  1. Jan 13, 2021 at 5:57 PM
    YotaBro
    YotaBro This forum will make me broke
    Calvin
    FL
    2017 Cement Grey Tundra TRD PRO
    Lots of shenanigans.
    I am short as well and just grab the steering wheel. Eventually I'll swap out the handle for my short butt but for now the steering wheel works just fine.
  2. Jan 13, 2021 at 5:59 PM
    Jmontgomery283
    Jmontgomery283 New Member
    Jacob
    2016 Toyota Tundra SR5
    I had them installed and the shop included it with the install kit for the flares.
  3. Jan 13, 2021 at 6:01 PM
    Good deal....most shops wouldn't have a clue. After seeing what happened to my 2013, I put it on my 2020 after I had them Line-X'ed.
  4. Jan 13, 2021 at 6:03 PM
    itstorbs
    itstorbs New Member
    Jack
    Fort Bragg
    2021 SR5 Trail
    Alexstundra[QUOTED] likes this.
  5. Jan 13, 2021 at 6:54 PM
    ohreary
    ohreary Party!
    2020 Platinum
    First time backing a trailer into a parking spot(s). How’d I do?146E283F-B4D5-4C29-9172-5EC64287E600.jpg
  6. Jan 13, 2021 at 6:56 PM
    YotaBro
    Calvin
    FL
    10/10
  7. Jan 13, 2021 at 7:03 PM
    War_Wagon312
    War_Wagon312 Puddle Dodger
    Rich
    2025 sequoia MGM TRD PRO
    Stock horse
    Nailed it!
  8. Jan 13, 2021 at 7:04 PM
    TrenThom86
    TrenThom86 New Member
    Trent
    NW Louisiana
    2021 TRD Pro Lunar Rock
    Towed 250 miles to Petit Jean State Park in Arkansas. First trip since I got my tundra.
  9. Jan 13, 2021 at 7:07 PM
    War_Wagon312
    Rich
    Stock horse
    Hooked up an HDMI, rca’s, remote wire and ran power wire for amp. Just waiting on box to be built for sub install.
  10. Jan 13, 2021 at 7:20 PM
    Fotnot
    Fotnot SSEM #69; LRCS#1
    Andy
    SW Louisiana
    Swimmers gonna swim
    Plz don't park next to me:goingcrazy:
  11. Jan 13, 2021 at 7:24 PM
    Kdogg77
    Kdogg77 If it ain't broke, it will be...
    Ken
    Central Cali
    2017 Tundra Crewmax
    6" RC suspension lift, 18" Pro Comp wheels, 35x12.5x18 tires, RC front/rear bumpers, RC Grill insert, Spider No Drill Roof Rack, Lighting by RC and Cali Raised. Interior mods include AJT Designs, Pioneer, and Rockford Fosgate.
    What sliders are those? Thanks.
  12. Jan 13, 2021 at 7:31 PM
    RobertD
    Robert
    DFW, Texas
    Nailed it! Smart to try when there was an empty lot. Takes some practice but you'll get the hang of it :thumbsup:
    ohreary[QUOTED] likes this.
  13. Jan 13, 2021 at 7:33 PM
    Astom22
    Astom22 New Member
    Bob
    Celina, TX
    2021 SR5 Tundra Crewmax 4x4
    Bakflip G2 Tonneau Cover
    Do you have a link to your amber lights in the snout? Those look nice, but I can't find a set I like.
    heyacker likes this.
  14. Jan 13, 2021 at 7:40 PM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    Started planning my anytime camera install. First order of business was to take the loose leads and make them into a single plug-n-play harness.
    The camera lead has the terminal pin on it, but isn’t clipped in yet so I can run it through the fire wall.
    Next I’ve gotta get some more wire so I can take the switch leads and extend them to make up the other side. I plan on making it long enough to eventually put the switch behind the shifter. That harness will join the camera power lead with the relay green, and will also have the ground lead. At least that’s my plan...
  15. Jan 13, 2021 at 7:57 PM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    I'm right at 6' and 225#. I'm also getting older. I was afraid that I would damage the steering wheel or something in the column if I pulled myself in using the steering wheel. It's really not made for that. I also use try to avoid sliding into and out of my seat - trying to keep from breaking down the side support. The grab handle helps me with that too.
