
    Bob
    Hollister, CA
    2008 DC
    That's cheating ;)
  23. Jul 1, 2017 at 9:49 PM
    texbambam
    Tundra TRD PRO sand
    I did not have any problems with rubbing before I put the new NFab bumper on...I did remove the front mugflap and hit the front liner with the heat gun. It was fine after that.
  24. Jul 2, 2017 at 9:32 AM
    texbambam
    Tundra TRD PRO sand
    The rims seem to have a huge influence on whether you have rubbing or not. These are rock warrior wheels and I chose them for that reason...and they are forged and weight is less.
    Jsena and lionix like this.
  25. Jul 2, 2017 at 10:12 AM
    boardude
    Kris
    Tucson, AZ
    [YODAGAN]
    2015 Inferno Ex-Pro
    Yep the offset on the wheels are a big factor on clearance. You would have a hard time running 35's on the stock wheels.
    Jsena likes this.
  26. Jul 2, 2017 at 11:19 AM
    jfrd30
    jfrd30 Lead, Follow, or Get the Hell Out of My Way
    2013 TRD Tundra
    Wow........Nice Ride!!!
    Jsena and texbambam[QUOTED] like this.
  27. Jul 3, 2017 at 2:37 PM
    KOZ
    KOZ New Member
    Indiana
    No, my 37's are 12.5"
    Jsena[QUOTED] likes this.
  28. Jul 3, 2017 at 3:00 PM
    R0CKETMAN
    R0CKETMAN IG: @rocketmanmtb
    NGAMTNS
    '17 TUNDRA TRD PRO CEMENT ‘15 TUNDRA SR-5 WHITE
    What the RW offset?
    Looks nice and tucked
  29. Jul 3, 2017 at 3:21 PM
    lionix
    +50mm
    Stock is +60mm
    texbambam likes this.
  30. Jul 3, 2017 at 8:04 PM
    R0CKETMAN
    NGAMTNS
    Roger that so that 4/10s with the 12.5 must put you pretty close to uca I'm guessing.
    Jsena likes this.