  16. Jan 13, 2021 at 8:28 PM
    ChattTundra21
    ChattTundra21 New Member
    Michael
    2016 Magnetic gray
    Eibach 3/1 with Toytec 1.5 Shackles. Nitto Trail Grapplers 295/70/18 with 1.25 wheel spacers. Borla muffler swap.
    Did a buddy's Tundra the same week. He went with the Bilstein 5100 lift instead so we could compare. They ride similar, but I definitely got more lift out of mine. Soaks bumps up better then stock and the shackles keep the bed stiffer.
    jonclark96[QUOTED] likes this.
  17. Jan 13, 2021 at 8:38 PM
    Hightide
    chadington von banks
    Abalama
    Magic School Bus
    Almost...
    Hint: Turn the bottom of the steering wheel the direction you want the trailer to go.
    Small inputs go a long way.
  18. Jan 13, 2021 at 9:01 PM
    a522467
    a522467 Life’s short. Live now.
    Michelle
    Ohio
    2020 Black Tundra Doublecab 4X4 SR5 with SX pkg
    Rear spring upgrade, rear shock upgrade, front & rear sway bars, bed step, bed mat, console organizer & tray, black lug nut covers, rear underseat storage box, black seat covers, Bluetooth CarPlay adapter, LED fogs, blue footwell lighting, LED cargo, reverse, tail, and stop bulbs, tinted tail and 3rd stop/cargo lights, tinted glass all around, tinted front emblem, matte black tailgate emblem inserts, retractable tonneau cover w/trac system and load bars, front facing camera, 8” exhaust upgrade, LED bed lights, 8-ball shifter knob, shifter boot, LED headlights, custom wheel center caps, 3”x30’ tow recovery strap, bed rail clamps, LED puddle lights, phone mount, OBD2 scanner, touchscreen glass protector/overlay, trailer hitch lock, tire traction aid, tinted license plate cover, power relay module, 6-way fuse block with cover, stainless mesh cowl screens, LT265/70R18 A/T tires, driver’s side swing case toolbox, dual air horn kit, rear Husky Liner, cat converter theft deterrent covers, front & rear dash cam, LED tail light bar, trailer plug wiring harness, locking fuel door, matte black interior door handles, glovebox & fuel door keyhole decals, TUNDRA sill plates decals, chalk bag cup holder / trash can, HD Roadmaster active suspension kit, HD front struts, Backlit window control panel, tailgate gap cover, matte black radio surround. https://www.tundras.com/threads/740-yota-2020-sr5-4x4-dc-w-sx-pkg.79742/
    I just noticed on a YouTube video that @2020Platinum mounted his front camera a bit higher on the grille. Might just need to just try a few spots and see what works best for you.
    2020Platinum likes this.
  19. Jan 13, 2021 at 9:04 PM
    AZBoatHauler
    So.Arizona
    I’m going blue for now.
  20. Jan 13, 2021 at 9:23 PM
    heyacker
    heyacker New Member
    Glad it worked out!
    JerryH[QUOTED] likes this.
  21. Jan 14, 2021 at 5:26 AM
    Badknees
    Badknees New Member
    2016 White Tundra 1794 CM 4X4
    TRD Pro BBS Wheels, TRD LED Headlights, Rigid LED Fog lights, 040 TRD Grille, 040 Hood Bulge, Black Center Valence, Driver's Grab Handle, TRD Pro Fox Suspension, 1.00" BORA Wheel Spacers, 1.5" Rear Shackles, TRD Front and Rear Sway bars, 295/70 R18 Cooper Discoverer AT3 XLTs, Full Size Spare, TRD Dual Exhaust, Console cover, Console Organizer, Husky Liner X-act Contours, Tinted Front Windows, Stubby Antenna, Autoventshade Deflectors, Duplicolor Painted Calipers, 040 Painted Front End Caps, Undercover Armor Flex Bed Cover
    I'm just fat and tired..
  22. Jan 14, 2021 at 5:29 AM
    CorsoTundra
    CorsoTundra This is the way
    North GA
    2021 Cement Trail Edition
    Toytec Aluma 3/1.5, Pro headlights, OEM LED fog lights, AJT chrome delete, interior/exterior LEDs, front TRD sway, 18x9 Method Roosts, 285/75/18 Toyo A/T 3, RCI engine skid,
    and bad knees too, I guess.....lol
  23. Jan 14, 2021 at 5:35 AM
    Badknees
    Badknees New Member
    Right!...forgot to mention being chronologically challenged too. Anyhow, makes me feel young again to swing out on the grab handle.
    WILLINH likes this.
  24. Jan 14, 2021 at 5:47 AM
    Toptalktoyota
    Toptalktoyota New Member
    2020 DC SX
    Tha
    Thanks for the tip!
    I learned a long time ago how to back a trailer up but we used an old Willies Jeep with the trailer. I always turned my head and looked back, never learned to back it up using mirrors.
    Now with the Tundra I need to use the mirrors and hard to get used to it.
    Hightide[QUOTED] likes this.
  25. Jan 14, 2021 at 6:07 AM
    mgm16trdpro
    Northern NJ
    2016 mgm trd pro crewmax
    I've been doing it so long I can pretty much back any combo without thinking, probably hardly even got to look lol. However I remember when I very 1st learned I would tell myself until I got use to it, turn the wheel the opposite direction from the way u want the trailer to go. Once you get it angled just follow it back. You'll get use to it, takes practice. Each trailer is different too. Longer ones are easier since it takes more cutting to get going, theres more forgiveness with length. The hardest are the little ones like a log splitter or something short n small, every tiny little wheel moves makes a big impact on the trailer cutting and they cut fast. Good luck.
    NewImprovedRon likes this.
  26. Jan 14, 2021 at 6:15 AM
    TrenThom86
    Trent
    NW Louisiana
    I’m 6’4 and still have to hold something to get into my truck. I’d rather have the handle than use my steering wheel. I’d be more curious to see how you get into your truck using no hands.
    Wallygator, 3xYOTA, WILLINH and 2 others like this.
  27. Jan 14, 2021 at 6:25 AM
    Ostrich
    Ostrich One bit me once.
    Nikki
    Marion, Texas
    2014 MGM Crewmax SR5 4x4
    3/1 level, black leather, raptor style grille
    Side steps and good balance helps. I'm 5'6" and get in without hands all the time when I'm carrying stuff.
  28. Jan 14, 2021 at 7:46 AM
    Ltaco17
    Ltaco17 New Member
    NC
    2023 TRD Pro
    285/75/18 Falken Wildpeak R/T color matched handles and mirrors.
    Put these s1 ditch lights on some Rago brackets.D68CDFF9-027C-411E-94E6-67B878131603.jpg4BCDFE73-9F69-40DD-ACCF-565F696BE04A.jpg
  29. Jan 14, 2021 at 7:51 AM
    chuffaluffigus
    chuffaluffigus New Member
    2021 Limited
    Not much of a mod, but I used Carista to turn off the seatbelt chimes and change a few of the climate control settings. In the mornings on the way to work it starts getting too hot in the truck, but if I just turn the system off the windows will start to fog almost immediately, so I change the setting to something like 65 degrees. As it comes from the factory the climate control would think I was trying to cool the truck at that point and turn on the A/C. Not what I want when it's 18 degrees outside. I changed that setting so that the climate control can't turn on the A/C automatically no matter where you set the temp. The other setting I changed has to do with outside air vents. As a default whenever you turn the engine off the car will open the outside air vents, presumably to let the interior breathe and fight lingering or worsening odors. We've had rodent issues in vehicles, and when they get inside they usually come in through those vents, chew through the cabin air filter, and go to town. I didn't want them to have that option, so I changed it so that the vehicle keeps those vents closed when parked. Our vehicles are garage kept and the garage is pretty sealed up against big things like wood rats, but I still catch the occasional field mouse in a trap out there. I don't want to find out after it's too late that they've been nesting behind the dash and wreaking havoc.
  30. Jan 14, 2021 at 7:53 AM
    a522467
    Michelle
    Ohio
    8” exhaust from dirty deeds industries is on.
    http://dirtydeedsindustries.com/product/standard-system/
    Supporting a local business, RJ (Muffler Man) put it on for me. :rolleyes:
    With the resonator, it’s not loud or obnoxious, especially at low throttle. It’s just a bit deeper and raspier than stock. The volume kicks up when you get on it, like when entering the freeway or climbing a hill. If you want “rowdy”, go for the 6” or budget (straight pipes) system, or perhaps leave the resonator off.
